My em5 image stabilization wants a focal length...for m43 lenses: Why?
Started Oct 17, 2018 | Questions
OliverHasanOlympus Regular Member • Posts: 115
The manual says that for m43 lenses my e-m5 shouldn't need me to input a focal length in the image stabilization settings, and so I don't think the menu should be letting me do that while an m43 lens is on the camera. But it's letting me today, I noticed, both with my Olympus 12-50 kit lens and with my 75-300, which is likewise Olympus m43. I wonder if my camera is not properly reading lenses, of if there's some other setting somewhere that I don't know or don't remember, which makes the camera think I want to do this manually every time I adjust the zoom.  Does anybody recognize this issue or have a theory they think might help? I'd be grateful!
 OliverHasanOlympus's gear list:OliverHasanOlympus's gear list
Olympus E-M5 II Canon PowerShot S1 IS Canon PowerShot SX260 HS Olympus OM-D E-M5 Panasonic Lumix G 20mm F1.7 ASPH +7 more
IanYorke Veteran Member • Posts: 5,266
Re: My em5 image stabilization wants a focal length...for m43 lenses: Why?
You have a faulty camera!  Clean the contacts on both the lenses and camera body and see if that helps.
Ian
Denjw
Denjw Veteran Member • Posts: 6,853
Are your lens working okay and what brought this to you attention? Does the camera actually request this?
Have you used a non-m43 lens on the camera recently and used the Lens Info Settings?
On the E-M1MkII the IBIS menu still allows you to input a focal length manually even if a m43 lens is attached.
 Denjw's gear list:Denjw's gear list
Olympus E-300 Olympus E-30 Olympus E-5 Olympus E-M1 Olympus E-M1 II +17 more
JMftrnr
JMftrnr Regular Member • Posts: 100
Hi,
my pana Gx8 has Focal Length Set in the menu for the stabilizer. If it is set to on, the camera always ask for the lens FL.
if it is off, then it must be automatic; if not, may be one dirty electrical contact between lens and body.
 JMftrnr's gear list:JMftrnr's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Samyang 7.5mm F3.5 Fisheye Olympus M.Zuiko Digital ED 60mm F2.8 Macro +7 more
Soulhand Senior Member • Posts: 1,467
5
I checked on my E-M10ii and it also lets me set the focal length when a M43 lens is attached
There is no problem here. It's just letting you set the value and will use it when you next attach a manual lens. It doesn't mean it's using it when you have the M43 lens attached.
 Soulhand's gear list:Soulhand's gear list
Olympus PEN E-PL5 Olympus E-M1 Olympus E-PL7 Olympus OM-D E-M10 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +10 more
OP OliverHasanOlympus Regular Member • Posts: 115
Thanks to all of you with the info that it's the same situation with the menus for you. I guess that's enough to allay my concern. I'm just getting to used to shooting with a long heavy lens, and it's seemed to me over the last few week that I haven't been able to get as sharp an image of the moon as when I first got the lens. Tonight I tried a slightly less flimsy tripod than I had a few days ago, and I saw clear no improvement. I didn't feel like I'd learned anything from trying different apertures and ISOs and shutter speeds either. Then I selected the IS (on the Super Control Panel) and maybe for the first time--or first in a long while--I saw the gray message "Focal Length INFO", pressed the INFO button and found that I could actually change the number in the box...FWIW. It seemed like a sudden change in my IS would explain why my moon photos seemed to have become suddenly less sharp. But being forced to reject this explanation is a lot better than finding my camera is defective. Thanks again.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
The "Focal length INFO" thing is there as a reminder that is the way to set the focal length for any dumb lens that may be attached at some later stage. The regular M4/3 lenses of course do this automatically for you.
As for that moon thing, start with a typical daylight setting for exposure as the moon is lit by the sun and more or less follows the old "sunny 16" rule. That means a tripod is hardly necessary, just careful hand-holding with IBIS doing the needed stabilising and depth of field is not an issue so use the lens wide open or close to that. Sadly around 1/30 to maybe 1/500 sec then shutter shock may also be an issue.
