SX620: Auto v. P modes?
Started Dec 2, 2018 | Discussions
richarddd
richarddd Veteran Member • Posts: 3,446
It seems that there is no difference between P mode with all the defaults and Auto mode on the SX620.  Am I missing something?
 richarddd's gear list:richarddd's gear list
Sony RX100 III Canon G5 X II Olympus OM-D E-M5 Panasonic Lumix G Vario 7-14mm F4 ASPH Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +5 more
Canon PowerShot SX620 HS
I2K4
I2K4 Senior Member • Posts: 1,441
Re: SX620: Auto v. P modes?
I'll certainly defer to the camera's manual - which you should read carefully - and to anyone who owns your model camera. But typically while Auto automates nearly everything except flash use, P Mode lets you
. select ISO (and then adusts Av and Tv accordingly)
. access Exposure Compensation
. access the Func/Set Menu, depending on model a rich set of choices
each covered in the manual.  I've found asking "What would Auto do?" is a good practical, if not spiritual, place to start with a new camera, using the detailed playback display to decide if it got the shot right.
