Seafrogs / Meikon pistol housing finally released fir A7iii/A7riii
Started Nov 20, 2018 | Discussions
(unknown member) Senior Member • Posts: 2,383
Sony a7
joel avery
joel avery Senior Member • Posts: 1,704
Re: Seafrogs / Meikon pistol housing finally released fir A7iii/A7riii
 joel avery's gear list:joel avery's gear list
Sony RX100 II Sony Alpha DSLR-A700 Sony SLT-A77 Sony Alpha a99 Sony a7R II +8 more
theoverratedphotog
theoverratedphotog Senior Member • Posts: 1,259
Mine arrived today. Pretty happy with it.
 theoverratedphotog's gear list:theoverratedphotog's gear list
Fujifilm X100V Sony a7R III Sony a7 III Sony FE 35mm F2.8 Sony FE 55mm F1.8 +11 more
Aquadrone
Aquadrone Forum Member • Posts: 85
It is back in stock!
 Aquadrone's gear list:Aquadrone's gear list
Sony RX100 III Sony RX100 IV Olympus TG-5 Sony RX100 VI Sony RX100 VA +15 more
Kyle Bultman New Member • Posts: 1
Can you please tell me if the Tamron 28-75mm lens fit in the standard SeaFrogs port?  I am about to buy this housing, but I need to make sure I have a lens that will work with it.  Is the length of the lens the only thing that matters here?   I have a Rokinon 35mm AF that I would love to take underwater too because it's so freaking sharp.
Barmaglot_07 Contributing Member • Posts: 633
Regardless of fit, getting the zoom to work will be a challenge - Tamron 28-70mm has the zoom ring up front, and SeaFrogs zoom gear is located inside the housing. You might need to mod the port, similar to daveco2 here.
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
AlfredC New Member • Posts: 2
Does anyone know if SeaFrog’s underwater housing are reputable and do not leak ? I am considering buying one for my a7iii and also if the housing would be able to zoom underwater  with the 16-35 F2.8 GM ?
Any housing can leak, but Meikon's latest housings, including the one for A7 III series, feature a vacuum port. Using a vacuum system (sold separately) significantly reduces the chances of a leak or a flood. I haven't had any issues with mine so far.
Regarding zoom - the only zoom gear they offer is for 28-70mm kit lens. With 16-35mm f/2.8 you'll have to either make your own zoom gear, or select focal length before sealing the housing, or use a different housing - Nauticam offers full support of that system, but costs in excess of $5k.
Ash Bowes New Member • Posts: 1
Hi Kyle, were you able to find an answer to weather the standard SeaFrogs port fits the Tamron 28-75mm lens? I am currently considering underwater housing options. Thanks in advance!
theoverratedphotog
No, it doesn’t fit in the standard port if I remember correctly. I’m pretty sure I tried. I sold my 28-75 though so can no longer confirm.
Aquadrone
There is a Google spreadsheet now available under product description to see the compatible lenses and ports.
