Buying used EM-5 II vs EM-1
Started Nov 21, 2018 | Discussions
averacpa Regular Member • Posts: 219
Going January on a combination south African cruise and 4-day safari at Kruger. In addition, the cruise will have half day tours (approx 5 hrs) to:
  • Botlierskop game Reserve - Mossel Bay port
  • Hluhluwe Game Reserve - Richards Bay port
  • Inkwenkwezi Game Reserve - East London port
  • Pumba Private Game Reserve - Port Elizabeth
  • Nambi desert via off-road vehicles - Walvis Bay port
Bringing my Em-1 and GX7 along with Oly 12-40, 40-150 with TC, Pany 15 f1.7, and 100-300 MkI lenses.
As the EM-5 Mk III won't be out by the time I leave, I am considering getting a used EM-5MkII, GX-8 or Em-1 Mk1. Still considering renting the 100-400 and bringing it in lieu of the 100-300, although my copy is pretty good and I am pleased with its sharpness.
Planning on shooting mainly large animals and carrying the least amount of equipment in term of weight.
Pros for both the EM5 and EM1 is both use the same battery, weather sealing, and similar operations.
I am very reluctant of spending any money on a used EM1, since my camera had the rear dial issue repaired under warranty, but would not be so lucky buying used. Plus there is also the lug issue. Although that would be the best camera in overall terms on having two cameras with the same setup functions. I would going to use the GX7 with the 12-40/15 lenses.
A used EM5 in LN condition is around $570 US and new $800 from KEH. The GX8 is a tad higher in price used, but is weather sealed, has a great EVF and is a range finder like my GX7 which I like. However, the EM% mk II is smaller and lighter than the GX8 if I recall correctly.
As far as the EM-5. I have not found any real issues noted in the forums with it like those found with the EM-1. Maybe I have not searched properly.
Any thoughts on which camera is a good bet buying used?
My concern is used reliability and not having a warranty. Note I don't use my cameras often, perhaps a couple of times a year on trips and some family outing. If it works and meets my needs I hold onto to for quite a while. The third camera is primarily going to be a replacement for the GX7 which I will be giving to my daughter in the near future.
One last note, I am open to other camera bodies in a similar price range of $800 or less., but will have to consider buying additional OEM batteries which could raise the total cost an additional $100.
Olympus E-M1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
Sam in Hawaii Contributing Member • Posts: 500
Re: Buying used EM-5 II vs EM-1
You can get a used EM1 cheaper than an EM5 ii. The difference is significant. The rear dial and strap lug failures are "yets" that might or might not happen. Basically, you're gambling the possibility of one of these failures, neither of which automatically takes the camera out of action (you might adjust your style to not use the rear dial, or you might catch the camera before it hits the ground or notice the loose lug), against a substantially lower price and 100% instant usability in that you won't have to remember which camera you are using, plus whatever advantages, real or perceived the EM1 might have.
I'd go with the second EM1, unless you REALLY want the EM5 ii and are looking for an excuse.
 Sam in Hawaii's gear list:Sam in Hawaii's gear list
Sony RX100 IV Fujifilm X100F Olympus TG-5 Olympus OM-D E-M10 Fujifilm GFX 50R +2 more
Cheshire-Chris Regular Member • Posts: 355
My main camera is an EM1 Mk II. Like you, I’m going on a photographic trip shortly and wanted a backup/secondary camera. I also looked at both the EM1 Mk I and the EM5 Mk II (both secondhand). You can pick up secondhand EM1’s really cheaply now, but in the end I bought a virtual mint (2500 shutter activations) EM5 Mk II and am very happy with it indeed. I wanted a smaller camera, and the EM5 Mk II is very solidly built and I immediately liked it. I’ve had it for a couple of weeks now, and in no way regret my decision. The only recommendation I would make if you buy an EM5 is to get an add-on grip for it, particularly if you’re going to be shooting with longer lenses with it. I bought a cheap Chinese-made grip from Amazon and it’s made the camera much more stable to hold.
Good luck with your decision,
Chris
 Cheshire-Chris's gear list:Cheshire-Chris's gear list
Olympus E-M5 II Olympus E-M1 II Olympus 12-40mm F2.8 Pro Olympus 7-14mm F2.8 Pro Panasonic Leica 100-400mm F4.0-6.3 ASPH +1 more
Architeuthis Regular Member • Posts: 493
Both EM-5 II and EM-1 are almost identical (EM5 smaller, EM1 more sturdy). Since EM5-II is newer it has better video (but still no 4k) and slightly better IBIS. IQ regarding the sensor is practically the same...
