Deliberating on kit for event and portraiture. 16-55, or others?
Started Dec 11, 2018 | Discussions
lewiedude2
lewiedude2 Senior Member • Posts: 2,662
Re: Deliberating on kit for event and portraiture. 16-55, or others?
Haha! Not a dismissal by any means, just trying to stay balanced. And yes, I hate it when people opine on something they don't have. That's why I only suggest something that should be checked out - flash, tripod, camera body, lens, food, wine, places to travel, cars, boats, castles, I could go on....
 lewiedude2's gear list:lewiedude2's gear list
Fujifilm X-T2 Fujifilm 16-55mm F2.8R LM WR
owenb Senior Member • Posts: 1,229
atalwar wrote:
Erik Baumgartner wrote:
The ideal event/portrait setup for me is the 16-55 (super versatile and good for portraits) and the 50-140 (versatile, excellent for portraits, excellent OIS for longer focal lengths) on two bodies. Using primes, most folks go the the 16 or 23 with the 56 route, but 35/56 will work too, less versatile though. At an indoor event I’d rather go 16/35 than 35/56. The 90, while great, is a bit long and not stabilized which limits its indoor usefulness somewhat. If I could only have one lens/one body it would be the 16-55, hands down.
+1, 16-55 + 50-140 is the most practical kit.
In good light, yes. Knowing the light conditions OP will be shooting in is crucial to being able to say with confidence that a pair of 2.8 zooms will be their best bet. I'd say 75% of the events I shoot I'd be sunk like the Titanic if I was stuck with those two zooms.
Add one or two special fast primes and you have more or less a workhorse kit. (You already own one).
I take the 16, 23, 35, 56 and occasionally the 90 to about 95% of my events and weddings and end up using them for most.
I suppose it depends what one means by 'events'. I'm a documentary event photographer at birthdays, weddings, luxury parties, etc, and almost all in very dark venues. Last week I was at an event that was so dimly lit that I was getting 1/50th second, ISO 12800, on my 1.2 and 1.4 primes.
Yes, I take a flash. But I will never use it unless I'm asked for a quick-n-dirty group shot by guests as I pass by. Otherwise I'm killing the mood and the ambient light by firing my flash all day long.
 owenb's gear list:owenb's gear list
Fujifilm X-T3
jjz2 Veteran Member • Posts: 4,396
There's nothing worse than an event with flashes going off every 10 seconds in your peripheral vision... Besides the look, part of the reason I don't like using flash is I know how jarring the experience is to me. A lot of people are sensitive to flash photography, strobe type stuff.
 jjz2's gear list:jjz2's gear list
Nikon Z6 Nikon Z5 Nikon Z 24-70mm F4 Nikon Z 35mm F1.8 Nikon Z 85mm F1.8 +1 more
Len-O Senior Member • Posts: 1,637
ViMa wrote:
hotaruhikari wrote:
That's good to hear. Heaviness was a slight concern, but as it has very similar weight to the 24-105 which I've used in the past, I should be able to handle it.
Regarding flashes, I suppose I should get a few in case I need them. I personally dislike the artificial look they create, but in some particularly dark venues I could see them being particularly useful.
How do you find hand-holding the 16-55 in dark conditions? I find that anything less than 1/125th often causes motion blur in people (thus why I don't prioritise stabilization), but I've only used stabilised zooms in the past.
I wanted to get the TT685F because I had read somewhere that the TT350F is too weak a flash. Folks in this forum kindly suggested that I go for the TT350F instead. Apparently the bigger one is a bit too big for the X-T2 and they say that the TT350F is good enough a first flash. There is also the V350F option with a rechargeable battery. At the moment they cost about 120 quid.
I have the TT350F and the X1TF trigger which makes for a great Godox off-camera starter which produces results with customized, subtle, and unique lighting without overpowering the subject. However, I primarily shoot worth available light.
I was fortunate to get myself a used 16-55mm in superb condition for $749 and it currently lives on my X-T3. I was not disappointed with the all of the reputation of this lens, including low light performance.  My great low light performer the 16mm f/1.4 has moved to the X-E3, and my 35mm f/1.4 & 23/2.0 standby.
 Len-O's gear list:Len-O's gear list
Fujifilm X-E2 Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R +8 more
imagei Forum Member • Posts: 64
hotaruhikari wrote:
Regarding flashes (...). I personally dislike the artificial look they create
Only if used incorrectly.
Regarding lenses, in any dynamic situation when changing lenses is not practical a zoom is the answer. I would recommend the 16-55 as the first lens to get for pretty much anything unless an ultra-light setup is the goal. Unless you need the razor thin DoF that the primes deliver it is an excellent and versatile lens, including portraiture.
 imagei's gear list:imagei's gear list
Fujifilm X-T100 Fujifilm X-T5 Fujifilm XF 35mm F1.4 R Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +4 more
