Focus problem - is this a fault in the G7 camera
Started Dec 5, 2018 | Discussions
Brisn5757 Veteran Member • Posts: 4,540
What I'm trying to find out is if I have a fault on my G7 camera or does this normally happen with the G7 camera.
When video recording the focus will change for a moment and what I'm recording goes out of focus. There doesn't seem a reason why the camera should attempt to refocus after it has correctly focused on a subject. There is nothing that becomes near the camera for the change in focus to happen. It can happen once within a 5 minute video clip and goes out of focus for a few seconds. It's enough ruin an important moment.
The camera is set to AFS/AFF
What I need to know is do owners of the G7 camera also have this problem?
If needed I could upload a video clip example.
Brian
 Brisn5757's gear list:Brisn5757's gear list
Olympus SP-570 UZ Sony Cyber-shot DSC-WX70 Sony Cyber-shot DSC-HX200V Sony RX100 IV Canon EOS 300D +9 more
Panasonic Lumix DMC-G7
burritosandbeer Regular Member • Posts: 314
Re: Focus problem - is this a fault in the G7 camera
Brian
So I'm still new to video with my g7, but I use AFC tracking with good results
 burritosandbeer's gear list:burritosandbeer's gear list
Olympus PEN E-PL6 Panasonic Lumix DMC-G7 Panasonic G95 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G X Vario PZ 14-42mm F3.5-5.6 ASPH OIS +7 more
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
manual advice
set the camera to aF then get your focus then set camera to MF and you will have the focus not changing if you leave your lens alone.
it may not solve every situation, but will solve some.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
JosephScha Veteran Member • Posts: 7,249
I used to have a G7.  In interior  (relatively dim) light the G7 can lose focus and refuse to refocus for a significant time.  I have examples in movies.
But now I have a G9 and especially with 1.2 Firmware the focusing is much better, and it's ADJUSTABLE in camera, which is awesome.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
pannumon Veteran Member • Posts: 4,130
Adjust the focus area to suitable size, or set up custom focus points for AF (custom multi AF mode).
I usually have Continuous AF set to OFF when I am filming (this is adjusted from the video menu). With this option, the camera auto-focuses only when I half-press the shutter.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
OP Brisn5757 Veteran Member • Posts: 4,540
To understand you better, do you mean that while video recording you half press the shutter to correct the focus if you move from a far object to a near object?
Brian
Brian
I think it uses more battery power but might be worth a try.
Brian
From the way I read it, your G9 had a problem focusing but this has improved with the firmware update.
I can understand having problems focusing in dim light but the refocusing happens in bright lighting conditions.
Brian
Re: manual advice
The only problem with this idea is that when video recording the subject is often changing it's distance from the camera. For example if I'm recording a parade then the float in the parade is a distance then gets very close to the camera when it passes by the camera and then distance as it goes further away.
However if the camera does start to chance focus on fixed distance objects then I quickly switch to manual focus once it has correcly focused again
Brian
Re: manual advice
it may not solve every situation, but will solve some. my technique was not a good idea for some parades, but could be good if you gave the parade a lot of focus distance if shooting far enough away.
JakeJY Veteran Member • Posts: 5,442
Brian
I have a GX85, but I do the same thing. I half press the button to refocus during recording.
With Continuous AF off, the camera never refocuses on its own while recording, only when I want it to.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
Brian
As you need to use this method to refocus then do you find that your camera goes out of focus for a moment for no reason.
What I'm trying to determine is do I have a fault on my G7 camera. If so I'll need to get it repaired before the warrant expires.
Brian
With 'Continuous AF' OFF, the camera makes initial focus when you start the video. After that the focus is locked at that distance. The camera does not change the focus. It is kind of manual focus mode. However, if the subject moves closer/forward to the camera, it is necessary to adjust the focus distance accordingly. With this method, the camera operator chooses when this happens by half-pressing the shutter release button. Using high F-numbers (like F8) helps with this.
I am quite sure your camera is OK. Video AF in this camera is not perfect. In different scenarios, different methods work the best. It can take some practice to know how to always get adequate results. In 1080 mode, the AF might be better than in 4k (at least it should be more responsive).
For example in that situation, yes. Or if the subject moves closer/further.
Brisn5757 wrote:
Brian
I haven't yet, but I use this method to make sure it doesn't happen for focus critical recordings. I have heard hunting like this can happen with Panasonic cameras. The last time I used continuous AF, I was using my GX85 and 12-32mm f/3.5-5.6 at f/5.6. It gives a decent DOF for the distance my subjects were at.
I don't know how true it is, but I have read that your initial focus immediately before you press record sets a baseline for focus, so it is best to set it to the correct focus first even if you use Continuous AF.
Brian
hindesite Veteran Member • Posts: 4,893
Is normal, BUT
What you describe is not a camera fault.
However, you haven't said what lens you are using, and how well the G7 performs AF with different lenses does vary, and especially so for non-DFD lenses.
With quick DFD lenses the disruption to focus is minimal and may not even be noticeable.
XVOYAGERX
XVOYAGERX Senior Member • Posts: 1,783
Re: manual advice
I f the video is important to you Always` use M/Focus, i never use Auto-Focus even on my GH5, no Auto-Focus system is immune to the `hunting-Bug` even Phase-Detect!!
Allan.
 XVOYAGERX's gear list:XVOYAGERX's gear list
Fujifilm FinePix F550 EXR Panasonic Lumix DC-GH5 II +1 more
XVOYAGERX
I have still to install that new firmware in to my GH5, JS, others, like yourself state that it makes one heck of a difference to their focusing systems, is it really that good?
Allan.
XVOYAGERX
No, i think that this is an inherent problem with most Panasonic and Olympus cameras that use contrast-detect focusing systems, phase-detect systems are better, but not infallible to odd hunting now and again, in my opinion auto-focus can not be totally trusted on most cameras, no matter what system is used, that`s why i always use manual focus!!
Allan.
Thanks pannumon.
I think I'll need to do some experimenting with my G7 camera and will try what you have suggested.
Brian
