G7 good enough or G85
Started Nov 11, 2018 | Discussions
Mwh624 New Member • Posts: 21
Looking to add a 4/3 camera to my collection. It will mainly be used for 4K video.
Leaning heavily towards a G85 but with the price of the G7, curious how much of a difference there is between the two?  How do the low light 4k performances compare? Is the G85 significantly better than the G7 when on a tripod?
Thanks for the input.
Panasonic G85 Panasonic Lumix DMC-G7
G Rash Senior Member • Posts: 2,890
Re: G7 good enough or G85
Probably not much difference on a tripod.  But I sold my G7 and have a G85 arriving soon so I can "loan" it to my son and get my G9 back.  The weather proofing and IBIS are nice additions.  I snagged one on Greentoe for a good price.  I had to wait a few days and turn down a counter offer, but eventually I got the G85 kit with 12-60 for $700.
Gary
 G Rash's gear list:G Rash's gear list
Olympus PEN-F Sony a7R III Canon EOS R5 Nikon D610 Panasonic Lumix DMC-GX8 +3 more
Chris Noble
Chris Noble Veteran Member • Posts: 5,191
G7 vs. G85
7
The G7 has shutter-shock (I've observed it in mine); the G85 shutter is significantly improved, + it has IBIS.
 Chris Noble's gear list:Chris Noble's gear list
Panasonic Lumix DMC-GM5 Panasonic Lumix DC-GX9 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Lumix G 20mm F1.7 ASPH Panasonic Leica Summilux DG 25mm F1.4 +3 more
johnpatrickbishop Regular Member • Posts: 276
I recently faced the same dilemma
I was buying my first M4/3 camera and was looking at G7 or G85. I researched obsessively and ultimately decided to save some money and go with the G7 (about $500 on sale) and an extra lens. Here's the thing... The G7 is probably good enough for your needs. But I wish I had dropped the extra $300 and just gone with the G85.
 johnpatrickbishop's gear list:johnpatrickbishop's gear list
Ricoh GR II Panasonic G85 Panasonic GH5 Nikon Z6
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
the g85 is a better camera and has better stuff for lower light.
the best feature is the limitless recording vs the g7.
it all depends on your budget and needs though.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
Mark Kaprielian
Mark Kaprielian Regular Member • Posts: 400
Hi
The G7 does not have in body IS.
Many of the primes do not have IS
If you will always be on a tripod that is very stable then having either one on a tripod will be extremely close to the to other in appearance for video, if you take into account that the G85 does not have an AA filter but the G7 does.
If you are ever going to walk with the camera the IS capabilities of the G85 will be much better than that of the G7 regardless of IS in the lens or not.
Mark
 Mark Kaprielian's gear list:Mark Kaprielian's gear list
Panasonic Lumix DMC-G7 Panasonic G85 Panasonic Lumix DC-GH6 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS +9 more
Son of Thunder
Son of Thunder Contributing Member • Posts: 899
I have a G7 and on image quality they are just about equal. the G85 has more features ibis 2more fps unlimited record time and no AA filter I believe, plus you can add a battery grip. Now if that is worth 300 more dollars you can decide. one more thing weather sealing on G85. I got mine on black Friday on special 2years ago for 399 and the G85 was a 1000 so no way was it 600 dollar better to me but now at 300 the choice is yours
 Son of Thunder's gear list:Son of Thunder's gear list
Canon EOS 6D Canon EOS 80D Panasonic Lumix DC-G9 Canon EOS M50 Fujifilm X-T3 +18 more
Badwater Senior Member • Posts: 2,095
It depends on if it's going to be your primary camera.  If so, I would go with the G85 for the IBIS advantage, and the better ISO and sensor performance.  G7 was a great camera and still is significant today, but the upgrades in the G85 IME is worth the extra cash.  Once you use the touch focus and IBIS, you'll realize just how important that is for 4K video.  The G85 can hand hold 4K video with smooth camera movement,  while the G7 can't.  That right there will allow you run and gun ability over a tripod stationary camera.
However, if the 4:3 is going to be your B camera or everyday carry and not your primary camera, I would look into the GX85 with 2 lens kit.  That camera is IME the best bang for the buck camera you can get.  Video quality wise and stabilizatio wise it's the same as G85 and beats the G7.   But the GX85  has no mic and headphone jacks, and not weather sealed.
