Bargain lenses
Started Nov 5, 2018 | Discussions
craniac
craniac New Member • Posts: 17
Bargain lenses
So I lost my GX1 two years ago, bought a cheap bridge camera, broke it, bought a Fuji X100, decided the flaws outweighed the strengths, sold it, upgraded my youngest daughter's saxophone, and now I'm cobbling together money for a used Panasonic GX7 body. As part of that process, I'm looking for cheap decent lenses.
One thing I've noticed is that on Ebay you can often find someone selling an older M4/3 body, something with a 12mp sensor, along with a decent kit lens, and if you end up reselling the body you get the kit lens for about 30 percent less than buying it standalone on Ebay.
So my question is, which M4/3 kit lenses are a real value? What should I keep my eye out for?
 craniac's gear list:craniac's gear list
Fujifilm FinePix X100
Fujifilm FinePix X100 Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7
alcelc
alcelc Forum Pro • Posts: 19,003
Re: Bargain lenses
If you are looking for a standard zoom kit lens, either the 12~32 or 14~42 mk-II could be the best of similar money. A de-kit (totally new) in grey market could be around US$100.
Since you will use on GX7, its primitive IBIS is far less efficient than lens OIS. Oly might not be your best option.
For longer, might be the 45~150 or 45~175 that should be in similar money. Around <US$150.
Albert
Adielle
Adielle Senior Member • Posts: 1,754
wouldn't recommend GX7 nowadays
You better buy a newer camera like GX85/GX80 at least, not a GX7. GX7 doesn't allow dual IS (IBIS + lens IS) and has much worse IBIS than later models. I would recommend at least GX85 and one of the lenses that have "Power OIS". If you just need a cheap kit lens and don't need large apertures, you could get the very compact Lumix G X Vario PZ 14-42mm f/3.5-5.6 Power O.I.S. and you'd get a really awesome and capable compact and cheap setup.
Stupot99 Regular Member • Posts: 428
14-42 mk-II
14-42 mk-II is a good lens and very good value
12-32 is also very good if you want 12mm, costs just a little more than 14-42
I don't know anything about the GX7, but the GX80 (GX85) is a very capable body, you might find a used one with 12-32 for a reasonable price
 Stupot99's gear list:Stupot99's gear list
Panasonic ZS100 Panasonic Lumix DC-GX9 Panasonic 12-35mm F2.8 II Panasonic 35-100mm F2.8 II
EarthQuake Veteran Member • Posts: 3,240
Re: Bargain lenses
The Olympus 40-150 4-5.6 can be found for next to nothing, usually under $100 used, and sometimes $100 brand new.
Outside of kit zoom lenses, there are a number of inexpensive prime lenses:
7artisans 7.5mm 2.8 manual focus fisheye $150 new
Samyang (Rokinion etc) 7.5mm 3.5 manual focus fisheye $150 used
Samyang (Rokinion etc) 12mm 2.0 manual focus $225 used
SLR Magic 8mm 4.0 manual focus ultra wide (not fisheye) $200 new
7artisans 12mm 2.8 manual focus $188 new
Panasonic 14mm 2.5 pancake $150 used
Sigma 19mm 2.8 $100 used
Panasonic 20mm 1.7 pancake $175 used
Zonlai 22mm 1.8 manual focus $170 new
Panasonic 25mm 1.7 $100-200 new
Olympus 25mm 1.8 $200 used
7artisans 25mm 1.8 manual focus $80 new
Meike 25mm 1.8 $80 new
Kamlan 28mm 1.4 manual focus $200 new
Sigma 30mm 2.8 $100 used
Olympus 30mm 3.5 macro $160 used
7artisans 35mm 1.2 manual focus $145 new
Olympus 45mm 1.8 $175 used
Kamlan 50mm 1.1 manual focus $170 new
7artisans 50mm 1.8 manual focus $90 new
7artisans 55mm 1.4 manual focus $120 new
Sigma 60mm 2.8 $130 used
*AF lenses in bold
Probably a few more I am forgetting as well.
Ghost1999 Regular Member • Posts: 177
Re: Bargain lenses
The 12-32 is an amazing value for money, and there seem to be lots out there used.
Another good option, if you can find one in good shape, is the original 14-45 kit zoom (not the 14-42 MK I, but the lens sold originally with the G1 and G2).
If you are interested in primes, the Sigma 30 and 60 are also good value for the money.
Have fun!
Dutch Newchurch
Dutch Newchurch Veteran Member • Posts: 5,716
Re: Bargain lenses
M43 kit lenses?  I've been won over by the (now discontinued) 12-50mm M.Zuiko because:
-  Macro (43mm).
- Weather sealed.
- 12-50mm range is just a little more useful where you need it.
- Cheap (it cost me just £100).
At the long end it is slow (f/6.3), which does limit the creative choices with it.
I don't video, so the power zoom is no benefit and I've not found a use for the fn button.
