Shadows in the sky?
Started Oct 27, 2018 | Questions
maxx218 New Member • Posts: 10
Shadows in the sky?
I own a G12 and shadowy blobs appear in the sky when I shot pics on sunny days with the sun BEHIND me. I have noticed a small scratch on the lens which could correspond to the area; is that the cause? as yet it doesn't sem to affect pics whn I shoot into the light, like at sunset. I'm gonna try some flash indoors to see if it produces any unusal artifacts. Has anyone else suffered from this. Heres an example
and this full size close up
thanks
max
Canon PowerShot G12
Lancaster
Lancaster Forum Member • Posts: 95
Re: Shadows in the sky?
That looks a lot like a dust spot on the sensor, although your supposition of a lens scratch could be correct.
In LIghtroom it is quite easy to take dust spots out of the image and I believe there may also be a way of mapping the spots and taking them automatically out of the image, but I am unsure of that.
Or, you could send it to a service depot.
Rick Grant
Calgary
 Lancaster's gear list:Lancaster's gear list
Canon PowerShot G7 X Canon G7 X II Canon PowerShot SX730 HS Nikon D7200 Sigma 18-35mm F1.8 DC HSM Art +2 more
Geodude Contributing Member • Posts: 596
I recognise that view Malvern Hills in Worcestershire I live close by. Yes very likely as you have a scratch to be that. Does look like a dust spot mind on sensor. Take a photo of a bright white piece of paper and see what that reveals.
 Geodude's gear list:Geodude's gear list
Panasonic Lumix DMC-FZ50 Canon PowerShot G1 X Canon PowerShot SX50 HS
I2K4
I2K4 Senior Member • Posts: 1,441
Sensor dust tends to be small, the size of smudge points to lens surface. Below was from my little Ixus a few years ago, in that case able to clean off the lens:
https://www.dpreview.com/forums/post/51625525
Post processing works well, but would be irritating if a permanent problem.
rmexpress22 Senior Member • Posts: 2,304
Just use a little fill flash. You might have to zoom in the flash head all the way.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
OP maxx218 New Member • Posts: 10
Good idea: but nothing showed up! Even when I turned up the contrast.
These shadows only seem to happen on sunny days with the sun behind me and always in the sky.
Does anyone have another idea whats going on here? I have a sensor spot on another camera and it replicates in the same place in every photo. I thought the scratch might be the cause but nothing shows up when I shoot into the sun at sunset for example.
thanks
max
Britney Elvis Veteran Member • Posts: 5,382
Sensor dust
This looks exactly like the 'shadow blobs' I would get on my P200 back in the day.   Usually only showed up in sunny, high contrasty pics.
Back then there was a vacuum cleaner trick that sometimes worked to remove them.
Good Luck
Gus
"It is not necessary to understand things in order to argue about them."
~~ Pierre Beaumarchais~~
sueanne
sueanne Forum Pro • Posts: 21,078
It looks like there is a dirt got on the lens
thanks
max
 sueanne's gear list:sueanne's gear list
Canon PowerShot A510 Canon PowerShot A650 IS Canon PowerShot SD880 IS Canon PowerShot S3 IS Canon PowerShot S110 +3 more
