Flash gun puzzle Oly v Pana
Started Nov 17, 2018 | Discussions
rambling robin
rambling robin Senior Member • Posts: 1,196
Some months back I sold all my E-volt kit and for some reason included my Oly FL36 flash.
I never used it on my Panasonic G2 / G7 so have no idea whether it would function correctly.
As far as I can tell from reading assorted threads, the Oly FL36 and the Pana 360 are the same. So, please can anyone confirm (or deny) that the Oly FL36 will provide full TTL on a Panasonic m43 body?
I know it's old technology but it's only used inside churches or similar and not that often.
Thank you.
 rambling robin's gear list:rambling robin's gear list
Nikon Coolpix P7100 Fujifilm FinePix S3 Pro Fujifilm FinePix S5 Pro Nikon D100
Panasonic Lumix DMC-G2 Panasonic Lumix DMC-G7
lathspell
lathspell Regular Member • Posts: 121
Re: Flash gun puzzle Oly v Pana
My FL-36R is fully* functional on my GX8, so the FL-36 should also work.
(*Only the red focus assistant light doesn't work.)
 lathspell's gear list:lathspell's gear list
Panasonic Lumix DMC-GX8 Silkypix Developer Studio Pro
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
In a similar but more confused vein, I used to use  same vintage Olympus FL-50 (not the R type) on Panasonic LX3 for a top heavy but useful TTL performance. Also used FL-36R and FL-300R on LX3.
Basically any reasonably modern (last maybe 10 years?) Panasonic/Olympus/Leica camera with a hot-shoe can play TTL nicely with any flash that is deemed "Olympus/Panasonic/Leica/Micro Four Thirds/Four Thirds" compatible.
Regards..... Guy
Skeeterbytes Forum Pro • Posts: 23,186
The TTL features still work. The camera won't access the flash's AF illuminator and I believe Panny won't support Oly's multi-flash system.
Still a viable flash.
Rick
john isaacs Veteran Member • Posts: 8,444
Rick
Panasonic does support multi flash RC control.
There is a slight difference between Olympus and Panasonic, and so Quantum and Pocketwizard support Panasonic but not Olympus.
JakeJY Veteran Member • Posts: 5,442
Thank you.
The accessories compatibility pages for both cameras show support for FL-36 (go down the the "External Flash" section):
http://av.jpn.support.panasonic.com/support/global/cs/dsc/connect/g2.html
http://av.jpn.support.panasonic.com/support/global/cs/dsc/connect/g7.html
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
rambling robin
OP rambling robin Senior Member • Posts: 1,196
Great info - thank you one and all. Interesting about the focus light...........
Mfr web site provides useful information - who knew
Should have checked, shouldn't I?   DOH!
