32mm f/1.4 - people, cats & food (PICS)
Started Nov 12, 2018 | Discussions
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
27
32mm f/1.4 lens
A few handheld JPEGs taken using the new EF-M 32mm f/1.4 STM lens. Most were taken in the city yesterday but there's a few from Halloween.   The lens is still performing well at f/1.4 and is decently sharp at all apertures. It's small enough that I've carried it on my camera in my hand to a Broadway production and several Cinemas without anyone batting an eyelid.
I didn't bother to detach the UV filter on my lens and simply double-stacked the CPL filter over the top when needed.   Focus wasn't affected and it saved me juggling filters while walking.  Surprisingly the portrait shots (including the one above) were candids ...which were shot in bursts. I simply selected the image from each set that was most appealing.  I applied some Noise Reduction to the last shot of my black Cat - which was taken at night in indirect lighting.  I don't think I used a flash for any of these.
32mm f/1.4 lens - [43mm Hoya FUSION/EVO CPL Filter used]
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
Miguel-C
Miguel-C Senior Member • Posts: 2,321
Re: 32mm f/1.4 - people, cats & food (PICS)
Amazing Shots! love the colors and crispness
 Miguel-C's gear list:Miguel-C's gear list
Fujifilm X-T2 Canon EOS M5 Panasonic Lumix DC-S5 Canon EF-M 11-22mm f/4-5.6 IS STM Fujifilm XF 35mm F2 R WR +3 more
jaadwa Regular Member • Posts: 351
Great, as usual ...
----Daniel----
 jaadwa's gear list:jaadwa's gear list
Canon EOS M6 Sony a7 III Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM Sony FE 55mm F1.8 +11 more
robbert100 Contributing Member • Posts: 714
Great pictures Marco!
never saw a picture from the opera house from that side. Is it always so crowded over there? (I’ve never been to Australia)
Best regards,
Rob
www.namaqualand.wordpress.com
 robbert100's gear list:robbert100's gear list
Canon EOS M Canon EOS 7D Mark II Canon EOS M10 Canon EOS 5D Mark IV Canon EF 100mm F2.8L Macro IS USM +2 more
Scott Milso Senior Member • Posts: 1,099
Marco Nero wrote:
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
Great shots!! It's nice to see what that lens can do.
Only nit is the skin tones in the 1st photo seem a little bit off.
Marco Nero
OP Marco Nero Veteran Member • Posts: 7,582
to: Miguel-C ...working with this lens - (PICS)
Thanks Miguel-C.  Not every shot is perfect although I'm used to working with fast lenses and composing with a very shallow DOF. Sometimes you expect a shot to come out a little better than it does ...and sometimes you get an image that looks a little nicer than you anticipated. The angle is usually important when shooting up close. I think it's just fun to take pictures and sort them out later to see what your results are. Obviously you'd plan your shots more carefully if you were photographing something important but composition plays an important role in what the results will likely be.
The light in the scene is always important - alongside composition. And those two elements play an important role in getting the best results from this particular lens.  it's not hard to take a picture with f/1.4 and end up with one eye out of focus on the subject (although f/1.2 is usually far less forgiving... in relation to other lenses).
Some of the "Reject Shots" below that didn't quite make it ...
32mm f/1.4 lens - a bad angle
32mm f/1.4 lens
32mm f/1.4 lens - this one was a little over-ripe.
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
Marco Nero.
James K Cheung Contributing Member • Posts: 684
These are good and convincing shots.Thanks for sharing.
I might be tempted to buy one even though I was mounting my 85mm 1.4 for bokeh.
Jim
Photographers cherish the environment.
 James K Cheung's gear list:James K Cheung's gear list
Canon EOS M50 Canon EF-M 22mm f/2 STM Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM +3 more
Marco Nero
Robert100 - re: Sydney Opera House (PICS)
EOS 6D + EF 100-400mm II lens - panorama - taken from Taronga Zoo last year.
