OP
IanYorke
Re: Make presets to fix the defaults.
NAwlins Contrarian wrote:
[I]t might be helpful if users could share any tips with Forum members to help those starting out with DXO-PL2.
There are several of the DxO PhotoLab default settings that I don't like, so I pull up one image from each of my cameras, change the settings to what I want, then save them as a preset (Image -> Create preset from current settings) for that camera. Examples of what I change / think you might want to change:
(1) change Noise reduction (a) from HQ to Prime, (b) with the Prime settings reduced from their default levels e.g. Luminance 40 and Chrominance 100 to more sensible settings depending on the camera and how you typically use it (maybe 15 and 30 or something);
(2) change Color rendering - Rendering from Camera default rendering to Neutral color, neutral tonality;
(3) (a) turn on Chromatic aberration correction and check the boxes for (b) Lateral chromatic aberration and (c) Purple fringing;
(4) turn on Unsharp masking, and choose some modest settings like Intensity 75, radius 0.3, and Threshold 5 (or you make want to start stronger, like Intensity 100, radius 0.6, and Threshold 3); and
(5) under Geometry, turn on Distortion and set Correction to Auto with DxO Optics Module.
This saves me considerable time on every image I process, and significantly reduces the chance that I forget to apply some correction or processing that I would want to apply.
Very useful post.
When you use new software you need to understand the philosophy of the software designers in order to fully utilise and not fight the software by trying to use the approach from your normal raw processing software.
DXO-Pl2's approach is one of user simplicity, make it easy. Your comments on presets is important because it fits in with DXO because preparing the basic image to your taste enhances the software's ability to produce excellent default results. All new users should take note of your suggestion to fine tune their results.
However I think you should rethink your use of Unsharp mask on raw images. With raw images and a lens module DXO-PL is designed to use the lens sharpness settings to control sharpness, the USM settings are really for RGB images or where no lens module is available:
The default settings are those determined by DXO from their optical lab measurements of the lens and attempt to take into account the variation in sharpness across the frame, generally more sharpness applied at the image borders.
Ian
