Minolta A1
Started Dec 3, 2018 | Questions
Td2018 New Member • Posts: 1
Minolta A1
sometimes  I have a flashing half battery and no display in viewfinder but I can hear a grinding noise when I press the button
if I tap/bang  the bottom of the camera the ccd and viewfinder work and I can take pictures
can this be repaired ? Is it worth repairing
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Minolta A1
Sounds like , amongst possibly other things , the anti-shake is on it's way out .
Parts are no longer available , even if they were to be found the cost of labour to repair it would be several times more than a fully working camera is worth .
Time to get a replacement I think .
If you like the form factor of this camera , especially if you have the battery grip , you might like to have a look at the DiMage A2 ; https://www.dpreview.com/reviews/konicaminoltaa2
Both the A1 and A2 use the same batteries , so you'll already have some spares .
I prefer the the Dimage A200 , partly because of the swiveling rear screen ; https://www.dpreview.com/reviews/konicaminoltaa200
I also still use this camera from time to time when I'm shooting medium or large format film , but also want a compact digital option with the equivalent of a 28-200mm lens , rather than my DSLR or NEX 7 and several lenses .
Both these  cameras use an 8 megapixel sensor and can share accessories such as the wideangle , telephoto and macro converter lenses along with the same flash guns .
There are much more modern camera to buy new or used , but at the price these go for you can't complain .
For best results , shoot RAW and develop in modern software such as Lightroom .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
