Jumping off the fence
Started Nov 25, 2018 | Discussions
quiquae Senior Member • Posts: 2,265
After a month of staring blankly at the sky asking myself whether I really wanted a full frame mirrorless, I decided this afternoon that I'd be more productive if I just bought one and stopped daydreaming about it. So here we go.
They had the camera and the 35mm lens in stock, but the lens hood was not! The bastards!
With the sun setting rather quickly, I had to go shoot without even bothering to read the manual, so this is not a review, just a first impression:
As much as I like the EF 35mm IS, I think I'm going to sell it now that I have the RF version. The bokeh seems very nice.
Is it really the case that there is no magnification focus support for unchipped manual lenses? This shot with the Samyang 14mm F2.8 was a royal pain in the butt!
APS-C crop seems OK, to the extent that a 13Mpx crop is OK, but dusk was not a very good time to test it, since the noise level when cropped feels like a 13Mpx APS-C camera, too. (In retrospect, this should not surprise anyone.) I'll have to try this again some other time.
One thing is for sure, this is not something you can just pick up and expect to be an expert at in five minutes just because you have experience with an older Canon camera. You actually have to sit down with the manual and try to make sense out of it.
 quiquae's gear list:quiquae's gear list
Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F4L IS USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II +6 more
BirdShooter7 Veteran Member • Posts: 9,127
Re: Jumping off the fence
I certainly agree with your last paragraph.  I hope Canon really ups their game on the next R user interface.  The R seems like it could be a very nice camera for me if it had more of a conventional control layout/user interface.  Every time I have tried the R so far I have walked away quite frustrated.  If this sort of ergonomics is the future of photography then I might have to find another activity to occupy my time as this R doesn't make photography fun for me at all.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
Rawpaul
Rawpaul Senior Member • Posts: 2,567
Realy ? i have great fun using the Eos R.
maybe for me its easier to adapt to new  innovations .
light is the source of all life.....
 Rawpaul's gear list:Rawpaul's gear list
Canon EOS M5 Canon RF 24-105mm F4L IS USM Canon EOS R5 Canon EF-S 17-55mm f/2.8 IS USM Canon EF 70-300mm f/4-5.6L IS USM +6 more
Ed Rizk Veteran Member • Posts: 3,898
I didn't have to read the 6D manual.  I picked it up and found everything pretty much where it was on the 60D.   Simple.
I tried the same thing with the R, and I could actually take a picture.  However, a lot was different in terms of button and  dial placement and use, and a lot was new.
I ended up having to read the manual.   After that, it was easy and fun to use.   But it is a really new camera.
I don't shoot every day.   I am not a speed shooter.    Sometimes I take both cameras out for the sole purpose of taking pictures.   Most of those times are real estate shoots, which take 30 minutes.  Some are recreational shoots which last as long as the light, typically a couple of hours, or until I decide to do something else.  But most of the time, I have something else to do while I'm taking pictures.    If my life was more focused on photography, I might have a harder time adjusting.
Ed Rizk
 Ed Rizk's gear list:Ed Rizk's gear list
Canon EOS 6D Canon EOS R Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +4 more
Sittatunga Veteran Member • Posts: 5,406
You can get 5x and 10x magnification in the viewfinder or on screen with unchipped lenses. I use the swipe function of the M-Fn bar to control viewfinder magnification, the left hand end to toggle the histogram display and the right hand end to toggle the level display. That way I can leave the bar unlocked without getting any nasty surprises from touching it accidentally. I also have focus peaking on permanently as that doesn't work with lenses set to autofocus. I'm a bit disappointed that focus peaking doesn't work in magnified view (it does on the EOS M10) but that's not the end of the world.
I leave the focus aid permanently on as that disappears with lenses set to autofocus. It only works with chipped lenses as that's how the camera knows there's a lens actually mounted, but it even works with an f/16 catadioptric lens, which is amazing. It would be worth glueing a chip onto an unchipped EF mount lens just for that, if you can get one that doesn't confuse the camera.
