Lumix G7 NTSC to PAL?
Started Oct 30, 2018 | Questions
harisd New Member • Posts: 3
Hey guys,
i have an issue i have not found an answer to yet. I changed my lumix g7 from PAL to NTSC with one known trick. Just did it so i could record 60p. Now i have to switch it back to NTSC for 50p but I could not figure out how to do it or if it was even possible.
I hope some of you would know the answer to this. I would be really thankful
Panasonic Lumix DMC-G7
pannumon Veteran Member • Posts: 4,130
Re: Lumix G7 NTSC to PAL?
It is possible.
I had trouble doing it in the past with my G7, but when I tried again, I was able to do it.
To do it:
  • Power off the camera
  • Set mode dial to P
  • Power on the camera
  • While pressing [ MENU/SET] and "[ RIGHT ] of cursor buttons" simultaneously, turn the Power off. The "INITIAL SETTINGS" menu should be displayed.
  • Press "[ RIGHT ] of cursor buttons"
  • Press [ RIGHT ] again.
  • Turn on the camera. All settings are reset, but the camera should now operate in PAL mode.
This is the instruction in one video that I used.
I hope this helps.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
hindesite Veteran Member • Posts: 4,893
hindesite wrote:
https://www.youtube.com/watch?v=Dt-GX5BdcgU
This is the one. Funnily it did not work when I tried to open as embedded. Instead, when I open it on YouTube, it works fine (I think this video is not available on direct search. It is not "public").
Not really, maybe it is "unlisted" (so, public but doesn't appear in search results, you need a direct link).
The 3 options are Public, Private and Unlisted.
Embedding is a different issue.
"Allow Embedding" is an advanced setting that causes the video to not display in the DPR web page.
OP harisd New Member • Posts: 3
Tried it and did it. Thank you very much. I really could not find it myself, this was a huge help
Thank you guys for the kind replies. It worked perfectly fine and I can record again with no worries Thanks!
zain1254 New Member • Posts: 1
Hi I have a Lumix GF10 and converted it from PAL to NTSC and now going back to stock PAL when pressed Menu button with right cursor and switched off, It do show a list to select region but I can't select it by pressing right cursor 2x as it shows Strict Mode and Error 0A when selecting.
Help me out Thanks.
