Will the future X-T4 have IBIS or not?
Started 7 months ago | Polls
Mikeb9550 Forum Member • Posts: 72
Re: Will the future X-T4 have IBIS or not?
I too would like IBIS. A lot of people state they don’t need it and I would mostly fall into that category but when I do need it, I want it to be there.
There is no trade offs with modern IBIS. Not sure why people think there are compromises.
AaronX Contributing Member • Posts: 770
This assertion --- " there will still be a penalty on price and camera size" is actually misperception. Sony A7 and Panasonic cameras started without IBIS, and they added IBIS later without adding to the size and price. In the old DSLR days, Pentax had IBIS and had no price or size penalties compared to Canon and Nikon. Obviously with IBIS you need to add something into the camera and there is a research cost, but apparently these can be absorbed.
Maybe Fuji has already figured it out and it's just a marketing strategy to let the early adopters buy the X-T3, and make another sale with the IBIS enabled X-T4, If the X-T3 had IBIS, the X-T4 might not have enough new features.
OP virgil1612 Regular Member • Posts: 326
I just realized that I didn't answer my own question yet.
And I also realized that maybe it's not a great question to ask. Some of the answers were erring on what Fujifilm should do, which was not my intention, because that would just reflect our own preferences and style of shooting, which are unique to each photographer or enthusiast.
I wanted in fact to provoke some educated guesses as to what fuji will do concerning IBIS and probably I didn't explain it well enough, though of course only Fujifilm knows what it will do.
Me, I think Fuji will put an IBIS in the X-T4. The way I see things, Fujifilm was slow in implementing advanced features in their cameras. When they came out with their X-Pro1, the focus was slow and it took Fuji all these years, before producing the X-T3, with a really great AF . The movie features (AF and others) were also way behind others and it's only with the X-T3 again that they are on par (even ahead).
So with IBIS, they are just starting developing it, they did it for the X-H1, but can't do it yet small enough for an X-T or X-E body. But I think they are working on it and will put it on the X-T4, keeping the small form factor of the camera. I think they want to show that what Sony is doing, they can do it too (technical features I mean, because in color and usability they are way ahead).
I think IBIS slowly becomes an ubiquitous feature of serious cameras.
 virgil1612's gear list:virgil1612's gear list
Canon G7 X II Sony a6000 Fujifilm X-T100 Sigma 30mm F2.8 DN | A Fujifilm XF 23mm F2 R WR
Advent1sam
Advent1sam Veteran Member • Posts: 6,760
virgil1612 wrote:
I just bought the X-T100 and I decided that my future Fuji body, whenever it comes (for me) will have IBIS. I wonder if Fuji will put IBIS in the X-T4 or IBIS will used exclusively in the X-H bodies. What do you say?
I prefer no ibis or basic sensor shift on button press which is more stable when off, and wish that all Fuji lens just have ois, when an ibis sensor is locked down ie switched off it still can "rattle"
Sensor-shift IS systems operate by ‘floating’ the sensor using a series of electromagnets. Even when they’re ‘off’ they’re not locked in place, they’re simply set so that the electromagnets aren’t attempting to correct for movement. This has the side-effect that, which mounted on a professional stabilization rig, there’s a risk of the sensor being shaken around.
For high-end video work, Panasonic says its users would prefer to use dedicated gimbals and dollies, rather than internal stabilization, and that means physically locking the sensor in place to avoid unwanted interactions between these systems and a floating sensor. You also get noise and heat, look at the Nikon z7 I think they haven't solved that problem yet lol, Sony and Olympus already solved it, well Olympus gave the tech to Sony.
 Advent1sam's gear list:Advent1sam's gear list
Fujifilm X-H1 Fujifilm X-T100 Fujifilm XF 18mm F2 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
DarnGoodPhotos Veteran Member • Posts: 8,381
IBIS will end up in the other cameras once Fuji can make it small enough to not affect body size.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X-Pro1 Fujifilm X-Pro2 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +3 more
57even Forum Pro • Posts: 13,285
They were larger, heavier and more expensive than the previous versions of the same camera. Money is saved elsewhere, and the A7iii cuts a lot of corners in terms of LCD, EVF and weather sealing.
