Difference between Lumix G7 and G80
Started Dec 1, 2018 | Discussions
Photographer9778 Forum Member • Posts: 60
Hi!
Other than the price, what is the difference between the Panasonic Lumix G7 and the G80?
Many thanks
Panasonic G85 Panasonic Lumix DMC-G7
Danielvr Veteran Member • Posts: 6,863
Camera comparison feature
 Danielvr's gear list:Danielvr's gear list
Olympus E-M1 Olympus Zuiko Digital ED 12-60mm 1:2.8-4.0 SWD Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Carl Zeiss Planar T* 1,4/50 Panasonic 20mm F1.7 II +2 more
brentbrent Veteran Member • Posts: 5,768
Re: Difference between Lumix G7 and G80
The following is quoted from this page of DPReview: https://www.dpreview.com/reviews/panasonic-lumix-dmc-g85-g80
Though Panasonic has not come outright and said it, the G85 is the successor to the G7. More a refinement than something new entirely, both cameras share seemingly identical bodies and offer twin control dials, plenty of customizable buttons and fully articulating touch interfaces.
But the G85 is rather more grand: it's weather-sealed with a magnesium alloy front plate, and offers a new electromagnetic shutter to combat shutter shock, an upgraded electronic viewfinder and 5-axis in-camera IS.
Like the Panasonic GX85, the G85 uses a 16MP chip with no anti-aliasing filter. We found image quality from the GX85 to be slightly improved over that of past Panasonic cameras using the same 16MP chip with AA filters (like the G7).
The G85 also uses the same redesigned shutter mechanism as the GX85, which we found to effectively mitigate shutter shock, an issue that affected the Panasonic G7.
I've added bold to the five main upgrades.  The G80 also offers Dual IS with many Panasonic lenses, where the camera's image stabilization works together with the lens' image stabilization.  The G80 is a very substantial improvement over the G7.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
JosephScha Veteran Member • Posts: 7,249
The review of the G80 said said it was "the camera the G7 should have been."
It has a new shutter mechanism that greatly reduces shutter shock.
It is weather proof.
It has in camera focus stacking, the G7 doesn''t.
There's probably more.  I used to have a G7 but jumped from that to a G9, so I only listed what I'm sure of.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
davidedric Veteran Member • Posts: 7,339
I endorse the other comments (I have both bodies).
It's a shame that the improvements come with increased size and weight, but I guess that's the price you have to pay).  It's why I won't be moving to a G9.
Maybe I should be looking for a used G80 and sell the G7
Dave
 davidedric's gear list:davidedric's gear list
Sony RX100 VII Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic 12-35mm F2.8 +3 more
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
Lumix G7 and G80
the main difference is that you would want to get a g80 if you shoot a lot or need a higher quality cam.
the g7 advantages are a plastic lightweight build and no image stabilization.   so if you dont need that then get the g80.
others have also listed great answers.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
OP Photographer9778 Forum Member • Posts: 60
Re: Camera comparison feature
thank you
thank you
Okay, thank you
Re: Lumix G7 and G80
thank you
WT21 Veteran Member • Posts: 5,473
Photographer9778 wrote:
Hi!
Many thanks
Lots of answers already, and I never had a G7, but you can see my gear list in my profile. I've used TOO many cameras, and I would say the G80 is one of the best I have ever used.
Cons: I would like better C-AF, but it has workable C-AF. I would like 24MP instead of 16MP. I would like double the battery life, but it has better battery life than the GX85.
Other than that, it's fabulous. Handling, IQ, pixel sharpness, IBIS, Viewfinder, etc.
 WT21's gear list:WT21's gear list
Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic 100-300mm F4-5.6 II Olympus E-PL7 Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 +6 more