Regards.,... Guy
buratino
buratino Contributing Member • Posts: 929
stabilization adjustment - possible?
what if I put, say, oly A-200 1.5x converter on the Oly lens, say, 45mm 1.8? Any chance to get the stabilization adjusted accordingly or no luck?
 buratino's gear list:buratino's gear list
Panasonic Lumix DMC-GF7 Panasonic Lumix DMC-GX85 Panasonic GX850 Olympus M.Zuiko Digital 45mm F1.8 Rokinon 7.5mm F3.5 UMC Fisheye CS +9 more
drj3 Forum Pro • Posts: 12,632
Moon images are much more a function of atmospheric distortion than the camera/lens/stabilization.  I have images with my old not very sharp FTs 70-300+EC14 on a clear night that are sharper than many of my MC14+300mm f4 images taken on typical nights.
drj3
 drj3's gear list:drj3's gear list
Olympus E-510 Olympus E-5 Olympus E-M1 Olympus OM-D E-M10 Olympus E-M1 II +13 more
buratino
can one override the automatic setting?
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Apparently, not. I discussed this in this thread.
https://www.dpreview.com/forums/thread/4330087
I think this would be a simple firmware fix but it is very unlikely to happen.
Allan
ahaslett
ahaslett Forum Pro • Posts: 12,654
Are you using spot metering on the moon?  Is it blown out or just hazy?
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
aliasfox Senior Member • Posts: 1,375
If your camera's properly reading the focal length of the m4/3 lens, the focal length should appear in the upper right corner of the screen/EVF - at least it does that on my bodies (E-PM2, E-M1i, E-M5ii). If it's showing up properly, I don't see a reason why the camera would need manual input.
 aliasfox's gear list:aliasfox's gear list
Olympus XZ-1 Olympus PEN E-PM2 Olympus E-M1 Panasonic Lumix DMC-GM5 Olympus E-M5 II +17 more
Guy Parsons
Why would you need to change the setting away from the correct value?
Regards...... Guy
buratino
Regards...... Guy
I got Oly A-200 1.5x converter to put it on Oly 45mm F1.8 lens.
Guy Parsons
OK, the setting will be wrong, but that will only really start to possibly cause problems when slower than (guess) about 1/100 sec. Test all shutter speeds to find out where it starts to over-correct and remember that all stabilisation results depend on the individual and how they handle the camera. If in doubt, stay with faster shutter speeds than about 1/100 and keep stabilisation off.
Regards....... Guy
Smith-64 Regular Member • Posts: 364
Test
Take some pictures with each of your m43 lenses at several focal lengths. Look at the EXIF data and see if the lens data is recorded correctly. If it is no problem.
A. C..
 Smith-64's gear list:Smith-64's gear list
Olympus E-M1 II Olympus 14-150 F4-5.6 II +1 more
Allan Brown
Regards....... Guy
I ran into the problem with my 45-200 + tubes + close-up lens.
The problem is not taking the photo, it is holding the lens stable to frame and focus on the object.
If it were possible to change the setting for the IBIS to some value other than "normal" for the lens, things would be better.
I can do this with the same tube + close-up lens but with an adapted mechanical lens - my Nikkor 105mm f2.5.
So, the method works but not with native lenses.
Allan
Allan Brown wrote:
Regards....... Guy
Allan
Well, I guess then, if you were willing to shoot all manual and give up focusing to infinity for no other reason than to customize your IBIS, you could just insert a cheap dumb tube/ spacer between your m43 lens and your camera.
M_digicapt Veteran Member • Posts: 3,289
Overriding automatic IBIS setting?
Regards...... Guy
I would also like to override the automatic setting when I'm using adapters like an Afocal TC. Also when using the wcon because the wide angle option in my E-M10 doesn't let me adjust many settings, it's like a modified Auto mode...
Regards
