50-230 II as a landscape lens
Started Oct 30, 2018 | Discussions
Snap Happy Senior Member • Posts: 1,925
5
A shot from the weekend, processed through SilkyPix 3.0 and then in Photoshop Nik Dfine, Sharpener (I only used SilkyPix as I wanted to change white balance, I am in the process of migrating to C1 Pro).
Cropped to 4:3 as I didn't quite nail DoF and part of the original foreground was not quite sharp.
Very light lens, seems pretty good when stopped down.
X-T2, Gitzo 2 series Traveller, RRS BH-25, RRS L-Bracket, Hoya polariser.
 Snap Happy's gear list:Snap Happy's gear list
Fujifilm X-T4 Fujifilm GFX 100S Fujifilm X-H2S Fujifilm XF 50-140mm F2.8 Fujifilm 16-55mm F2.8R LM WR +19 more
Fujifilm 50-230mm II Fujifilm X-T2
John356 Regular Member • Posts: 171
Re: 50-230 II as a landscape lens
Nice shot.  I have this lens, it is light and when I bought it very inexpensive but a little plastic compared to other Fuji lens I have. This said Fuji, at least to me, offer a very good range of lenses - even the lower price ones can give very nice results.
John
 John356's gear list:John356's gear list
Sony RX100 Fujifilm FinePix X100 Fujifilm X100F Fujifilm X-Pro2 Fujifilm X-H1 +7 more
georgehudetz Veteran Member • Posts: 6,299
As others have said, nice image.
You should be able to pull more detail out with C1.  Since you shot this at F16 (presumably to slow the shutter) you do get noticeable diffraction.  In C1, in the Lens Correction toolset, check "Diffraction Correction" on any image that is F9 or smaller, and you should be able to push the standard sharpening further without artifacts.
I've been considering the 50-230 as well.  I have been hiking with the 16-55 & 50-140 (along with the 2x TC) and I know that going with something like the 16-80 & 50-230 would be sooo much lighter and compact.
 georgehudetz's gear list:georgehudetz's gear list
Panasonic Lumix DC-S1R Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Sigma 14-24mm F2.8 DG DN Panasonic Lumix S Pro 16-35mm F4 +4 more
OP Snap Happy Senior Member • Posts: 1,925
Ah, thanks, yes I was struggling to get shutter speed long enough to blur the water.
Your back would certainly notice taking the 50-230 instead of the 50-140!
Yes indeed.  I'm even thinking of just taking the 10-24 & 50-230 in a waist pack for most hiking.
Garthom Regular Member • Posts: 332
If I end up sticking with Fuji, I'll get the 10-24 and this will be my hiking/backpacking combo as well. At f8, my copy of the 50-230mm is really impressive for its size and price (I got a brand new grey market copy for $175!). It sounds kind of silly since it's a cheap kit zoom, but it's actually a big reason to stick with this system for me. There just isn't really anything comparable if I were to switch.
jonikon Veteran Member • Posts: 7,432
Nicely done! It appears you have a better copy of the 50-230mm than I do though. Did you have OIS turned off?
Jon
Yes, absolutely, especially after I took some test shots at home on the same tripod/head but forgot to turn OIS off - I almost left the lens at home as the shots were not sharp.
BTW, if you could post a 100% JPEG from C1 - or a raw - of a Landscape image @ F8 sometime, I'd appreciate it.  Most of the XC samples I've seen posted here are of reduced resolution.
