Camera Settings for Safaris
Started Nov 23, 2018 | Discussions
averacpa Regular Member • Posts: 219
Hi,
I am working on setting up the MySet for the upcoming safari trip so I can practice beforehand.  I'll be using the Oly EM1 Mk I and the EM5 Mk II cameras with Oly 40-150 (+/- TC) and the Pany 100-300 Mk I respectively.  The Oly 12-40 will be on the GX7
I am interested on your Oly camera settings setup (silent, low speed, single point focus versus 9, C-AF, S-AF, etc..) Checking with folks who have been on safaris and used either of these cameras.
I currently have one of the MySet configured for birds, so I am looking for your setup for animals.
I normally shoot travel/landscape, so animals is a bit new to me.  Plan on practicing at the local zoo next weekend.  Will be shooting raw.
Any advice or suggestions is greatly appreciated.
Andrew
Olympus E-M1 Panasonic Lumix DMC-GX7
MRK83 Senior Member • Posts: 1,133
Re: Camera Settings for Safaris
I have been to Africa a number of times. Most recent trip here :
My default setting (not using a myset) is shutter priority, auto iso. Then I set the shutter speed based on conditions, with selected shutter speed based on focal length and whether the subject is moving.
I do have a myset for birds in flight - all focus points, highest speed burst that allows continuous focus and continuous auto focus selected.
From my observation of photos that people display after a safari, the most common problem is little or no attention paid to composition. You might not be inclined to do this, but I have seen many potentially good photos ruined by the animal's face being in the middle of the frame, with part of the animal cut off and a large amount of empty space above and in front of the animal.
That's not so say you shouldn't zoom in for a portrait, or include negative space, or some other object in the frame if the scene requires it, of course. I think your idea of practising at the zoo is a very good one.
Enjoy your trip.
Michael Kilpatrick
Bob657 Veteran Member • Posts: 3,486
averacpa wrote:
Hi,
Andrew
I've gone on 7 safaris with m4/3, currently using the EM1.2 and EM1.1.  Most of your shots will be of relatively static animals, seeing a chase or hunt is the exception.  On the EM1.1 I shoot silent, smallest focus point, SAF + MF, usually using the 12-60 PL.  Any action, or long focal length is on the EM1.2 although I used the Mark 1 for this before.
You might consider using the EM 1.1 with the 100-300, it should have better CAF ability should there be any action.  I haven't used the EM5 Ii so you might be the best judge of that.
Bob G
Visit my website at:
http://bobgreenberg9918.zenfolio.com
 Bob657's gear list:Bob657's gear list
Sony a6400 Sony a7R IV Sony FE 100-400mm F4.5-5.6 Tamron 18-300mm F3.5-6.3 Di III-A VC VXD
OP averacpa Regular Member • Posts: 219
As I was experimenting with the Pany 100-300, I have noticed that the Pany's OIS seems to give me sharper (static shot, low light 1/50 f4.0 hand held) images than using the EM-1's stabilization wide open and at both ends 100 and 300.
I will be making more tests once the EM-5 arrives, to see which camera/lens combo works best.
Next Day:
Done some more testing, hand held using a downloaded microscopy resolution test chart, printed off a laser printer and taped onto a solid panel.
Trying to use all the lenses wide opened using both A and S dial settings.
Standing approximately 20 feet from test image outside in overcast light, I ran off a series of shots on the EM-1 Mk I using both my 100-300, Oly 40-150 with and without the TC.
Based on these rough tests shots, I found that my copy of the Pany 100-300 at f5.6 resolves significantly better than the 45-150 at F2.8 when the image is enlarge to equate to the Pany at 300mm.
The images of the 40-150 with the TC and the Pany set to 214mm and f5.1 (I must have moved the zoom ring) is about the same, with the Pany perhaps just slightly better.
The Oly f2.8 40-150 without the TC is sharp wide open.
What I have concluded for the Safari purpose is to have the Oly without the TC on one camera and the 100-300 on the other (either EM1 or EM5). Depending on distance, I will need to switch from either camera. The third camera, GX-7, will have the 12-40 in case we get fairly close to the animals. Probably have my wife carry that camera leaving me handling the two.  Granted, the two lenses are not at the same f-stop, possibly giving an edge to the Pany, but the Oly pro lens should be sharper.
Next step is to conduct similar testing at the zoo with moving animals
Oly at 210mm f4.0 1/500, no editing, just converted to jpeg.
Pany at 214mm f5.1 1/320, no editing, just converted to jpeg.
I was hoping that others with experience would chime in on the their settings when using either the EM-1 Mk I or the EM-5 MK II.
Hopefully I'll have the EM5 within a week and can begin testing which lens combination and settings works best for each of the two cameras using either the Oly 40-150 pro (+/- TC) or the Pany 100-300 MkI.
C Sean Veteran Member • Posts: 3,423
I used Back Button Focus and have three of them saved to my custom setting for different scenarios.
  • Aperture Day Light shooting
  • Shutter Speed
  • Aperture Low Light Shooting
Regarding shutter speed. Normally you don't see animals running and you have to be at the right spot and at the right time to see a hunt that develop into to a chase.  You would be very lucky to discover predators stalking it prey, which develops into a chase and ends in a kill.
vallecano Contributing Member • Posts: 770
"You would be very lucky to discover predators stalking it prey, which develops into a chase and ends in a kill." Your are right and I am one of those lucky ones. A pride of lions on the hunt at night resulting in kill and I managed to get some good shots. This was in 2008 in South luangwa, Zambia. Never give up hoping!
Earl
Madrid
 vallecano's gear list:vallecano's gear list
Olympus OM-D E-M10 Olympus 12-40mm F2.8 Pro Samyang 12mm F2.0 NCS CS Panasonic Lumix G 25mm F1.7 ASPH +1 more
Bobby J Veteran Member • Posts: 5,191
Michael, I just looked at your gallery of your last trip and it is wonderful!  WAY better than 90% of what I see here normally.  Looks like you and your G-9 and 100~400 know what you are doing.  Thanks for sharing.  I am Green with envy.🤢! 😄
BJM
 Bobby J's gear list:Bobby J's gear list
Olympus M.Zuiko Digital 45mm F1.8 Panasonic Lumix G 25mm F1.7 ASPH Olympus 12-100mm F4.0 Olympus E-M1 Olympus E-M1 II +9 more
Thanks Bobby. I'm going again in March 2019 and am really looking forward to it.
Michael Kilpatrick
(unknown member) New Member • Posts: 3
Yeah those pics are really nice! It looks like you used a really long lens for all of them. For a wide-angle shooter not accustomed to teles, what would you say is the shortest focal length one can get away with on safari to get environmental portraits of the animals? Close-ups don’t interest me, but, you know, it should be clear that wildlife is there, right?
I’m going to Botswana in late Dec with my GX9. Will I be kicking myself if my longest lens is 60mm?
On m4/3 I have done a similar trip (in 2013) with a Pana 100-300. I wouldn't want to go any shorter than that. It, or the Oly 75-300 are both pretty compact and not a big deal to carry.
I think you will regret it if your longest focal length is 60mm. I certainly took very few at, or near, that focal length on either of those trips. You'll enjoy the trip though.
Michael Kilpatrick
