How do I lock the focus on an M100 ?
Started Nov 7, 2018 | Discussions
mangurian Senior Member • Posts: 1,187
Is there a way to focus on an object and then keep that same focus distance for subsequent photos ?
Canon EOS M100
DevilsCry
DevilsCry Forum Member • Posts: 90
Re: How do I lock the focus on an M100 ?
After clicking a photo, don't fully release your shutter button. Keep it half pressed.
 DevilsCry's gear list:DevilsCry's gear list
Canon EOS M100 Canon EF-M 22mm f/2 STM Canon EF-M 55-200mm f/4.5-6.3 IS STM Canon EF-M 15-45mm F3.5-6.3 IS STM
MyM6II Senior Member • Posts: 2,424
Yes there is. It’s not as straightforward as on other m cameras, because there is no dedicated MF button.
What you do is:
1. Make sure the “Continous AF” is disabled. (In the menu)
2. Half press the shutter button.
3. Set “Focus Mode” to MF. (In the menu)
4. Shoot.
5. Remember to set “Focus Mode” back to AF. (Or AF+MF)
 MyM6II's gear list:MyM6II's gear list
Canon EOS M6 II Canon EOS M6 Canon EOS M200 Canon EOS M50 II +1 more
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
Via Google
Page 144 and 145 explain where this is and how to access Manual Focus on the EOS M100.  Have you not read the M100 Manual?  I would recommend doing so in order to understand many of the hidden features this camera possesses.
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
OP mangurian Senior Member • Posts: 1,187
Is there a way to use the function button s but I have not figured it out.
What you do is:
4. Shoot.
What I was looking for.   Your explanation is better than the manual.
Essentially, focus (even using auto) and then switch to MF and the focus will not change (unless you turn the ring on the lens).
Thanks,
R2D2 Forum Pro • Posts: 26,528
Does the M100 have a Custom Function to disassociate AF from the shutter button?
Then could you use the touchscreen for AF? With Continuous AF disabled, and One Shot AF enabled.
Or can the ( * ) button be reconfigured for AF? With Continuous AF disabled.
Using the menu to lock focus every time sounds like a real pain, esp if one does not want to use manual focus every time either.
R2
Nickm46 New Member • Posts: 4
