Canon EOS 300D -350D - clicks??
Started Nov 25, 2018 | Questions
geneacom
geneacom New Member • Posts: 3
How can I determine how many clicks on my Canons EOS 300D or 350D?
Or is that only possible on EOS 650D and later?
kreygscott
kreygscott Senior Member • Posts: 1,285
Re: Canon EOS 300D -350D - clicks??
Hi geneacom,
There have been rumors that using certain hex editor tools can determine the shutter count of older cameras including the above mentioned cameras. Your best bet is to perform a YouTube search and see what comes up. Alternatively you could try your local camera store.
Best of luck.
LANDSCAPE, TRAVEL & OUTDOOR PHOTOGRAPHY
My Website
http://kreygscott.com
My Stock Portfolio
http://shutterstock.com/g/kreygscottphotography
My Blog
http://prakticalphotography.blogspot.com
 kreygscott's gear list:kreygscott's gear list
Canon PowerShot S110 Canon EOS 5D Mark II Canon EOS 7D Canon EF-S 10-22mm F3.5-4.5 USM Canon EF 17-40mm f/4.0L USM +9 more
geneacom
OP geneacom New Member • Posts: 3
Hello, scottcraig Thank you for your info. I will try to find more on YouTube.
I will keep looking!
Best regards,
Rob van Willigen
kreygscott
Best regards,
Rob van Willigen
No worries Rob,
Sorry I couldn't be of more help.
My Website
My Stock Portfolio
My Blog
Doug Pardee
Doug Pardee Veteran Member • Posts: 9,920
The shutter count's only accessible via a special computerized tool that the Canon shops have that connects via the hot-shoe. There's no way for the average person to access it.
Does it really matter? Those camera models are ancient, cost next to nothing when bought used, and probably won't be used for taking that many more pictures. If the shutter is still moving smoothly and not producing light leaks -- look for white arcs in the image at super-fast shutter speeds like 1/2000 or higher -- it'll probably last long enough.
The 300D is more prone to sub-mirror hinge-pin failure than to shutter failure. The 300D's shutter is also unusually susceptible to damage from old flash guns, because it's only rated to 6V on the firing pin. So if you're looking at a 300D, you might want to be sure it can fire a flash. But I can't imagine buying a 300D these days, with its limited controls.
Co-founder of the open-source LightZone Project: http://lightzoneproject.org/
 Doug Pardee's gear list:Doug Pardee's gear list
Fujifilm X-T10 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Olympus Stylus 1030 SW Canon EOS 350D +13 more
geneacom
The reason I was asking is that lately my Canon EOS 300D is showing some problems.
Usually after one or two shots the camera shows an error and stops. After shut down and restart I can again make one or two shots and then stops again .
I can repeat this everytime, but it is quite ennoying ...
Doug Pardee
My knee-jerk reaction when one of these older cameras starts behaving wacky is to suspect that either the processor is confused, the date/time battery is going dead, or both.
I'd suggest removing both batteries -- the main rechargeable and the CR2016 "button" date/time battery -- from the camera and letting it sit for a few minutes before putting them back in. That will allow the processor to reset.
If that works for you, you might consider buying a new CR2016 date/time battery, since those are usually good for just a few years -- the manual says five years -- and that one's probably over a decade old.
It's also possible the main rechargeable battery is losing its ability to hold a charge, but that's usually a lot more obvious.
What error is it showing?
Wayne Larmon Forum Pro • Posts: 10,698
Several reasons for using a 300D now.
I bought one a few months ago for $30 on eBay.  I was testing A.I. Gigapixel and wanted to shoot the same scene on both the modern cameras that I now use and on the cameras I used, back when I used them.  This is easier than trying to duplicate things I shot in 2003 with my modern cameras!
A $30 DSLR is also a real good bad weather camera (if you also declare one of your lenses to be sacrificial.)
Wayne