Hi Robert100 - The Sydney Opera House is usually busy but not all the time... usually around midday it has a lot of visitors and tourists and it does look quite different from different angles.  New Year's Eve is perhaps the busiest time to be near this building.  I find it gets quieter as the sun sets.  But it's a fascinating place to sit at any time of the day or night.  One of the best times to see it is just after sunset when the internal lights start to come on... around 30 minutes after the sun has set. The Opera House is also a good spot to photograph the Sydney Harbor Bridge from at sunset. If you ever find yourself coming to Sydney, let me know and I'll pinpoint some great locations to capture it from. Some of the best vantage points to shoot from are from hidden stairwells and garden mounds in the Botanical Gardens and others are from locations on the other side of the harbor.
It's perhaps a tricky subject because the building is designed in quite an intricate manner. There's lighting projected onto the building at night and if you capture it before sunrise or just after sunset the silhouette against the sky can be interesting. It's in one of the busiest areas of the city so there's always a lot of people trying to take pictures of it.  Even though I live here, I don't seem to have gone out of my way to photograph the Sydney Opera House so the pictures below were taken when passing by with various cameras.  I often see serious photographers setting up tripods etc to try to capture the building in various weather conditions and it's certainly popular with the visitors.
PowerShot G1X - (CPL filter used)
EOS M + EF 24mm f/1.4L II lens
PowerShot Pro1
PowerShot s95
There's a few here from the EF-M 32mm f/1.4 STM lens (below) that were taken over the last couple of weeks - while I was testing the lens to so how it performed.  The 50mm (equiv) focal length is a little harder to work with up close since it's not a particularly wide lens but if you shoot from more distant locations you can usually get nice results with the wider view.  Every angle of the building offers a unique view.
32mm f/1.4 lens - (CPL filter used)
32mm f/1.4 lens - panorama - (CPL filter used)
Marco Nero.
fstopx2 Senior Member • Posts: 1,088
Nice pictures, great job! The last pic with the black cat is amazing!
Marco Nero
To: fstopx2 - Re: Black Cat (PICS)
I took a few different pictures of my black cat 'Quorra' that night.  She's tolerant of me taking her picture and I try not to shine bright lights in her face.  Her eyes are both green and blue although if they are very narrow (in bright sunlight) they look yellow-green.  Depending on how wide the pupils are, they sometimes appear very bright blue-green... like opals.  In the past, with other cameras, I've had great success capturing her with a bounced flash or even a remotely triggered flash.  I might have to try an external flash with this lens to see what the results are like.  Below are four of the images I took the other night (the first one was in the original post).
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens - taken using my wife's cellphone for illumination
32mm f/1.4 lens - pop-up flash used (bounced  off the ceiling)
Marco Nero.
immortalstrong Junior Member • Posts: 25
Extremely lovely pictures!
Marco Nero wrote:
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
32mm f/1.4 lens
 immortalstrong's gear list:immortalstrong's gear list
Canon EOS M100 Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF 50mm F1.8 STM Canon EF-M 15-45mm F3.5-6.3 IS STM
24thWanderer
24thWanderer Regular Member • Posts: 228
Nice captures. This thread is a compelling case for getting one of these lens.
 24thWanderer's gear list:24thWanderer's gear list
Canon EOS Rebel T7 Canon EOS RP Canon EF 17-40mm f/4.0L USM Tamron SP 45mm F1.8 Di VC USD Tamron SP 90mm F2.8 Di VC USD Macro +1 more
Dave Seeley Senior Member • Posts: 1,760
very impressive set of pics...   !
pro photo-illustration - check my website via my profile
 Dave Seeley's gear list:Dave Seeley's gear list
Canon EOS 5DS R Canon EOS R Canon EOS R5 Canon EF 50mm f/1.2L USM Canon EF 70-200mm F2.8L IS II USM +8 more
RLBur
MOD RLBur Veteran Member • Posts: 5,551
Great photos!  Love the color.
