How do you handle optical stabilization on Olympus cameras for zooms?
Started Oct 15, 2018 | Discussions
Dave Andrade Contributing Member • Posts: 587
Potentially a strange question, and I will admit that I am just more curious than anything else.
I know that on the Olympus cameras, such as the EM5 Mark 2 that I own, you can enter the focal length.
This is great for primes. And potentially zooms, if you set your length and leave it there. But let's say you're out shooting birds or other wildlife and want the ability to adjust the focal length. (such as the 100-300mm Panasonic, for example. And yes, I know that lenses has stabilization. So does the 300mm Olympus. But the 40-150 f4-5.6 doesn't for example)
Do you go through the laborious task of setting the OS for whatever focal length you're using? Or do you just leave it alone, as we all did in the past with non-stabilized sensors and lenses?
I know.....I know....this question almost answers itself. but I was just curious how others approached this.
 Dave Andrade's gear list:Dave Andrade's gear list
Panasonic Lumix DC-S5 Panasonic Lumix S 85mm F1.8
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
Re: How do you handle optical stabilization on Olympus cameras for zooms?
I think it's not necessary with most M43 lenses - perhaps except manual ones and any others that don't communicate the FL details to the camera?
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
Olymore
Olymore Senior Member • Posts: 1,939
5
M43 lenses tell the camera what focal length they're on.
This would be a problem with legacy zoom lenses that have no electronic contact with the camera, used via an adapter.
There are 10 types of people.
Those that understand binary and those that don't.
Beware of Geeks bearing Gifs
 Olymore's gear list:Olymore's gear list
Olympus E-M1
OP Dave Andrade Contributing Member • Posts: 587
Yes, you are both correct.
I guess, now that I think about it, it's a moot point.
I have a 80-200mm 2.8 lens, and I guess there's not much of a choice. Either set it, and use that ONE length, or just hope you have steady hands if you zoom around.
FWIW, trying to shoot birds with a legacy lens might be quite the feat anyway (not that no one photographed birds before the stabilization technology appeared though, I know that)
Skeeterbytes Forum Pro • Posts: 23,182
Yes, that's the rub with adapted legacy zooms although for BIFs and sports the shutter speed should render IS moot. It's critical however to make sure you don't have IBIS on with a bad FL entered--I think my E-M1ii came set for the body cap fisheye or somesuch, which would make IS go nuts with a tele.
For experimentation sake, maybe pick the zoom's midpoint as the IS value and do tests across the range so see how it does. My hunch is that accurately matching the FL becomes less critical as the FL gets longer. If it still buys you a stop or three of handholding then it's worth having it engaged, otherwise switch it off.
Rick
ahaslett
ahaslett Forum Pro • Posts: 12,654
You can change the FL quite quickly from the IS option on the SCP.  Mine is set for my fisheye, which is the only non electronic lens I use regularly.  I'm guessing it would become almost instinctive, if you had to change frequently.
You could also turn IS off.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
Andrew
Great points to both of you (Skeeterbytes and ahaslett.
I hadnt thought about putting the middle point as the FL. Might be worth a try.
And you're right Andrew about the SCP. I was thinking of trying to assign a function button, but I have ones that I use for each of them. the SCP might be a nice workaround.
Thanks again! I'll experiment with those!
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
a little off topic but related
So, I was playing with my 45-200 and a set of extension tubes that have the electrical contacts.
The problem is that the camera still sees the lens as 45-200 rather than the, lets say,  "equivalent" focal length - i.e. the higher magnification. The IBIS was totally useless.
There does not seem to be any way to adjust the focal length setting for this combination.
Any suggestions other than taping over the contacts?
If taping over the contacts, anyone know which one?
I used to tape over contacts with my Pentax Kx and some lenses.
Allan
Re: a little off topic but related
Allan
Oly or Panny body? Is it possible the IBIS and OIS were "fighting"? What happens when you select either IS system by itself?
Have use the Oly EX25 tube with various 4/3 lenses and IBIS has no issues with the close focusing distances--focal length remains the same of course.
Good luck!
Rick
mad-marco New Member • Posts: 19
I have the E-M1 II and the Pana Leica 50-200.
If you have the body set to auto IBIS, then this will automatically be switched off and on in response to what the lens OIS is set to.
i.e. OIS off - IBIS on, OIS on - IBIS off
I didn't manage to get both switched on at the same time.
 mad-marco's gear list:mad-marco's gear list
OM-1
Allan Brown
Allan
Good luck!
Rick
It is an EM5 II and I have it set to ignore OIS and use IBIS all the time. Also, the OIS switch on the lens was OFF.
I realise that the lens focal length remains the same with the tubes but the magnification increases. Setting the IBIS to, say, 500mm, probably would work.
I do this all the time with my Nikkor 105mm f2.5 and close-up lenses and it works. However, this is an all-manual setup with no electrical contacts.
Allan
tt321
tt321 Forum Pro • Posts: 13,854
If your 80-200/2.8 is a new AF type, there may be adapters/focal reducers that would let it AF on mFT. If this is the case, the focal length might also be conveyed through the adapters or at least the lens' OIS should work on its own if switched on, because the lens would be supplied with electric power.
If it is a manual lens then you need to set the FL on camera each time you change FL, in theory. In practice, this is not as onerous as it sounds, because the worst thing about this is you might forget about it. However, with half-press IS on, you can see whether the IS is working correctly or not. If the change of FL does not affect the IS too badly you would see nothing to object to when aiming. If it's bad, the effect could be clearly seen and you can then change the FL setting on camera in response.
Most people work way better in 'responsive mode' than in 'having everything planned and remembered mode'. And this is a case of the former, fortunately.
tt321
Allan
Good luck!
Rick
Allan
I understand what you are trying to do. You still want the AF, aperture, etc. to function properly, but want to disable the auto-IS but instead set the IS focal length manually.
Then it is natural to think that by selectively taping off some of the pin(s) this might do the trick.
However, data comms between lens and body tends to share wires/pins esp. for digital information, kind of like a serial connection with data sent in packets. If that is the case, this tack would not work. See link below for the non-micro FT as a reference (mFT has more pins). All lens comms protocols I have seen have shared single wires in the same transfer direction. In that case, you need to chip your adapter to selectively interpret the data. If you can chip your adapter, you might as well program it so that the right correction is always translated anyway.
This kind of smart adapter to maintain IS correctness only for macro is not worth building commercially, because it's too much hassle to license the IP from Olympus just to gain such a very small market.
http://preamp.org/revenge/four-thirds-communication-protocol
I'm now very tempted to just get a real macro lens so that IS can work properly.
