Phantom Power Drain on X-T3
Started Nov 25, 2018 | Discussions
Sugyn Regular Member • Posts: 179
My X-T3 is using power when it is turned off. fresh battery dies in about 48 hours with camera turned off. Anyone have a reason this might occur? Just in case I turned bluetooth off but didn't seem to effect it.
Fujifilm X-T3
c0les0 New Member • Posts: 6
Re: Phantom Power Drain on X-T3
I had a similar issue while flighing in the trip. From fully charged camera at home it became a fully discharged after 6 hours... Seems, a random start might occur...
But anyway, there is a 2 mins delay for power off in yht settings.. that's strange.
OP Sugyn Regular Member • Posts: 179
I can understand if it turns itself off, because it has to have enough power drain to detect when the shutter is pressed to turn back on.  But my battery is going dead with the power switch set to off. I'm afraid it's looking like a service issue unless someone knows a reason it could occur. To have an issue on camera so new (just 2 months old) is annoying especially when it's to late to return it.
Hate to bump my own thread but hoping someone can at least confirm there XT-3 doesn't drain batteries when turned off.
Miroslav_1
Miroslav_1 Regular Member • Posts: 240
I confirm. Have you checked your battery in other camera? If not leave the battery out of camera and check if it drains.
 Miroslav_1's gear list:Miroslav_1's gear list
Sony a9 Sony a7R III Sony a7S III Sony a1
chimphappyhour Senior Member • Posts: 1,087
I think I saw somewhere a suggestion that "off" is more akin to a deep sleep. If the camera senses input from the shutter button (such as it sitting wrong in the camera bag) it'll give it a little "sleep apnea" to continue the analogy. I haven't had issues but it's something to look into.
 chimphappyhour's gear list:chimphappyhour's gear list
Fujifilm X-T20 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
Thanks for checking not looking forward to sending a new camera in for service so soon and so close to the holidays
I reset camera changed lenses and used 3 different batteries always the same result dead in about 48 hours. In comparison my XT-20 same battery for 5 days shows no loss.
Thanks for looking but it seems my camera is unusually power hungry just what a Fuji camera needs. Looking into service Monday.
Dark Mist Contributing Member • Posts: 559
I have the opposite problem.
The batteries in my X-PRO 2 and XT-2 hold their charge for weeks if the cameras aren't used. However, my spare batteries lose their charge within around 48 hours. The batteries are interchanged randomly and I don't think it's individual batteries going flat but I will need to note which batteries go flat and which hold their charge.
This behaviour is counter to what I expect to occur and what happens with my other camera batteries. Is it normal for Fuji batteries to discharge quickly when not in a camera?
ikaika777
ikaika777 Senior Member • Posts: 2,626
I can have my Fuji camera batteries sit for a couple months in my camera bag without fully discharging. Probably with over 60% juice left.
After all is said and done and your photo is hanging on the wall, no one is going to know or care what camera, lens, or what post processing you used. All they care about is if the image moves them.
 ikaika777's gear list:ikaika777's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 16mm F1.4 R WR +18 more
Well that just sounds crazy   Maybe it's how your batteries bounce around and if they touch something?  As for my camera, service said it sounds like a service issue. Feels so awesome to spend another $27 on shipping and insurance for a camera only 2 months old. The sad thing is I think it was this way from the start but I was using it almost daily so did not notice. Than it sucked a battery dry and a approved anker external battery in about 4 days when I wasn't using it. Oh well hopefully it returns from service soon and it all becomes a distant memory. Will post upon it's return.
Re: Phantom Power Drain on X-T3 UPDATE NOT HAPPY!!
Well sent my camera to Fuji Edison NJ repair center. They turned it around quickly because they did nothing and sent it back defect intact. They than argued that they didn't do nothing because they measured some voltage that they said was good. Of course I pointed out that they than did NOTHING to fix the problem and sent it back. I than asked to talk to a supervisor because by this point I was livid. They transferred me to a supervisor voicemail who never returned my call. Really not happy with Fuji right now. They choose to ignore my observations entirely and without calling just sent it back. So beware of the problem new battery by 24 hours with camera turned off 3 bars down within 48 hours dead battery.
Patrik1404 New Member • Posts: 1
Hi, I have the same problem. Did you manage to find out what it is?
Sorry should have finished the story. I made a fuss as I should have and they took it back and concluded I was absolutely 100% correct. They acknowledged it and fixed it. So just press the point if your camera turned off with fresh battery over night loses charge.
MehdiT
MehdiT Regular Member • Posts: 396
Do you by any chance use a soft release button on your camera? I had one on my X-Pro2 and found that it was pressing on the side of my camera bag and causing it to drain the battery in an hour or so. I removed the soft release and the problem went away. I found a few threads relating to the issue, as one poster in this thread says, off is not off.
Mehdi
Fuji X-T1, X-T1 (IR), X-E2, 10-24, 18-55, 55-200, Zeiss 12, 32, Rokinon 8, Olympus Pen half frame and Canon rangefinder lenses
 MehdiT's gear list:MehdiT's gear list
Fujifilm X100F Pentax 645D Olympus OM-D E-M10 II Fujifilm X-Pro2 Hasselblad X1D +28 more
No it was a defect Fuji fixed it the second time around.
Laurence7 New Member • Posts: 1
I'm afraid mine does the same. I put a fully charged battery in the camera two days ago and doubled checked that the camera was turned off. Went to use it today and the battery was completely flat.
SailingWJ New Member • Posts: 2
Thought I's ask here... my issue is the battery dies after about 10-12 days in storage.... looses a bar after about 3.... Using Fuji "S" battery that came with the X-T3 and swap with the others I have same vintage... all seem the same.... I'm debating if I should send in before the warranty runs out... or is this relatively normal?? Appreciate any input... Thanks!!~
Mine drained a lot faster 24-48 hours but if it is set to off there should be no power drain IMO.  Mine got fixed but it was a battle. I haven't used it in days and no drain. Try another battery than I'd send it in if you feel it's an issue mine was.
Tom Schum
Tom Schum Forum Pro • Posts: 11,893
I have a X-T3 and I think "two weeks to kill the battery when the camera is off" means the camera is draining the battery too fast.  I can understand if it loses a couple bars in that amount of time.
Convincing Fuji that you have a problem might not be possible.  Is the problem slowly getting worse?  If so, you have a reason to be worried.
Tom Schum
Cooper: a person who makes wooden containers from timber.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +12 more