Nevertheless, if you're going to 4:3, get one that will suit your style of video.
photofan1986
photofan1986 Veteran Member • Posts: 3,841
In the m43 world, there are many new models I consider as mere refreshes, and only a few I consider real upgrades. The G85 is most definitely one of the latter.
Better body, better EVF, IBIS (a game changer), new shutter (game changer as well), and other bells and whistles. So for me, it's a no brainer.
 photofan1986's gear list:photofan1986's gear list
Fujifilm FinePix F200EXR Panasonic Lumix DMC-GM5 Sony a7R III Olympus E-M5 III Panasonic Lumix G 20mm F1.7 ASPH +15 more
rambling robin
rambling robin Senior Member • Posts: 1,196
Re: G7 vs. G85
I'm sure you know this already, but with the latest firmware there is an option to set the camera to use E shutter on an automatic basis. If you are straying into S/S parameters it will engage E shutter. So far I have not seen any shock on my G7 - but I know from experience it is variable from rig to rig/shot to shot.
For sure an IBIS body is a major advantage and makes lens choice more flexible.
 rambling robin's gear list:rambling robin's gear list
Nikon Coolpix P7100 Fujifilm FinePix S3 Pro Fujifilm FinePix S5 Pro Nikon D100
Terminal Boy Senior Member • Posts: 1,292
I never thought I’d replace my G7 as it did exactly what I wanted in a mini-DSLR and I was delighted with the images I captured with it.
And then the dastardly rotters at Panasonic released the G85 for an entirely reasonable price.
Weather sealing, IBIS, Dual IS, no AA filter on sensor (which may or may not improve detail),  magnesium body and the improved shutter.
Which made it an easy decision for me, but I can’t say I’ve noticed any difference between the G7 and the G85 as far as stills performance when tripod mounted.
 Terminal Boy's gear list:Terminal Boy's gear list
Panasonic Lumix DMC-GM5 Panasonic G85 Panasonic Lumix G Vario 7-14mm F4 ASPH Panasonic 12-35mm F2.8 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +2 more
Chris Noble
Re: G7 vs. G85 shutter
Yes, but E-shutter is useless if there is motion in the frame or when using flash. And the G7 E-shutter mode is only 10 bits. The G85 E-shutter mode is a full 12 bits (like the mechanical shutter mode in both cameras).
For me, it was very noticeable with my 14-140 lens.
OP Mwh624 New Member • Posts: 21
Re: G7 vs. G85
G85 it is.  Weather sealed will be nice and having the IBIS opens up a few more doors for what I'll be able to do  with the camera
Thanks for the input!
Chris Noble
Temptation....
Have you looked at the G9?........
Astrotripper Veteran Member • Posts: 8,676
G85
There are three major improvements to G85 vs G7:
  1. shock-free mechanical shutter
  2. IBIS
  3. weather resistance
IBIS is a pretty big deal if you're interested in shooting video but don't want to work on tripod or stabilizer rig.
Also, the G85 with the 12-60 is a very versatile kit with a solid lens. I would say that it's worth the difference in price, especially if you want to use it for handheld video.
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
photofan1986
Are you sure of that? I certainly notice increased noise in the shadows when using E shutter. I would have bet it is only 10 bits.
Albert Valentino Veteran Member • Posts: 9,770
Re: G7 vs. G85
Good choice. Should be able to get a good deal on black friday
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 25mm F1.8 +10 more
davidedric Veteran Member • Posts: 7,339
I have both.  Used for video, I think the stabilised video on the G85 is invaluable for hand held.  Haven't done video on a tripod.
Dave
 davidedric's gear list:davidedric's gear list
Sony RX100 VII Panasonic Lumix DMC-G5 Panasonic Lumix DMC-G7 Panasonic G85 Panasonic 12-35mm F2.8 +3 more
Chris Noble
e-shutter Raw files
I read that it was 12 bits -- I don't have a G85. Look at a Raw file on RawDigger and you can see where the missing codes start.
My G7 definitely had 10-bit e-shutter Raw files. My G9 is 12-bit.
Re: Temptation....
If only $ didn't factor into the decision
But then I'd probably end up with an A7s ii
