Panasonic lumix GX7 firmware update (and wifi app)
Started Dec 4, 2018 | Discussions
bugabuga New Member • Posts: 11
I hope this message reaches Panasonic and helps make the company better. I'm posting here because their official forum is only tech related.
I have three gx7 bodies, one black and two silver; on the black something broke in the viewfinder and the image is corrupt; banding, patchy, off color, one of the silver ones hot shoe is offline and the other ones front wheel is stuck, turns but no input.
I don't mind all this, the cameras are/were well used and are capable despite this. What I don't understand is:
Why on earth won't you issue an update?! Auto iso in manual, more than one stop bracketing (i.e. -2,0,2), near eye focus, trippy rainbow colors in the menu...
It would take a reasonably decent coder 2 to 3 nights to port and twice as much to polish for the gp. It's a shame because there is/was potential here. Maybe the fridge will have iris recognition. Rant over.
Adios, b
p.s.: By the way: Your (Panasonic) wifi app is laughable(sh!t).
p.p.s.: firmware updates history for record:
- 2014/05/22, Ver. 1.3: nothing
- 2013/11/21, Ver. 1.2: Improved MF with one lens, flash expo comp. can be assigned to a botton(very good)
- 2013/09/17, Ver. 1.1: nothing
Panasonic Lumix DMC-GX7
Mark9473 Veteran Member • Posts: 6,428
Re: Panasonic lumix GX7 firmware update (and wifi app)
The team that used to work on the GX7 no doubt have moved on to other projects
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
OP bugabuga New Member • Posts: 11
Undoubtedly.
Like team members (software developers in this case, not product engineers/designers) from all other companies that issue software updates regularly, they go and write newer (hopefully) better code. That's what you meant, right?
There are many products in photography world that get updates and such, if nothing else just because of new lenses. We are talking about software that exist, no need to "invent" it, as you said: it's probably the same team that worked on it than. It doesn't change just because the button is in a different place.
Think of the android (windows...) update you (might) got last night, maybe it even made your 3mm 1.8 render shadows slightly different, or maybe learned how to make just a bit more out of that octa-core, not designing a new mold for a button. The company has chosen.
I own the Panasonic Lumix DMC-GX85 (Lumix DMC-GX80 / Lumix DMC-GX7 Mark II) and am probably never going to own the Panasonic Lumix DC-GX9.
You have many Panasonic products in your gear list and spend a lot of time on the forum. If you are endorsed by Panasonic you should of made that clear. If not I'm sorry and high 5.
Cheers.
I'm not affiliated to Panasonic in any way other than as a customer. Why would you even think that ?
Mark
I'm sorry mate. I was being a #!@.
I'm still not happy with Pana. Even when the product was new, 5 yrs ago(?), basically no updates/upgrades came out. Despite room and possibility for them. On topic and addressing your comment. I was giving them time
b
I sympathize, but I think that ship has sailed. 😏
Mark
alcelc
alcelc Forum Pro • Posts: 19,003
I suppose you should aware that GX7 is a model of 2 generations old. There are the GX85, and recently the GX9 as its successors.
I suppose some requirement you are expecting have been included to the later models, and you should also agree that if Pany publish certain upgrade by means of firmware, it is going to kill its sales on the successors...
I have very different experience. Indeed I am very impressed by the Pany products.
Used its cameras for 15 years and except one early bridge camera had dust issue on the sensor many years ago, had replaced the rubber sleeves of 14-45 and 45-200 after 4~5 years using, and LCD of GX1 had minor delaminated issue, none of them develop any sort of major problem.
To go extreme, my G1 and 7-14 f/4 had been dropped into a river. Pany Service Center advised me not to repair them because of the cost concerned and issued me a death certificate for insurance purpose. Luckily they were able to keep on shooting without major issue for a few years after the accident. G1 was retired but 7-14 is still one of my major lenses as of today.
Not sure how you use your gear, I have no complaints on my Pany gear at all.