The camera can use the rear screen for all sorts of controls, so coming to it in an EOS M frame of mind makes it a lot easier than treating it as a DSLR. I'm still coming to terms with the Fv mode where you use the rear wheel to determine whether the front wheel controls shutter speed, aperture, exposure compensation or ISO and choose how many of those remain on AUTO. It promises to be very powerful.
OP quiquae Senior Member • Posts: 2,265
Well, you know, I had a similar reaction when I started using a 7D mark II after the 6D, yet no one accuses the 7D mark II of having obtuse interfaces. It's just that these newer bodies have more features to get used to than the 6D.
I had an instructor in college saying: "UNIX is a power tool. Power tools kill. Be careful." One may say the same thing about powerful cameras. You have to try to learn one in earnest to get good results.
Rawpaul
You are right, but isn’t part off the fun
Learning new stuff?
I think the learning procces is fun too
Thoughts R Us
Thoughts R Us Senior Member • Posts: 2,910
Learning new stuff?
That is really the attitude to have...enjoy the journey of learning.  I too find the R enjoyable to use.  But all mirrorless cameras are an adjustment, because they operate in many ways fundamentally different than DSLR's.  The DSLR is a kind of hybrid between old school film cameras and modern day computers.  MILC's are closer to just being the computer.
And yes, I would advise anyone new to mirrorless, regardless of brand, to give it a bit of time to learn before passing judgement.  We all can learn if we just persist.
Learning new stuff?
It is for me, but I'm not under the pressure to crank out pictures every day that some are.
I'm still excited about opportunities to experiment with all the new features.
Ed Rizk
Rawpaul
Learning new stuff?
i am not a pro too ,but so are most on this forum.
If you are a pro, maybe the R is not for you.
Canon said it,s no pro camera
Just my opinion.
Badwater Senior Member • Posts: 2,095
Congratulations on your new camera.  I'm happy for you and your new Canon.  Now you can enjoy all the FF goodness that others have experienced for so long.
360iViews
360iViews Regular Member • Posts: 292
RTFM is soooooo overrated! 😀
Of course it might have helped me to read the manual to see if there was a setting I needed in order to use my Rokinon version of the Samyang.
 360iViews's gear list:360iViews's gear list
Canon EOS R Canon EOS-1D Mark II N Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS M +16 more
Probably more like we shoot different types of subject matter in different conditions.  I'm sure the folks at Canon aren't idiots and have designed a camera that is great for some, I am just not one.  I hope future models rapidly improve things for my type of photography.
Oh I love learning new stuff.  Unfortunately in its current state the R is a big step backwards for me.
I don't have a lot of experience with mirrorless for sure but have had some time with the R as well as the Panasonic G9 and Olympus EM1mk2 and the R is by far the least pleasant experience.  I hope that this is just Canon trying to figure things out and they advance quickly.  I really have no desire to switch brands.
Astrophotographer 10 Forum Pro • Posts: 13,911
Congrats and lovely photos. I don't have an EOS R but focus peaking should be activated for manual focusing. That makes it very quick and easy.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony a7R III Canon EOS Ra +1 more
Aw c'mon don't be like that! Are you sure its just not the process of becoming familiar with something new? That can be offputting.
Greg.
Everyone is different.  I definitely had no problem adjusting to the 7d mk2, the R on the other hand is quite different.  I'm definitely looking forward to seeing more advanced models.  I know Canon is good at making the UI painful as experienced in many of the rebel models.
Yes, quite sure.  Also let's be clear, I am speaking for my own use not for the public in general but I must say that after I read the review on this site I thought they are right on the money.
Thanks. Having had some experience with EOS M5, I did know enough to turn on focus peaking; the problem with the Samyang 14mm is that the DOF is so deep that pretty much the entire screen turns red. I’ll have to try again next weekend with other MF lenses I own.