Not entirely, no. Something else is compromised. A simple fact you can't seem to fathom. Plus the fact that Sony wanted to force Canon and Nikon to a lower entry point cost for mirrorless.
Or maybe it would have cost more to re-engineer the bodies to accept it which would have pushed the cost up and made it uncompetitive against the latest FF cameras.
Just because you can't have what you want does not mean there is a conspiracy.
Reporter: "Mr Gandhi, what do you think of Western Civilisation?"
Mahatma Gandhi: "I think it would be a very good idea!"
 57even's gear list:57even's gear list
Fujifilm X-Pro2
Indeed you choose to believe in what you believe and will not understand what you cannot fathom.
dual12 Contributing Member • Posts: 725
I say that I've seen enough of these IBIS X-T threads.
Have you ever worked in production engineering?
Fujifilm X-Pro2
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 13,048
Then, my all means exercise your ability to ignore them and move on to threads which are of greater interest. Clearly, the subject continues to have "legs" given both the number of threads and responses within those threads.
I can certainly see why some folks might be tiring of the discussion, in which case, just give them a pass. Complaining about it here won't change a thing.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm X-T2 Fujifilm X-H1 Carl Zeiss Touit 2.8/12 Fujifilm XF 10-24mm F4 R OIS Fujifilm 16-55mm F2.8R LM WR +2 more
webber15 Senior Member • Posts: 1,556
There are compromises...and ibis causes more than ois (though no stabilization at all is preferred, and I will freely admit that the notable iq difference between stabilized and not stabilized is probably small).
As already mentioned in this thread, you have plenty of choice if you want ibis - from a variety of makes, and that includes a camera from Fuji.
I honestly don't understand the mentality of the ibis fans...they whinge that Fuji doesn't have it, then when it's implemented in a particularly model, they whinge it's not in "ALL" models - and that's despite the fact there are many who do not want ibis.
What gives!!
Dave.
 webber15's gear list:webber15's gear list
Fujifilm X-Pro2 Fujifilm XF 100-400mm F4.5-5.6 OIS WR
Greg7579
Greg7579 Senior Member • Posts: 6,425
Sorry I Missed This
Great question.  Just saw this down low on the Board.
The answer is it better or Fuji is in big trouble.
So the answer is yes.
Greg Johnson, San Antonio, Texas
https://www.flickr.com/photos/139148982@N02/albums
 Greg7579's gear list:Greg7579's gear list
Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS Fujifilm XF 16mm F1.4 R WR XF 90mm Fujifilm X100F +13 more
Greg7579
Adios Amigo!
Goodbye Dual.
You can't stay here because I can promise you that over the next two years you are going to see 5000 IBIS threads if you do.  This is a Fuji camera equipment board My Friend.
The single biggest issue Fuji faces is getting IBIS on the XT-4.  It is their biggest challenge and we are going to be talking about it and arguing about it every day for a long, long time.  Fuji must do this and they know it.  Failure is not an option.
Adios.  It was nice having you here for a while.
Astrophotographer 10 Forum Pro • Posts: 12,829
Re: Adios Amigo!
Greg7579 wrote:
Goodbye Dual.
I agree, getting IBIS into an XT4 should be their highest priority now the camera seems spot on with AF, video, build, ergonomics etc.
Its the only real "flaw".
They can't say it can't be done as Sony manages to squeeze it into the A6500 which is tiny.
Greg.
 Astrophotographer 10's gear list:Astrophotographer 10's gear list
Sony a7R II Sony a7R III Sony FE 55mm F1.8 Zeiss Batis 85mm F1.8 Zeiss Loxia 21mm F2.8 +1 more
celestialemissary
celestialemissary Contributing Member • Posts: 633
Platinum_Jello wrote:
If they know what they're doing they'll keep it separate/keep the X-T line lean and mean for stills shooters. That said, so many people are crapping their pants over this and flippy flappy vanity screens, they'll probably eventually cave. Then we'll have the same features on every model and you'll have your choice if 10 different versions of the same camera.
