Lightroom, the R, color temperature.
Started 7 months ago | Discussions
zbh
zbh Junior Member • Posts: 27
Is it something on my side, or the color temperature is way off in Lightroom CC/Classic for shots taken with the R?
I have to set it above 8000K to get a balanced sunlight shot. Compared to the M5, in the same scenery, i need to add at least 2000K to get the same result.
 zbh's gear list:zbh's gear list
Canon G9 X Canon EOS 50D Canon EOS 80D Canon EOS M5 Canon EOS R +10 more
aftab
aftab Forum Pro • Posts: 10,122
Re: Lightroom, the R, color temperature.
Using AWB (ambient), there is a slight difference, but not 'way off'.
Standard Picture style
Adobe color is default with a little more contrast and warm tone compared to Adobe Standard. But DPP, Adobe Color and Adobe standard are close enough I think.
 aftab's gear list:aftab's gear list
Canon G1 X II Panasonic FZ1000 Canon EOS 5D Canon EOS 5D Mark III Nikon D600 +23 more
zbh
OP zbh Junior Member • Posts: 27
What I mean is the actual absolute number for the temperature:  a normal, AWB shot appears neutral with the Adobe Color/Standard profile. But the temperature slider is  just short of  8000K, while it should be about 6000K.
henrikbengtsson Senior Member • Posts: 1,227
Yes. I have noticed that too.
This is a good example. Needs more than 20 000 K
https://m.dpreview.com/sample-galleries/9958447403/canon-rf-35mm-f1-8-macro-is-stm-sample-gallery#&gid=1&pid=47
 henrikbengtsson's gear list:henrikbengtsson's gear list
Canon EOS 5DS Canon 6D Mark II Canon EF 70-200mm F2.8L IS II USM Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +1 more
aftab
That's strange.
jay-A Regular Member • Posts: 266
This screams bug.
You can file a report at adobe.
Tony Parenti Regular Member • Posts: 393
I had this same issue with ACR / Lr with the R as well.  I was getting a WB reading of 6450 and tint of -40 (yes, negative 40) on images shot at kelvin 5500K.  The same RAW file on my friends computer would open up 7250K, +8 tint.  I had to uninstall Ps and Lr, scrape out the remaining folders, reinstall and now all is well in the world.
zbh
Reinstalling the whole thing is out of question. Restoring all my setup is a couple of days' work.
I'll try opening an issue with Adobe. Either case this seems an issue with ACR/LR.
kiwi2
kiwi2 Veteran Member • Posts: 4,196
I get a similar thing with Fuji's new X-T3 in Lightroom.
I downloaded this RAW file and as shot AWB shows these numbers...
 kiwi2's gear list:kiwi2's gear list
Fujifilm X-T2 Fujifilm X-T100 Samyang 8mm F2.8 UMC Fisheye Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 56mm F1.2 R +4 more
Damn!
I  think Adobe is running a copy-paste approach sometimes when they want to rush the profiles out the door after a camera release but haven´t had the time to develop them properly from scratch.
