Should Olympus start a new f/2.8 prime lineup?
Started Oct 19, 2018 | Discussions
bluevellet Veteran Member • Posts: 4,172
I wouldn't buy it
5
Except maybe an ultra-wide f2.8 lens.
But the rest? Forget it. F2 or faster or don't bother.
 bluevellet's gear list:bluevellet's gear list
Panasonic Lumix DMC-GM5 Nikon Z6 OM-1 Sigma 35mm F1.4 DG HSM Art Olympus M.Zuiko Digital ED 8-25mm F4 Pro +23 more
Dave Lively Senior Member • Posts: 1,938
Re: Should Olympus start a new f/2.8 prime lineup?
SushiRyu wrote:
I wrote an ad for these new lenses:
"Do you like the f1.8 primes that already exist for m43, but sometimes just wish that you could switch to a different lens instead of stopping down to 2.8 in those clutch moments? Introducing the new 75mm f2.8 from Olympus! Similar to the fabulous 75mm f1.8, but inferior."
Or how about:
"Do you want a 7mm lens but don't want to spend $800 to $1300 for one of the zooms?  Introducing the 7mm f2.8 from Olympus, all the wide of our 7-14 zoom but only a third the weight and price"
Or:
"Do you want more working distance than our 60mm f2.8 macro provides?  Tired of struggling to get light on small subjects?  Introducing the 120mm f4 macro."
I wouldn't buy a conventional f2.8 prime for a focal lengths between 12 and 90mm.  The compact and inexpensive f1.8 primes or kit zooms I already own are fine in that range.  But depending on price, weight and optical quality I would likely buy a longer macro lens or an ultrawide 7mm to 9mm prime.  And neither would have to be fast.
Cagey75
Cagey75 Senior Member • Posts: 1,347
Just get the 12-40 2.8 and you basically have a bunch of 2.8 primes in one.  Whoever said 2.8 is slow .... eh?? The 12-40 is one of the better M43 lenses available, and many are happy enough with it's bigger brother the 12-100 F4! they don't think it's too slow.
 Cagey75's gear list:Cagey75's gear list
Fujifilm X-H1 Fujifilm XC 35mm F2 Venus Laowa 65mm F2.8 Macro +1 more
Belgarchi Senior Member • Posts: 2,704
Tommi K1 wrote:
Now most of the Olympus primes are f/1.8 ones in their Premium line. But they had a 25mm f/2.8 in their 4/3 system and 17mm f/2.8 in m4/3. But both are gone.
Should Olympus revive that f/2.8 line with something new, special for cheaper prices?
9mm f/4
17mm f/2.8
25mm f/2.8
75mm f/2.8
120mm f/4 (Macro?)
The 9mm, 17mm and 25mm in pancake designs, and 75mm to be made as small as possible. The 120mm f/4 macro in quality of 60mm Macro.
If one could get a 17mm and 25mm f/2.8 for lets say 200€ each, would it be worth to consider new users those, instead their f/1.8 Premium line that are 1.3 stops faster?
Considering that 17mm and 25mm f/1.8 models costs like 350€. Being pancake models without any fancy clutches etc, it would be nice cheap set to buy someone to start with. Ie E-PL9 + 17mm and 25mm for lower price.
F/2.8 is really too small for lenses, say, between 14 and 45mm and they would compete with existing zooms.
I would love the following lenses (if well made) with moderate aperture:
10/2.8, 12/2.8, 14/2.0, 17/2.0, 20/2.0, 25/2.0, 30/2.0, 40/2.0, 50/2.8, 70/2.8, 100/3.4, 150/4.0, 200/4.8, 300/5.6.
They could be light, inexpensive and sharp.
 Belgarchi's gear list:Belgarchi's gear list
Leica D-Lux 7 Olympus PEN-F Olympus E-M5 III Fujifilm X-T5 Canon EF 35mm F2.0 +101 more
A 300mm 5.6 would be nice. I mostly use my 100-300 at 300mm but have to stop it down a little for best results. A light, inexpensive and sharp wide open 300mm prime would be a nice alternative.  But since I already have a 100-300 it would have to be noticeably sharper and/or lighter before I would buy one.
arson519
arson519 Forum Member • Posts: 68
No we need more speed I would not even consider or even buy a 2.8 prime there already is a bunch of cheap 1.8 lenses
 arson519's gear list:arson519's gear list
Panasonic S1 Sony a7S III Sigma 35mm F1.4 DG HSM Art Sony FE 55mm F1.8 Sigma 50mm F1.4 DG HSM | A +3 more
Astrotripper Veteran Member • Posts: 8,676
[...] 200/4.8
Or a 200mm f/2.8 that doesn't cost 3000 EUR. You know, something like Canon 200mm f/2.8L II, which currently sells for 700 EUR.
