International junior badminton championship
Started Nov 7, 2018 | Discussions
Fred_Last Contributing Member • Posts: 525
5
First attempt with sports photography. Taken with GX7 + 100-300 mk I. Auto ISO, shutter priority at 1/500 sec, centre-weighed metering.
Initially I was thrilled to test out the 40 fps "SH" burst mode on my GX7. Then I realized it is only available with 4MP image resolution. I switched on electronic shutter and the "H" burst mode in full 16MP ran up to about 10 fps. This was slower than my Nikon 1 J5 (see my other post in the Nikon 1 forum) but acceptable.
It was not until I ran this setup in the stadium, I realized the auto ISO was only available up to 3200. It was not bright enough to use SP at 1/500 sec (minimum 4000, as shown on my Nikon with a 70-300 4.5/5.6). I was forced to switch the mechanical shutter back on and I only got about 3 fps burst rate.
As a result, it was not fast enough to capture the flight of the bird (aka. shuttlecock) towards and away from the player, as well as the desired shot in most (90+%) of the shots.
Somewhat disappointing, but still a good practice run with the 100-300mm.
Panasonic Lumix DMC-GX7 Panasonic Lumix G Vario 100-300mm F4-5.6 OIS
addlightness Veteran Member • Posts: 3,641
Re: International junior badminton championship
Nice set!  I'm an avid badminton player and good to see 1/500s works very well at this venue.
 addlightness's gear list:addlightness's gear list
Panasonic Lumix DMC-GM1 Olympus E-M5 II Olympus PEN-F Panasonic Lumix DMC-GX85 Olympus E-M5 III +14 more
Skeeterbytes Forum Pro • Posts: 23,185
Indoor and night sports are a huge challenge and these are nice work considering the environment. The last is my favorite.
Looks like a fun sport to shoot.
Rick
HRC2016 Veteran Member • Posts: 6,874
Looks like you did very well with challenging conditions. Thanks for sharing.
I believe in science, evolution and light. All opinions are my own. I'm not compensated for any of my posts. Can you honestly say that?
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
OP Fred_Last Contributing Member • Posts: 525
Yes I would have liked to use a higher shutter speed but it was really restricted by indoor lighting. As you can see in the originals, there is smudging and tons of artifacts when you pixel peep.
I used to play badminton years ago (just amateur). Unfortunately I cannot play anymore because of frozen shoulder, despite having a lot of free time after my early retirement.
To be honest, they are all very acceptable(I don't pixel peep) despite the rather high ISO.  There're enough blur to suggest motion which is good IMO.
OT: I stopped playing for about 8 years due to frozen shoulder too.  I did a year of PT and the therapist suggested not to baby the shoulder too much and to 'challenge' the restrictions with gentle stretching and rubber-band exercise.  I was able to resume recreational badminton about 2 years after that.  I just need to be extra careful with overhead clears
