Godiwa wrote:
nice review but 7000+ photos in 24 hours? that's 1 picture every 12,34 seconds for 24 hours straight or did you just record highspeed video and count that as "photos" for each frame?
This has been addressed previously.
On January 20, 2018, I took just over 3,000 photographs between 2:30pm and 7:14pm using the EOS M6 with the EF 100-400mm f/4.5-5.6L IS II USM lens with extenders as part of a test to see if the extenders worked on the camera. This included time for me to drive to several different locations and to walk to where I was going to shoot from ... and to change lenses, drink beverages etc. That's a period of just under 5 hours for 3,000 photographs. And I started after lunch and finished before dinner. Many were of birds, swimmers, stationary landscapes and the moon. Others were of surfers or were for testing the results over water and warm surfaces to demonstrate thermal fluctuations and how longer focal lengths are subject to them. I don't waste shots if I'm taking them because every actuation of the shutter reduces the life of any camera. Less than a handful were useless or out of focus. I think there were just two shots that I couldn't justify from that session. Most of the images were keepers. I just had to decide which ones to keep. With Continuous Drive active, the M6 camera takes 9 shots per second. Obviously this changes with different settings but that's the standard. I seem to get around 6 or 7 fps myself.
This was not the first time I've taken 3K shots in a day (let alone in 5 hours). But it is the limitation for my camera batteries ...amusing because they have an CIPA rating of just 295 shots. I've recorded similar on three other occasions, not including the 32mm test days. A single battery on the EOS M6 using AI Servo tracking and/or burst mode) in JPEG mode is easily capable of this and I've often shot 3K worth of images at busy conventions of public fairground events.. In burst mode I can shoot clusters of shots in a single second. It's ideal for sporting, and moving objects. Sometimes I'll even use it for Macro to ensure I capture a precise area as I move the lens. My M6 is always set to Hi-Burst so I never miss a subject. I also ONLY SHOOT IN JPEG. So thirty shots in a few seconds isn't unusual. Many of my shots are singular because not all images require a Hi-Speed Burst. Shots taken in the museum need only be singular and more carefully composed. Shots of seagulls and people were usually in bursts. A measly 11.1 seconds of shooting at 9 fps results in 100 photographs. Do that 30 times and you have 3,000 photographs. Obviously I'm not shooting in burst mode all day long but it's easy to shoot a few thousand images over a single day, let alone in a weekend devoted especially to testing a new lens. I walked around 14 kilometers through and about the city over those two days and was tired for it. I only stopped to speak with people I knew who bumped into me on the street.
With the test on this particular lens, I shot for 2 solid days (48 hours) with just a few hours to sleep and recharge batteries. I even had my wife drive the car to and from the city so I could shoot out the window at vehicles and architecture & sunsets etc. I shot pictures of meals and at night as well. Then I went to the mountains a few days later and did it all over again.