I recommend it depends on the offers you get (price/shape of body)...
Wolfgang
 Architeuthis's gear list:Architeuthis's gear list
Olympus E-M1 II Olympus E-M5 II Sony a7R V Canon EF 100mm F2.8L Macro IS USM Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
VideoPic
VideoPic Senior Member • Posts: 1,931
Hello
Great trip you have planned.....
Like most said the EM5 MKII and the EM1 MKI are much the same, EM5 MKII has video, 40MP option image which is great. It has 2 add on grip options, one with shutter button and other without, I found the 2nd great to add just that little extra real estate to the body. Never buy the silver body....silver goes off and really bad for reselling...
Another awesome option is the 20MP Panny GX8. They sell over in the EU new at low prices and 2nd hand at a steal. These are wonderful bodies, huge EVF, IBIS, 4K with great video plus plus.
What is cost of 100-400m rent plus EM5 MKII? Would that buyout a 2nd hand EM1 MKII? They awesome and does not have the problems the MKI had....
Best
Siegfried
See my Blog for short articles on the Olympus and Panasonic cameras.
https://myolympusomd.blogspot.com/
 VideoPic's gear list:VideoPic's gear list
Olympus PEN-F Olympus E-M1 II Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Panasonic 12-35mm F2.8 Panasonic Lumix G X Vario 35-100mm F2.8 OIS +4 more
OP averacpa Regular Member • Posts: 219
VideoPic wrote:
Hello
Best
Siegfried
Hi Siegfried,
The rental cost for the 100-400 for a month is about $400 with insurance plus $575 for a LN used EM5 Mk II for a total cost of around $1000.  Still on the fence of whether I really need to rent the lens.  I know it is the preferred lens for a safari, but my shooting style is to capture the experience which tends towards a wider viewpoint then a tight close up.  I think the 40-150 with the TC will do (especially with larger animals) and I have the 100-300 for when I need a longer reach.
To that end, I rather have 3 camera/lens setups vs trying to switch lenses in the field.
A LN used EM1 Mk II is $1300 from KEH.  But with the Em1 MK II, I would need to buy 2 additional OEM batteries and that would add another $100. (had back luck with 3rd party brands of batteries mainly with expansion and short life).
I was hoping to find out from those who have used the EM5-Mk II is its reliability as compared with the EM1 Mk I. (has the MkII ever had the rear dial or lug issue?)  I really don't like the idea of buying used digital cameras and or lens given the current issues with Panasonic repair program and Olympus issues with the EM-1 camera body.
I have/had camera bodies and lenses from both brands and generally like and use them equally, but I have always bought new with their extended warranty.
TomFid Veteran Member • Posts: 3,999
I would pick the EM5 over the EM1, because it's smaller and has slightly better IBIS. I think it does have a good rep for reliability, just judging by the lack of widespread issues reported here. If you need CAF, your EM1 has that covered. However, I hesitate at the $800 price tag, just because I've seen some nice examples go on ebay for more like $450. Presumably it will take a further beating in value when the Mk III comes out.
I would avoid the GX8 for two reasons: lack of a really good shutter shock solution, and inferior stabilization, particularly with your 100-300.
I'd seriously consider the G80/85, especially if you're taking the 100-400.
Skeeterbytes Forum Pro • Posts: 23,184
Second E-M1 makes better sense, as the physical layout, menus and function will be identical, as will the image files. Since you're presumably shooting wildlife, some in motion the better C-AF and higher frame rates are quite important.
E-M5ii has more effective IBIS and high-res mode. If you're doing landscape with a tripod, hi-res is an attractive feature.
I recommend a dual-sling setup and connecting the cameras at the tripod socket. It's how I shoot sports and keeps the cameras in control and very quick to switch.
Good luck!
Rick
VideoPic
averacpa wrote:
VideoPic wrote:
Hello
Best
Siegfried
Hi Siegfried,
Hello
I used the EM5 MKII for little more than 2 1/2 years and had only joy with it, no issues. I am only aware of EM1 MKI adjustment knobs issue (had it myself + Oly great service) My EM1 MKII has no issues.
Lenses. Agree the 12-40mm plus 40-150mm (I do not have this one) should be OK. Being an ex South African spend much time in Kruger & others.