Yeah those people only think about them selfs.
Every camera has to be great for vlogging (even if it's 1.4gb fullframe beast) and it need to have that stupid screen.
No thanks
 celestialemissary's gear list:celestialemissary's gear list
Fujifilm X-T2 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR
Greg7579
Re: Adios Amigo!
Astrophotographer 10 wrote:
Greg7579 wrote:
Goodbye Dual.
Greg.
There is no should be.  It absolutely is their number one priority.  Hard to do unless they change the mount, and they can't do that...  This is all absolute fact.  You guys can argue this all you want.  This is a big deal.  Fuji went APSC, which was brilliant.  But they designed the mount just a tad too small.  They weren't thinking about IBIS back then.  Now they are.  They have to, or they are screwed.
JS Burnie
JS Burnie Veteran Member • Posts: 3,878
Re: Adios Amigo!
X-H1 has the same mount, no?  It's how big the rest of the body is, including adequate cooling.  Am I missing something?
 JS Burnie's gear list:JS Burnie's gear list
Fujifilm X-E2 Fujifilm X-T1 Fujifilm X-E3 Fujifilm X-H1 Fujifilm XF 27mm F2.8 +5 more
Gibbons3D Forum Member • Posts: 75
Re: Adios Amigo!
I don’t see them doing it without costs going a lot higher, at that point the masses would just go full frame the price is that close.
XH series is thier answer to people who want it and I’m happy it’s a choice where we can determine what model suits are needs and price points.
I personally think there biggest issue going forward with new tech is battery life.
KariP
KariP Veteran Member • Posts: 5,078
Commercially clever - as it is now
to have separate and different series of cameras. Just like cars. 4 wheel drive is a useful thing - some people do not need it and do not want to pay more.
It is very likely that X-H1 will get all the "bells and whistles" and some more that X-T3 now has. And then there is the camera that has everything - and the price is higher.
X-T3 will be smaller and a bit cheaper. People who use OIS lenses do not really need IBIS - of course it is nice to have.
There is no commercial wisdom in producing cameras that are all a like.  If Ibis is engineered/squeezed  to X-T3 body and the size can not get bigger the price of the X-T4 camera will be even higher than the price of X-H2.
Fuji has clearly three or four different  camera lines for "advanced amateurs" or pros. 1    )X- pro series with a different viewfinder ( that camera can get IBIS)
2) range finder style smaller X-E  series that gets smaller every time - if they want to keep it small and light and cheaper there is no room for IBIS
3) X-T series has everything but IBIS and it stays compact ...
4) X-H series  stays as the IBIS model, slightly bigger and aimed  for a special group who uses especially prime lenses - or like to have a bigger body.
Fujifilm wants to sell lenses and cameras - there is no point in creating basically just one model that has everything and also a steep price.
There are several types and models of customers with different needs and budgets.
Kari
I started SLR photography in 1968, first DSLR was Canon 40D in 2007. Now Fujifilm X-E3 and the new 80D are my favourites - also 6D for landscapes and some portraits.
 KariP's gear list:KariP's gear list
Fujifilm X-T1 Canon EOS 80D Canon EOS 5D Mark IV Fujifilm X-E3 Canon EF 50mm f/1.4 USM +14 more
left eye
left eye Senior Member • Posts: 1,609
X-T = thinner body / X-H = IBIS
I hope Fuji have two parallel lines, the X-T and the X-H, so we can choose whether we want a body with a floating sensor where IBIS (even when off) is constantly draining our battery, or not.
Also if we don't want IBIS we can then have the less deep body of the X-T line (a floating sensor and IBIS actuators take up more depth).
...the 'top view' for both 1 & 2 cameras here...
https://camerasize.com/compare/#800,772
...otherwise what real difference would there be, a deeper X-T body with IBIS - well that's an X-H.
 left eye's gear list:left eye's gear list
Olympus E-300 Pentax K-5 Fujifilm GFX 50S Panasonic GH5 +5 more
