My 70-200mm f4 IS is marvelous!Why canon d'ont do a 200-600mm F5.6is with same IQ??
Started Oct 24, 2018 | Discussions
chouette New Member • Posts: 22
No text.
J A C S
J A C S Forum Pro • Posts: 20,544
Re: My 70-200mm f4 IS is marvelous!Why canon d'ont do a 200-600mm F5.6is with same IQ??
BlueRay2 Forum Pro • Posts: 14,816
chouette wrote:
depends on if you can afford it
Who are you gonna believe, me, or your lying eyes? Groucho Marx.
John Sheehy Forum Pro • Posts: 26,698
Don't expect such a lens to be anywhere near as hand-hold-able. The front element needs to have 4.5x the area; the lens needs to be longer, etc. Even a 600/5.6 DO prime, would be as big and as heavy, or a little more so, than a 400/4 DO with a 1.4x TC, and add to the zooming, and you're looking at something at least 7 pounds, minimum.
What I wonder about is whether Canon will eventually start making lenses slower than f/5.6, as AF ability at higher f-numbers improve, especially with mirrorless cameras with EVFs.
A 200-600/5.6-8.0 zoom could be very hand-hold-able. Even f/7.1, if they break from their whole-stop silly standards.
Dave
Dave Veteran Member • Posts: 6,231
Re: My 70-200mm f4 IS is marvelous! Why doesn't Canon do a 200-600mm F5.6is with same IQ??
I'd settle for 200-500 to limit cost and weight.
If not committed to L, maybe the 18-135 and 70-300 Nanos form a better basis?
Is there room for both?
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
would that be a "L", EF or just an EF-S zoom? makes a big difference! looking at Tamron and Sigma, and nikon it can be achieved (150-600mm) but it will be just a matter of economics for canon!
we are all one consciousness experiencing itself subjectively.
Will T
Will T Regular Member • Posts: 425
Canon did, it is called EF 200-400mm f/4L IS USM Extender 1.4x!
Will T.
"Galleries don't hang DxO charts" David Hull
true, but they didn't make it easy on the wallet, though
I was assuming a lens the quality of the L and DO series. Those 600mm 3rd-party zooms are not as rugged or as sharp wide open (although they're fine when you fill the frame and don't have to crop much).
Jura S Senior Member • Posts: 1,980
They are very good in relative (price/performance) and absolute terms. If you want ruggedness there's Sigma S or a little less Tamron G2. If you want hand holdable lens there are all light enough. Sigma S maybe the only exception.
Here's one shot from my terrace few moments ago. Sigma C hand held and wide open.
ed rader Veteran Member • Posts: 9,068
quite true!  and this is fantasy lens day ;^)
 ed rader's gear list:ed rader's gear list
Canon EOS 80D Canon EOS 5D Mark IV Sigma 15mm F2.8 EX DG Diagonal Fisheye Canon EF 24-70mm F2.8L II USM Canon EF 16-35mm F4L IS USM +4 more
