Re: King 7S 3D phone on sale!
OK, I have done quite a bit of testing on the King 7S. I am reworking some my old left and right movie files to produce the required 3d output - it takes quite a bit of time.
Here are some results
Using the built-in app '3D Center' and selecting its 3D player.
At no time did the playing of any of the video clip ( side by side, 1/2 size ), listed below did the action stutter - it played nice and soothly. This was for the following video specs
1920x1080 29.97fps 21Mbps h264 .mp4 file
1920x1080 59.94fps 20.5Mbps h264 .mp4 file
1920x1080 59.94fps 20Mbps h265 .mp4 file
3840x2160 29.94fps 120Mbps h264 .mp4 file
3840x2160 29.94fps 40Mbps h265 .mp4 file
I have had not much luck with installed apps from 'Google play ' such as sView media player ( version 17.10 )
On 2d clips it is not playing smoothly on 4K clips.
On 3d side by side 1/2 size clips the 3d images is not working properly - it sort of half works - there is a vertical split in the image and the 3d is different on one side of the split to the other.
The app 'Stereoscope' version 1.5.4 will convert the side by side , 1/2 size image to anaglyth but i don't know if it can make it 'glasses free' 3d.
I think the King 7S is excellent for show 3d movie clips. The quality is amazing.
I'm certain that 4k produces a significant sharper image than 1080p.
I measured using a macro lens on my camera the pitch of the vertical lines on the lenticular display as 10 lines per mm.
The display is 133mm wide , so there are in total 1330 lines - 665 for left side and 665 for right side images.
For a 1920x1080 pixel image, the squashed right and left images will both have 960 pixels. So I guess the player in the King 7S will map the 960 pixels to the 665 vertial lines of lenses in the Lenticular display.
