200D and Sigma 18-200mm f/3.5-6.3 II DC OS HSM
Started Oct 22, 2018 | Discussions
Alain0209 New Member • Posts: 3
Hello,
My girl-friend uses an old EOS 350D and a zoom Sigma 18-200mm f/3.5-6.3 II DC OS HSM , using the EF-S mount. She wants to upgrade to an EOS 200D, using the same lens. I assume the old lens and the newer 200D should work perfectly well together. Is this correct ?
Apologies is the question is obivious, but I'm not familiar with those compatibility issues.
Alain
Canon EOS 350D (EOS Digital Rebel XT / EOS Kiss Digital N) Canon EOS Rebel SL2 (EOS 200D / Kiss X9)
GeralH Regular Member • Posts: 142
Re: 200D and Sigma 18-200mm f/3.5-6.3 II DC OS HSM
Alain0209 wrote:
Hello,
Alain
If the zoom works with the 350D (ergo, it has an EF-S mount) it should work perfectly with the 200D
 GeralH's gear list:GeralH's gear list
Canon EOS Rebel SL1 Canon EF-S 18-55mm f/3.5-5.6 IS STM Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF-S 24mm F2.8 STM Canon EF 50mm F1.8 STM
OP Alain0209 New Member • Posts: 3
Alain
R2D2 Forum Pro • Posts: 26,551
Alain0209 wrote:
Hello,
Alain
No problem. It's actually not obvious at all!
I'd advise checking with Canon and Sigma regarding compatibility. The SL2 uses the new Canon lens communication protocols (esp for Dual Pixel AF). Even some of Canon's own older EF lenses are not fully compatible.
Sigma might have a firmware update that they could apply if available. Check with them.
Best of luck. The 200D packs a huge bang for the buck!
R2
ps. If you can get the 200D with the 18-135 USM kit, that would really rock (I have the older brother 18-135 STM).  It is dead quiet and just a joy to use.  R2
canonaimer
canonaimer Regular Member • Posts: 368
It should work fine; I just tried it with a first model 18-250 Sigma, and it worked just as advertised, even in live view.
 canonaimer's gear list:canonaimer's gear list
Pentax K-5 IIs Canon EOS 6D Canon EOS 7D Mark II Canon EOS 5DS Pentax K-3 II +38 more
We tried it yesterday and it workd fine, indeed. Thanks to all for your advices.