GX85 has it. GX9 allows EC to make it complete.
Why not use 5/7 shots (ie., -3,-2,-1,0,+1,+2,+3), and on merging you might skip the unwanted shots. 5 shots is my default setting and sometimes shall use 7 shots.
near eye focus,
Not sure would it be useful to me. Single focus in its smallest size is all what I wanted. I think I shall never use it if it is added. Indeed I even never use face detection.
What is it?
I only own one GX7, not three, but have used it extensively since 2015. The LCD and evf are still working fine. Never noticed your problem. I have set the Menu background color to the traditional black. Not sure would it help?
Adios, b
Comparing to some other brands that I heard from other forums, Image App might not be the best, but never be the poorest... It just does what it suppose to do: operate the camera remotely and transfer files (after testing, I never use it). What more do you wish it to do? GX9 has added Bluetooth...
Look at GX85, which has only 2 firmware update before it was succeeded by GX9!
The 2 firmwares of GX85 were for:
  • 1) more quiet operation on video shooting, and
  • 2) add Focus Stacking for the Post Focus (a new feature after GX85 was released).
Other 2 items are minor improvement like flexibility on selection of sequence on bracketing and add Flash OFF to the Menu (meaningless since Pany cameras use physical switch to activate the integrated flash).
IMHO except for the out of factory fault (like the over sensitive IBIS of G85 and Pany issued an update very quickly), we are hard to expect the manufacturer to keep on refreshing the old gear by any mean, especially the lower end models that are generally regarded as consumer products. That is the life we have to live with it.
My 2 cents.
Albert
Lenses are cool, gx1 as well. Nothing about updating those in the post.
I also love it, the camera, (obviously, I had three, now only two), just wish they would up the software. I was complaining about that and the app. And I use them well I hope:)
This.
That's a "different" camera. I have the gx85. Never held the gx9. I truthfully prefer the form/size of gx7.
So We are paying 1000e for a software update? That is not "new" tech.
I don't use it for hdr (usually). It is important for me that the different exposures happen as close in time as possible. The shoots in between take up valuable time and are sort of useless, for me. Honestly +/-1 is little. "You" end up with 7 shots instead of three, and 7 shutter executions, that not only wear on the cam but also makes more noise(not signal). Really 2 would work for me in many cases, for example 0,-3.
near eye focus,
I use it and its useful, to me and I imagine to few others as well. Its good when light is abundant. I use point focus a lot also, obviously.
What is it?
Its colors of a rainbow turning, twisting and changing shape, often in symmetrical patterns, designed to escalate the effect of a hallucinogen. I wasn't serious.
What problem? I used them a lot. I can send them over if you want to have a look, seriusly, if we can agree on a fair price. Hot shoe one was manufacturer error, or a bug/moth, front wheel one got some cuba-libre over, evf I blasted in a rock.
Which is worse? It barely operates the camera remotely. Have you ever tried it? Seriously. Just install it now on phone/tablet of choice and shoot 10 shots.
Drops connection. Keep awake doesn't work. Wake up doesn't work. The device and camera can't be more than like/about/approx/cca 67 cm apart. Lags worse than 80s dial-up.
Its laughable and a in my opinion a shame for a company the size of Panasonic. It just shows how big/important the particular department is.
There, actually useful updates. It is ok that a device gets improved after it has been released! Even more so If its made of rough&tough, expensive to mine, alloys.
My 2 cents.
They can charge for it if they think it is better. These are the high-end cameras by panasonic not the lower end ones.
Well, anyhow, I'm glad You like them. I think they are good, too. They could throw it's not-so-loyal-anymore fan base a bone here and there, it's what I'm trying to say. Not make You buy a new camera so you get auto ISO in M. You know, make the planet greener type thing, make less trash, show that they are in the photo community and that they care. Again, for clarity, I like the gxs.
cheers, b
It's sort of: auto iso, next model; min shutter speed, next model... come on.