Randy
 RLBur's gear list:RLBur's gear list
Canon PowerShot A640 Canon PowerShot G1 X Canon PowerShot S120 Canon PowerShot G7 X Olympus PEN E-PL1 +10 more
huyvnphan
huyvnphan Forum Member • Posts: 62
Re: To: fstopx2 - Re: Black Cat (PICS)
Sharp? Yes
But sorry I don’t want to spend $450 on a no IS prime lens.
Either give us an IBIS body or lenses with IS Canon.
Even my $500 iPhone has OIS in it
 huyvnphan's gear list:huyvnphan's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Apple iPhone X
huyvnphan wrote:
Sharp? Yes
At f/1.4 you can probably hand hold it with better results than your stabalized iPhone .
And the high ISO capability of the modern aps sensor you don't need IS with a 32mm f/1.4
huyvnphan
Scott Milso wrote:
huyvnphan wrote:
Sharp? Yes
For photos maybe. However, my iPhone videos come out more stable than my Canon M50 with 22mm F/2.0 lens. That's just stupid, but the regarding the $150 cost of the lens, I can stand the lack of IS. For $450 of the 32mm. I just can't .
I was waiting for the M5 mark II to have IBIS, but when the EOR R with out IBIS there is no chance Canon with put IBIS in M5 II
EricJB
EricJB Regular Member • Posts: 109
I continue to be pleasantly surprised with my 32 so far...  Here are a couple of examples, all shot handheld, and except for the bridge shot, all were wide open.  EOS M5 and ISO 100.
 EricJB's gear list:EricJB's gear list
Canon PowerShot G3 Nikon Coolpix P7800 Canon EOS 20D Canon EOS 60D Canon EOS 6D +34 more
Marco Nero
Re: iPhone problems + OIS + Comparisons (PICS)
Scott Milso wrote:
huyvnphan wrote:
Sharp? Yes
You do yourself a great disservice by turning down a lens just because it has no Image Stabilizer.  It makes some sense with longer focal lengths and smaller sensors but NOT when you're dealing with a 32mm lens at f/1.4 on an APS-C sensor. Some of my finest shots have come from various non-IS lenses. I paid AUD $2800 for my 85mm f/1.2L lens and about AUD $2,500 for the f/1.2L 50mm lens. I'm pretty sure I paid about AUD $2400 for the 24mm f/1.4L lens. I don't often shoot in virtual darkness handheld although I have two examples below.
When the new 85mm f/1.4L lens was released recently, critics were quick to note that there was no obvious advantage in the slower aperture with the addition of a new Image Stabilizer. Especially since there was no improvement with CA on this very expensive new lens (which retails here now for over $2,000+).
EOS 6D + EF 85mm f/1.2L USM II lens - Taken at 1/160 second with plenty of shutter speed to spare. No Image Stabilizer required. The advantage of a Full Frame sensor and a fast f/1.2 lens made easy work of this shot on my wife heading home after dinner alongside a beach at night. The illumination comes from street lights across the road. This was taken at ISO 1600 - with plenty of ISO to spare as well. Image Stabilization was entirely unnecessary.
EOS M + EF-M 22mm f/2 STM lens - Taken on a street at night. No IS needed.* ISO 1600 | 22mm | 1/100 sec | f/2
Canon states IBIS is inferior because it affects exposure, color and image quality. Faster glass is literally better. You can't tell a person, animal or vehicle to sit still while your image stabilizer compensates for a lack of light. You'll get a blurred subject if it's moving. The iPhone, even with its OIS on recent models, suffers horrendously from this issue.