, 300/5.6.
Now, that one would make equivalence police fuming.
Ah, the famous unicorn trio. Sorry, you can only get two of those, pick which ones
 Astrotripper's gear list:Astrotripper's gear list
Sigma DP2 Merrill Olympus PEN E-PL1 Panasonic Lumix DMC-GM5 Olympus E-M1 II OM-1 +15 more
Androole Senior Member • Posts: 1,455
Maybe if they're for an FF camera
9mm f/4
17mm f/2.8
25mm f/2.8
75mm f/2.8
120mm f/4 (Macro?)
f/2.8 primes don't really make sense on M4/3. They are small, light, sharp, and affordable in the f1.7-f2 range. With the possible exception of an ultrawide prime or lens ~100mm or longer, it's pretty much impossible for me to see the appeal of f/2.8 lenses on M4/3. It would just be sucking up R&D resources to produce low-margin products that no one would buy.
Compact, light, affordable F2.8 primes for an FF system, though? That would be fantastic.
 Androole's gear list:Androole's gear list
Olympus Stylus Tough TG-850 iHS Panasonic Lumix DMC-GX7 YI M1 Panasonic Lumix G 20mm F1.7 ASPH Panasonic Lumix G Vario HD 14-140mm F4-5.8 OIS +2 more
Astrotripper wrote:
[...] 200/4.8
You can use that Canon 200mm/f2.8 on your M4/3 camera if you want, you know.
You'll be disappointed with it. It's a 25 year old lens design. It has less than half the linear resolving capability of the PL200mm/f2.8. But I guess if the cheap price is much, much more important than performance, that's fine.
, 300/5.6.
Androole wrote:
Astrotripper wrote:
[...] 200/4.8
Yes. I might pick one up second hand. Should be nice with a SpeedBooster.
Well yeah, of course. And you think a cheap 200/4.8 would be as good as PL 200?
Besides, you can actually get that already by buying Panasonic 100-300 II. It's fairly affordable, reasonably small and lightweight and actually pretty good at 200mm. It's even weather resistant.
So since you can already have that, I assume Belgarchi has something smaller, lighter, cheaper and better in mind.
This is the kind of wishful thinking I have an issue with threads like that. It has to be small, it has to be cheap, it has to offer great image quality.
Yaay, I want a unicorn as well.
But it's not gonna happen.
Well, apparently it's not fine to the poster I replied to. As they, like OP, want it to be both cheap and sharp. And small as well.
OP (unknown member) Veteran Member • Posts: 7,274
Re: Pentax?
DiffractionLtd wrote:
Pentax did it.
And they are thriving, right?
Peter
What has one got to do with the other? Problem is you people don't get where the camera world is going. High-end, high-quality, which means large, expensive lenses, not pancakes. Take a look at nearly every offering from Nikon, Sigma for example. Large, expensive lenses. That's where the profit is, certainly not in camera bodies.
So lets put Olympus to kill all lenses that ain't their PRO lines. All priced to 1299€ at minimum, and some for 3499€.
That certainly will put Olympus on huge profit side...
Who needs any cheap, small and light good quality lenses... Right?
Every beginner should go and buy a camera worth of 2000€ and then add a lenses that each cost one arm...
Or how about buying a camera for 499€ and then nice three-four set of fast primes for 200€ each, to start.... Don't you agree?
That is where the Canon and Nikon core business and profits comes, selling a 499-599€ APS-C camera kits, not FF nor any expensive lenses.
About 350€ for f/1.8 lenses is not cheap, compared that you could get a f/2.8 one for 200€.
17mm f/1.8 = 350€
25mm f/1.8 = 350€
45mm f/1.8 = 240€
12mm f/2 = 670€
Total = about 1600€
So how about:
17mm f/2.8 = 150€
25mm f/2.8 = 200€
45mm f/1.8 = 240€
12mm f/2.8 = 250€
7mm f/2.8 = 350€
Total = about 1200€ (or 850€ if leaving that 7mm possibility away).
So you would get half the price all the same focal lengths, smaller, lighter and more affordable.
Now tell someone beginner to invest 1600/1000€ for lenses as extra over a 630€ for E-M10 III (body only), or to invest a 600/850€ with fast f/2.8 lenses.