Even so, these upgrades could be provided for older(1 and 2 gen, not more) models easily.
This discussion could maybe use a topic/title/forum change. Its the same camera. New
  • processors,
  • material,
  • ease of use,
  • sensors (iffy),
  • use of new tech,
  • design solutions, like the EVF that tilts, the flash that tilts...
those and a lot more beyond me make a new camera, not a slightly different program running. That is an update, no?
alcelc
A small discussion on the Wi-Fi.
As being agreed among Pany users along the rolling out of Wi-Fi, it seems that a direct effective range of 30~50 feet could be expected.
I could do it happily with a very old Sony Android phone, a few cheap Android M.I.C. tablets, even a primitive Windows Nokia phone (old enough?). Not to mention the more current Android phones... If you have the 2 PZ lenses, it is fun to control the zoom remotely.
However, it is subject to usual Wi-Fi limitation like no walls in between. In the old day I used to have an AV signal transmitter (use 2.4Gh bandwidth) in my living room to connect my internet TV decoder & TV in my living room. I suffered from similar unstable Wi-Fi connection problem even within a very short range. Finally realized not only the GXs had problem, it also affected the usual Wi-Fi connection of my phones gradually (might be the AV transmitter which was sitting next to my Wi-Fi router was getting old). Stopped the AV transmitter had the problem solved.
When similar unstable Wi-Fi connection be complained, possible Wi-Fi signal interference could be a good place to look first.
Albert
MOD Tom Caldwell Forum Pro • Posts: 46,352
Panasonic does not seem particularly renowned for updating its firmware performance during a model release, but merely fixing known bugs.
Some other brands such as Olympus are known to update performance during a model - even if that meant losing the user settings until fairly recently.  Ricoh was known to release every performance update that was possible to their just superseded model when a new one was relased as a sort of friendly wave of “thank-you”.  But even Ricoh did not keep further improving software on models that were superseded.
Also depending on how the firmware was written.  Sony and Olympus (at least) seemed to need a complete replacment of their firmware when upgraded whilst Ricoh seemed to opt for a simpler upgrade procedure by mrely “patching” the presvious iteration. They could apparently do this from way back in the dark ages of digital without losing user settings.
It is a win/lose decision.  Updating firmware risks a certain number of dead cameras because the update was not properly carried out.  Regular fimrware enhancements makes for more devoted users who see this as almost like a free new camera in a sort of manner.
On the other hand adding some nice new firmware attributes that have been saved for a new model does help sell that model.
Tom Caldwell
dinoSnake Veteran Member • Posts: 3,570
Hi!
CORRECTION!
On GX7's with a broken REAR encoder dial, it can be very affordably fixed with a new part
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F152937869142Hi!
It takes only 13 screws to remove the entire top plate so as to access the dial's 2 screws.
I would recommend that you try to use the parts from 2 camera's top plate systems to rebuild the third camera - you'll have a fully functional camera and then hopefully you can get parts to rebuild the other two.
This might have more to do with the frequencies being (over) saturated. Once more of your neighbors start using 5.2 ghz freq and subsequently more devices you will likely start having similar issues again. My experience with panasonic wifi is only outdoors,. There are still other issues. Sorry but 50 feet is a dream, according to my experience, of course. Tried also in the middle (not exactly middle) of a desert with not too much tech around I would imagine, if there wasn't a mil base under my feet hampering the camera.
I realize that the tech is not perfected after 20 years. And am grateful for it with all its flaws and embrace it openhearted. There are other things, apart from signal, with the app itself (not the camera), that need a brush up.
b
That's why I waited for the gx9, in this case, to come out. Now I can be sure nothing is going to be done:). Neither in the future, likely.
I never thought of user settings and dead cameras (biggie), possible issues. Ultimately it would be user choice.
I would think that complete replacement is easier for them and therefor more sure. Possibly, in those cases, there is no update mechanism in the firmware so the only way than is to write over.
Nice of you to mention Ricoh
yup.