You've either bought an Apple 6S+ or something more recent.  The 8 has a good camera.  The X is meant to be even better but we now know that's not entirely true.  If you want something that comes CLOSE to what a modern DSLR or Mirrorless camera can do, you really need to look at a much more expensive model. And even then, low-light performance is still a serious problem. Apple compensates by applying very destructive noise-reduction and faking the shallow DOF effect using an algorithm that is too stupid to evaluate many scenes (see examples below).  You'll need to use the HDR settings to come closer to the results of a decent APS-C camera+lens combo and if you do, you're then approaching the realm of artistic expression instead of scenic reproduction. Apple couldn't even offer OIS on the iPhone 6S although they did offer it on the much larger and more expensive 6S+ model that was released at the same time. I'm sorry but they don't really make shirt pockets that fit that larger size of phone... so I bought the 6S instead.  As recent as August 22, 2018, websites were still comparing the iPhone 6 model with point-and-shoot cameras.  You can see the difference and comparisons they used for entertainment purposes right HERE: https://wjla.com/features/7-on-your-side/7oys-point-and-shoot-vs-cell-phone-cameras
I don't like the iPhone performance in lowlight and that also applies to the most recent models.  There are better alternatives available (eg Google's PIXEL).
With the focal length of this lens, 1/60 sec is perhaps the safe 'average' speed for handholding but 1/40 is simple if you have steady hands - although my personal safe speed with this lens is 1/80 since sometimes shake the camera when taking multi-shots. With the 85mm f/1.2L (even on a FF DSLR) I need to use a minimum shutter speed of 1/100 sec to be sure since movement becomes much more pronounced at 85mm. The amazing Image Stabilization on the more expensive White L-series lenses
Apple claims it has the BEST phone-camera on the market today.  But has anyone heard of the new iPhone XS problem called "Beautygate"?  Here you go... it's rendering people's faces as though they're wearing foundation and blurring the texture of the skin to hide pores and imperfections.  https://www.cultofmac.com/579942/beautygate-iphone-xs-selfies/  Apples is looking into fixing this... presumably with an update.  it's essentially a super-aggressive noise-reduction setting but it can't be altered, turned off or reduced.  It's horrible. It also increases the color of the face and alters the exposure method. Why can't this be turned off?
I tend to agree.  Let's take a look at the difference between my relatively modern iPhone6S camera (which was hailed as a 'Camera-Killer' and "... one of the best digital cameras on a mobile cell-phone available..." at the time of release. Sure, the iPhone7 wasn't an improvement but the 8 is. Now there's the X model... but an iPhone XS Max with 256GB of memory is AUD $2,369.00 (AUD 2,199 for the R model). You're going to pay through the nose for the privilege of using a modern phone-camera with all sorts of problems such as "Ghost Touch" and having to unlock your "camera" with your face. If you want to find a way, you might even find a 3rd party tool for fitting some kind of Circular Polarizer to your iPhone XS. But it takes a better picture and it's only now on sale from Apple seller. Since Apple releases a new model every year (sometimes two!) your device will be redundant the moment you buy it. I bought my iPhone to use as a phone. In daylight it takes a decent picture. But until I see better cameras I'm not interested in "upgrading". The new X models are still no match for a modern mirrorless camera, even one with APS-C.
iPhone Cameras are slowly improving
I just took the pictures below of my cat Zima while responding to these thread comments. I want to you pay attention to the difference in performance from the both cameras. Neither lens nor iPhone camera has Optical Image Stabilization. The iPhone cranks up the ISO to allow the camera to perform in lowlight conditions and the details are terribly smeared as a result. The colors suffer under artificial lighting as well. So I tried taking a picture with the light ON and then took several more with the light OFF before taking a shot with the EOS M6 and the 32mm f/1.4 STM lens.
iPhone - Be sure to look closer at this image. Observe the lack of detail and smeared image structure plus coarse noise.
Here's a comparison I made just now.. Apart from resizing, no editing at all was performed. The iPhone was a awful in low light....
* It didn't focus and Shot 1 is completely out of focus. Even with the light ON.
* It couldn't focus quickly enough. Subject moved during focus adjustment.
* The subject moved during the 2nd exposure
* The colors were awful and did not represent the actual colors.