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
Re: Maybe if they're for an FF camera
the 2.8 lenses fit where other ones dont.
the 14 and 17mm pancakes are ultra compact.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
SushiRyu Regular Member • Posts: 226
Or how about:
Or:
The Laowa 7.5mm f2 rectilinear costs $500, is tiny and weighs only 5 ounces. I'd love to see Olympus license that design and bring out one of those with autofocus (for the scuba divers on here; hint, hint I dive but haven't bought the UW housing yet).
For the longer lengths I could definitely see a 2.8 being fabulous, 120mm or longer (I'd like 150mm). But to develop new 2.8 lenses in the same lengths that already have the 1.8 primes, doesn't make sense.
 SushiRyu's gear list:SushiRyu's gear list
Olympus OM-D E-M10 III Nikon Z6 II Voigtlander 15mm F4.5 Super Wide Heliar Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 +5 more
17mm f/1.8 = 350€
25mm f/1.8 = 350€
45mm f/1.8 = 240€
12mm f/2 = 670€
Total = about 1600€
So how about:
17mm f/2.8 = 150€
25mm f/2.8 = 200€
45mm f/1.8 = 240€
12mm f/2.8 = 250€
7mm f/2.8 = 350€
If all of those lenses existed on the market at those prices, I'd advise a beginner to spend a little bit more on each lens upfront, because buying the 2.8 lenses will probably mean trying to sell them used when they decide to upgrade to the 1.8 down the line. You don't need to own every focal length prime, you can start with just 1 or 2, and decide to add to the collection in the future.
Skeeterbytes Forum Pro • Posts: 23,186
Dunsun wrote:
For m43 it really is too slow. By the way that's why I do not get any of those 2.8 PRO zooms. For a pure daylight shooting and deep DOF they are OKish.
ish is still okay.
E-M1ii+40-150Pro
cheers,
Rick
aliasfox Senior Member • Posts: 1,375
17mm f/1.8 = 350€
25mm f/1.8 = 350€
45mm f/1.8 = 240€
12mm f/2 = 670€
Total = about 1600€
So how about:
17mm f/2.8 = 150€
25mm f/2.8 = 200€
45mm f/1.8 = 240€
12mm f/2.8 = 250€
7mm f/2.8 = 350€
Or one could get a grey-market 12-35, 12-40, or PL 12-60 for about 600 Euro/GBP/USD. Sure, not as small on-camera, but I'd bet dollars to donuts that one 12-40 is still lighter than the combination of 12mm, 17mm, 25mm, and 45mm.
(pretty even bet actually, a lot of donuts are about $1...)
 aliasfox's gear list:aliasfox's gear list
Olympus XZ-1 Olympus PEN E-PM2 Olympus E-M1 Panasonic Lumix DMC-GM5 Olympus E-M5 II +17 more
For same reason one can say that:
- not to invest to 45mm f/1.8 but to 45mm f/1.2
- not to invest m/3 system but to a FF
- not to invest to any prime lens or premium lens but go straight to the PRO zoom lines
Here is the fancy thing:
People whine loudly and continually how top m/3 camera models are big, heavy and expensive, and that smaller options are not available nor updated like GM1 was about. When then such model is suggested as side to the current only options, it is huge negativity that someone would even dare to suggest smaller than what there is now available, and goes different ways to explain how all is good now. So why to whine at all about prices, sizes and weight so loudly about top models?
People as well whine loudly and lengthy how m4/3 top lenses are big, heavy and expensive, and smaller options that brought them to the system are not available, like the pancake options and the small zooms like 12-50mm but in better quality or long reaching affordable zooms reaching past 300mm. And now when someone again even dare to suggest to have a alternative option for even cheaper and lighter but still high quality primes to be available, it is lengthy explanation that everything is just fine right now and nothing needs to be done to the "low end" category. So why to whine about current lens sizes, weights and sizes when there is no need for different options?
1041 really shows that there is nothing good enough, as majority is whining about everything that there is or that could be. Nothing is about right, can't be changed, can't add anything alternative as next to ones, nor make anything new.
Sergey_Green
Sergey_Green Forum Pro • Posts: 12,058
F1.4 would be like F2.8, which is what most standard zooms for other (larger) systems are, including 3-rd party lenses as well. That should probably be the goal, to convince the potential buyers of the real weight savings. If there is any.
- sergey
jaeae Regular Member • Posts: 284
"If there is any" --> yep, there isn't much.
It's like zero-sum game, you can counteract FF sensors in MFT world using very fast glass and the same time ending up with just as big and expensive system.
If one wants small system, something has to give.