Dutch
forestmoonstudio.co.uk
My DP Review gallery
Photography is about light, not light-proof boxes.
craniac
OP craniac New Member • Posts: 17
Re: Bargain lenses
The quality of information in this thread is indispensable.  I'm grateful for the information about the primitive IS in the Gx7, and how it won't work with with an IS lens, but on the other hand, I'm on a tight budget and it will still be a huge improvement over the GX1.
One thing I really like about the GX1, the Fuji X100 and the future GX7 is the form factor.  Put a pancake lens on one of those and (in the winter) put it in your jacket pocket and you've got a really decent camera for random street photography or something to keep you interested during family outings.
Thanks everyone.
Simon97
Simon97 Veteran Member • Posts: 3,444
Re: wouldn't recommend GX7 nowadays
I agree with this. The GX85 two lens kit gets you a newer, better camera, the 12-32 and 45-150 which are good lenses for $600 US.
 Simon97's gear list:Simon97's gear list
Canon PowerShot ELPH 360 HS Panasonic Lumix DC-G100
Mark Ransom
Mark Ransom Veteran Member • Posts: 8,214
Reading between the lines, I'm guessing that $600 is way out of the budget.
 Mark Ransom's gear list:Mark Ransom's gear list
Pentax K-7 Pentax K-01 Olympus E-M5 II Pentax smc DA 15mm F4 ED AL Limited Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +6 more
Brian Chichester
Brian Chichester Senior Member • Posts: 1,114
Re: Bargain lenses
I'd second what Ghost1999 said about the mark I Panny 14-45mm. I got this lens years ago with a GF1 body. The GF1 is long gone but I won't part with the 14-45. Fairly big, not very fast, but just a very good lens right through its range.
And because of its age, probably selling for not very much these days.
 Brian Chichester's gear list:Brian Chichester's gear list
Olympus XZ-2 iHS Olympus Stylus 1 Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ +3 more
eques Veteran Member • Posts: 4,115
P 14-45
The first Panasonic kit lens, the 14-45mm probably was the best. My sample certainly is better than my 14-42ii. (I never tried the 12-32). As you suggested, you could get it with a G1.
IS is overrated. You will find that you get more unsharp photos by subject movement than by camera movement.
Better get an old body and a good lens than a new body and a mediocre lens. E.g. a used Olympus 12-40 with a G2 will give you better photos than a GX85 with 14-42.
Peter
 eques's gear list:eques's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G 20mm F1.7 ASPH Olympus 12-100mm F4.0
You are considering primes?
It does work with IS, just not the latest version, the Dual IS.
If you think along these lines, get a P 1,7/20mm or an O 1,8/25 and forget cheap zoom lenses. There won't be much, you can't do with these excellent primes! - And since they are fast, you won't need IS that much: F3,5 at 1/15s is the same as F1,7 at 1/60s.
Peter
hindesite Veteran Member • Posts: 4,893
Re: Bargain lenses
I have both the 12-32 and 14-42II.
The 14-42 is superb, small and very good IQ, feels great.
The only things going for the 12-32 are the WA and compact size. It is a collapsible lens with no focus ring.
mattthom1980 Junior Member • Posts: 38
Re: Bargain lenses
I'd suggest the Panasonic 12-60 kit lens over the Only 12-50. It's weather sealed and will allow dual IS if you upgrade the body .also a bit faster at the slightly further Tele end.
That said, it then stops being a pocketable camera but gives you a great walk around kit.
JakeJY Veteran Member • Posts: 5,442
Re: Bargain lenses
The GX85 12-32mm kit goes for about $400 on Ebay. I don't believe the GX7 14-42 kits goes for a whole lot less and if you buy body only, you need to leave about $100-150 for the lens, so you may not be ahead.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
nels11 Junior Member • Posts: 45
Re: Bargain lenses
If you're looking for both camera and lens, you might want to consider the Olympus website (getolympus). They have certified reconditioned latest camera and lens kit for a decent price.
https://www.getolympus.com/us/en/outlet/reconditioned-cameras.html
 nels11's gear list:nels11's gear list
Olympus E-M1 Olympus E-M1 II Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD Olympus Zuiko Digital 1.4x Teleconverter EC-14 +3 more
(unknown member) Veteran Member • Posts: 4,046
Re: Bargain lenses
For those prices all of them. For a narrower focus check my gear list, but I tend to go for more expensive lenses you won't get with your strategy. They are usually were and are not sold with older 12MP cameras.
I never found a bad OLY lens and I tried 30 of them. Panasonic made some dogs I remember in the 12MP days when I started with the system. All the OLY lenses I tried came after that so look at dates of introduction on DPR and try to find lenses introduced after the 16MP sensor was introduced. Good change they will be better than the older lens with exception.
You might learn more by asking which lenses NOT to buy.
DiffractionLtd
DiffractionLtd Senior Member • Posts: 2,836
Re: Bargain lenses
17mm f/2.8
Re: Bargain lenses
Second that. Sometimes I have to go for the f/1.8 version to keep the shutter speed up or the ISO down but most of the time its fast enough and sharp enough. I love the pancake design on a PEN. It lives on my PL-7.
