ViMa
First try with the XF 60mm - Impressions
Nov 22, 2018
Hi! I have mentioned in a number of threads that I recently got the XF 60mm (quite cheaply too!). My initial reaction was very mixed. The moment it arrived, I tried it indoors, in my living room which isn't that well lit, and I so that front element hunting so much and felt like I just threw away 250$. But I persevered. I have since tried shooting the Original Marathon in Athens and then my first try at some macro/product photography at my mother's shop.
Here are a few sample images (forgive the poor quality since I've never really shot neither moving subjects nor products before) followed by my impressions. All but for the 1:1 are SOOC Jpegs.
Runner for the 10k race
Third place in the Full Marathon
Corn and Chestnut Seller
The missus in her natural environment - a bookstore
My first proper try at Macro with a 10mm and a 16mm tube for almost 1:1 magnification
Same Ring but without the tubes.
Old men.
So. First of all, obviously I did not have the proper tech to shoot the rings. I used the bundled X-T2 flash and put a piece of paper on its front. I put a remote release trigger to avoid camera shake and placed the camera on a tripod. I had no optimal lighting or anything.
Now to impressions:
This lens felt huge. I then realised that the lens is far from huge, and in reality not that much bigger than the f2 lineup. What makes it appear huge is that damned lenshood. When reversed and stored, it increases the size of the lens by a lot. Solution: after reading a lot of older threads here, I'm not going to be using it anymore and I've purchased a 35mm f1.4 hood that should be in my hands by Christmastime.
The lens is great. It is not slow at all, nor is it that noisy. As long as I'm not using AF to move from a subject in the background to one close to me, it focusses quickly.
I am very pleased with it. It takes nice portraits, seems to be quite sharp and it renders colours in a pleasing way.
In the end, I feel that the XF 60mm is probably a better partner to my 35mm f2 than the 50mm f2 would be. The design and size of the f2 lineup is really attractive, but the 60mm is not that much bigger, and it looks quite sleep with the 35mm lens hood on it. It's quick enough, takes great portraits, can get in quite close (the more I use those tubes, the more I see that 1:1 is not really necessary with few specific exceptions) and could work as a nice enough walk-around lens should one wish to go tele.
For the price of 250$ which is what I got it for (good as new, with its box and everything) I cannot see why so many people are dead set against this gem of a lens. It may be that AF has gotten much faster on the X-T2 compared to older bodies or firmware versions, but as is now, it's great.
For those of you who like me are not dedicated macro shooters but like the idea of going close once in a while: do not be deterred by the 0.5:1 magnification. It's REALLY close. You really don't need more and should you, just get the tubes. I got the Meike ones for 20$ and they work just fine and look sturdy enough.
P.S. any sort of criticism or suggestions on the above pictures is welcome.