95% time one see animal on safari drives. These drivers are good and they know how to get photographers to best spots. Hardly ever that one need 600mm or 800mm. Probably up to 90% the 40-150mm with or without converter will be on the camera. Even water hole hide outs are well placed.
If you after birds of which South Africa is great then yes you will need reach.
Walking safaris will require something light & portable - I guess the 40-150mm will be great.
From your OP had the feel you have a EM1 MKI - use it.
In South Africa they have a community at link
These guys specialize - see their forum community (had one in the past) they experts and probably know all the spots you will visit...
Best
Siegfried
Thanks to all for your advice and time.
Only if money was no object...........it would be so easy to decide.
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
Since dpreview says you live in the USA, another thought is rather than regular used body from places like KEH.COM is to get a reconditioned E-m5 mark II from the Olympus Outlet store.  That comes with a 90 day warranty, but you can buy an extended warranty within the 90 days, and it will cover two years after the regular 90 warranty goes out.
Note, with the USA Thanksgiving and Black Friday sales going on, Olympus has no refurbished cameras in the outlet.  But I imagine the outlet will be restocked next week.
Note, while the E-m5 mark II and the E-m1 share the same battery (BLN-1), they do not share the same clip-on flash (FL-LM2 vs. FL-LM3), but that is probably a minor deal.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Just ordered the (LN condition) EM5 MkII with battery and charger from KEH.  They have a 15% discount today making the price with free shipping and a 365 extended day warranty for $486.  Could not resist the deal....
Good for you! I recently bought a "mint condition" second-hand EM5 Mk II as a backup for my EM1 Mk II. Lovely camera.
Chris
VideoPic
Pleasure......
When I used the EM5 MKI my wife had the EM10 MKII. She now has the MKIII.
Well I kept the MKII....will sell it but I wanted to study it first to write something on it. Today I took it out to do comparison images and immediately I knew why it's still with me. It's "tiny" and its nearly identical t the EM5 MKII. At the time she got it I thought why would I need the EM5 MKII?
Over here the EM10 MKII sells for very little 2nd hand. Plus is can do 120FPS at 720P not bad at all..... The movie functions in the EM10 MKII is interesting.
All the best
VideoPic
Congrats great camera......will you get the small version handgrip? Get one or two spare batteries...... Study using the 40MP function, early mornings/evenings on water scenes....brilliant...
One more...study practice stars...how to photograph with the EM5. South Africa has some of the most amazing night scenes.....
ivanj05 Forum Member • Posts: 96
Congrats on your purchase! I love my EM5 mk2, its such a handy little camera.
 ivanj05's gear list:ivanj05's gear list
Nikon Coolpix S3100 Olympus PEN E-PL1 Olympus PEN E-PM2 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +5 more
Thanks to all.....happy holidays.
Andrew
Steveus Forum Member • Posts: 84
averacpa wrote:
Just ordered the (LN condition) EM5 MkII...
Darn, I was away for the weekend else I would have seen this thread and warned you off the EM5ii.  I bought my Em5ii used and have had two major issues with it which many other folks have had as well.  First was a broken rear LCD screen; it just stopped working one day.  Second was a broken on/off switch.
Both are major issues, but you can still use the camera in a significantly handicapped sort of way.  With the broken LCD, you can at least still use the viewfinder, thought you'll want to go into the menus to disable LCD/EVF switching.  You'll know if your LCD is going to break if there isn't a "hard stop" on its rotation.  That is, if you can keep spinning the LCD screen the same direction more than 360 degrees.  Unless you religiously track which way you've rotated it and always reverse it when putting it away, you will eventually twist the ribbon connector inside until it breaks.  If the hard stop on your rotation is working, this shouldn't be a problem for you.
The broken on/off switch is a more common issue, but at least it breaks in the "on" position.  So you have to pull your battery out frequently to turn the camera off.  Which is unfortunate because it makes you miss shots, or if you leave the battery in all day you will need a ton of extra batteries.  Also, when you yank the battery your settings may not be as you left them, so you have to be careful to check things like auto ISO each time you put the battery back in.
Probably you won't have either of these issues, but at least now you're prepared for them just in case.  Look at my post history and you'll find the relevant threads.
Every camera has weaknesses. If the OP had gone for the EM1 there would probably have been people warning him about strap lug failures and broken rear dials . As you say, these "common" faults are actually not experienced by 99.9% of owners.
Chris
I didn't mean to offend; I was just providing actionable information specifically requested by the OP, who was already aware of the EM-I flaws but not aware of the EM-5ii flaws.
