Olympus E-P5: Assigning Fn Button to MySet?
Started Oct 28, 2018 | Discussions
Jim Ford Senior Member • Posts: 1,240
Page 85 of the E-P5 manual implies that the Fn button can be assigned to a MySet, or cycle through them. I've been unable to achieve this. Is this a mistake in the manual - anyone?
Jim
Olympus PEN E-P5
olybrit Regular Member • Posts: 147
Re: Olympus E-P5: Assigning Fn Button to MySet?
Jim
Hello Jim,
Fn button function can be changed via Cogs menu B, Button Function, where there is a list of available options. What you can't do is change the programmed function between Mysets - it will stay the same once set. If you save the setting to a Myset, it will be the same for all Mysets.
Applies to all button functions.
After saving to Myset(s), you can re-assign the function, effectively giving you 2 choices "on the fly" - one selected by the Myset selection, the other by pressing the Fn button manually.
This is a long standing limitation of Pen and OMD Mysets.
Hope this helps, Paul
 olybrit's gear list:olybrit's gear list
Olympus E-PL7 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +6 more
OP Jim Ford Senior Member • Posts: 1,240
olybrit wrote:
Jim
Hello Jim,
Thanks for the reply, Paul.
I've seen as you describe above, but MySets aren't on the list of functions that can be assigned.
Jim
Hello Jim,
Basic procedure for Mysets:
Make all the settings you want for a particular Myset.
Then go to Shooting Menu 1>Reset/Myset >Select Myset 1-4*>Joypad rightarrow>Press OK to save the settings.
*= Invoke any Myset later by pressing OK in the Myset select menu
Or, you can then assign your Myset(s) to a Mode dial position via Cogs B, Mode Dial Function, presumably using settings you don't use often e.g. Auto, Art, Scene or Photo-story ?
Regards, Paul
ScottoG Forum Member • Posts: 80
Hello Jim.
I see that the table at https://www.dpreview.com/reviews/olympus-pen-e-p5/6 confirms  that the Fn button cannot be set to a Myset.  However, the Magnify and REC buttons can.
Is that useful to you?
Scott
 ScottoG's gear list:ScottoG's gear list
Olympus M.Zuiko Digital 17mm F1.8 Olympus 14-150 F4-5.6 II Olympus 30mm F3.5 Macro Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +4 more
ScottoG wrote:
Hello Jim.
Scott
P128 of the Oly manual says otherwise - and it seems to work on my P5.
Regards, Paul
ScottoG wrote:
Hello Jim.
Scott
Thanks for the reply, Scott
I might use one of the dial functions instead.
Jim
olybrit wrote:
ScottoG wrote:
Hello Jim.
Scott
Regards, Paul
I can't see any reference to MySets on page 128 of my manual. The page is for 'Custom Menu', Chapter 11.
How did you set your E-P5 Fn button to a MySet, then Paul?
Thanks for the reply, Jim