EOS M6 + EF-M 32mm f/1.4 STM lens. No Flash, handheld JPEG with no light on in the room.The only illumination in the room was from my television.This image has now been tweaked for exposure and noise before resizing.
Handheld JPEG taken at - f/1.4 | 1/40 sec  |  ISO 2500
Lack of image stabilization is normal on most of Canon's faster lenses. That's because it's not really necessary. I took the shot of my Cat at 1/40 second at ISO 2500 with a wide open f/1.4 aperture. The noise was minor and easily corrected. The colors were accurate and I took a short burst of three shots just to ensure stability. I could have used a slower shutter speed or even a higher one.
Shallow DOF:
The benefit of a fast lens with a wide aperture is greater presence of shallow DOF... something that really helps to isolate a subject against any background. Whilst the new iPhones are great at FAKING bokeh, they're also very well known for screwing it up...
A nice Fake Bokeh from a modern iPhone ... with serious problems concerning its software algorithm for diffusing backgrounds and generating fake Bokeh.
"Bad Bokeh" - allegedly from the new iPhone XR model.
Lens Brightness and Sensor Size
The big deal about the 32mm f/1.4 STM lens is that it's cheap (although from the comment above it's clear some people think that this paltry price is too much). But it's an important lens because it's so incredibly SHARP.  Sensor Size is important if you want to capture specific results.  The aperture available is also important.  Image Stabilization is not, especially when using fast glass and not too long a lens.  As you can see from the images below, the combination of aperture and sensor size produces differences that are world apart in terms of visual impact and appeal.  (the images below were taken at my local cinema one evening).
PowerShot S95 - f/2 | ISO 1000 |  1/125 sec
6D + EF 85mm f/1.2L USM II - f/1.2 | ISO 400 | 1/160 sec
A Phone-Camera (eg iPhone) is a very handy tool to have.  Most people have their phone at hand when needed.  It takes a better picture than many (most) compact cameras.  But it doesn't replace a DSLR or a Mirrorless camera and I can't see it doing so while the sensors and batteries remain small and the trend of making phones thinner and lighter continues.  The only time an iPhone can perform best is in bright light. In lowlight it's forced to take multiple exposures and then averages out the noise and exposure data whilst still using very aggressive noise reduction software.  The results are often mixed.  I prefer the results from lenses like this new 32mm f/1.4 lens over anything my iPhone can take.  And until Apple can sort out their image problems with the latest iPhoneXS I'm not likely to bother updating.
EF-M 32mm f/1.4 STM lens  - bokeh + detail + exposure + sharpness example
Marco Nero.
huyvnphan
Marco Nero wrote:
Scott Milso wrote:
huyvnphan wrote:
Sharp? Yes
Thank you for your inputs Marco. I agree with you that the iPhone is still inferior to an APSC camera. However, for taking video, stablization is much more important, and there is no excuse not to put IBIS into any modern camera at the moment.
Because Canon states IBIS is inferior doesn't mean it's true. I think it's a lame excuse from their R&D deparment.
Sony did it 3 years ago, Nikon did it with their Z7, Panasonic did it, Fuji did it. Canon is the one left out. None of those cameras suffer from any noticeable downgrade in IQ.
I'm pretty sure Canon will put IBIS in their EOS R2. This stragery is not new. Apple used it a thousand times. Convincing their customers they don't need a particular function, then add it in future interation.
Yes I agree. The shallow DOF simualted by software is a joke.
OIS is the standard for any iPhones since iPhone 7 (‎released in September 2016)
The OIS of iPhone allows much slower shutter speed, hence improving IQ during low light and smooth out videos.
I bought the M50 to completely replace my iPhone in taking photos and videos. The M50 still cannot beat iPhone at taking videos at the moment because of laking of IBIS and 1080p 120fps (I don't really mind 4K).
The point I'm trying to make: There is no excuses for Canon not to put IBIS in their cameras.
