Fujifilm XF 18-135mm vs XF 18-55mm + XF 55-200mm for travel photography
Started Oct 11, 2018 | Questions
pt9 New Member • Posts: 19
I was wondering if any one had recommendations for a a great travel lens to use with the Fuji X system. I usually take either landscape pictures or personal travel pics.
Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR (Weather Resistant) Lens
VS combination of
Fujifilm XF 18-55mm f/2.8-4 R LM OIS Zoom Lens and
Fujifilm XF 55-200mm (83-300mm) F3.5-4.8 R LM OIS Lens
Any other suggestions or choices?
dv312
dv312 Veteran Member • Posts: 9,214
Re: Fujifilm XF 18-135mm vs XF 18-55mm + XF 55-200mm for travel photography
On travel trips you want to avoid changing lenses as to not miss the decisive moment
So the 18-135 is your trusted friend
I came back from a VN trip with the other 2 and immediately bought the 18-135 for next travel trip
I just didn't have the time to swap lenses so ended up shooting with the 18-55 most of the time
Either that or use 2 bodies with different lenses on each
The 18-135 being WR is quite suitable for all weather, genres
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 1.4x Teleconverter Sony FE 200-600 F5.6-6.3
sluggy_warrior Veteran Member • Posts: 3,204
I always think of the 18-135 as 18-90mm. Beyond 90mm is still OK but too soft and inconsistent for me. I brought both the 18-135 and 18-55 on my Hawaii trip, ended up using the 18-135 only for hiking and daylight, the rest is 18-55 (street, indoor, night, ...)
Personally, I can't afford switching lens in the middle of a hike/walk-around, so I usually choose ahead and leave the other lens in the car or my backpack.
On my last trip to LA, I brought only the 18-55 and didn't miss the 18-135 at all. I don't plan to sell the 18-135 though, as I know I'll still want it for serious travelling, at least for now. The 18-55' size is perfect on the X-T20, its' sharp and wide enough for low light. VR is really good, can frequently shoot handheld at 1/2s.
If you can swap lens easily then the 18-55 + 55-200 will give better range and IQ. For me, the convenience of a single lens is more important so I'll lean toward having just the 18-135, or even just the 18-55.
Troubleshooter
Troubleshooter Regular Member • Posts: 405
Go for the XF 18-135mm for travel photography
The 18-135 is my always on the Cam lense! I love the Output it delivers - all over the zoom Range. And I love it’s flexibility... No need to carry and change between different lenses, when hiking, biking or backcountry skiing! Yes, the 55-200 has more tele, but the 50-230 has even more - at the same IQ (as long as you have the light).
In dusty or wet and stormy regions, it is great to avoid changing lenses! That is when the 18-135 is the best choice. Used it a lot in SouthAfrica and Island! (And for sure during outdoor aktivities mentioned above!)
Just be sure to compare 2-3 of the 18-135 lenses, as sharpness on the long end can vary extremely between the lenses!
 Troubleshooter's gear list:Troubleshooter's gear list
Fujifilm X100T Fujifilm X-T1 Fujifilm X-T3
j tokarz Senior Member • Posts: 1,387
I have all the lenses you have + a couple of primes. The ONLY lens i use is my 18-135mm and a wide angle 12mm . Thats all. To me its a brilliant lens. All i could want.
Geekapoo
Geekapoo Senior Member • Posts: 2,831
In general, multi purpose lenses like the 18-135 are a compromise. Slower and softer, especially on the long end. You can somewhat compensate for the softness by stopping down the lens.
Myself? I've used enough of these type of lenses and steer clear of them..the quality is not what I like/want. Your experience and expectations may differ. Optically, they tend to be compromised (too much in a small package). Why put a 2nd rate lens on a great camera? Remember, ultimately it's all about the glass. Buy and use the best glass you can find if possible.
Maybe these reviews will be informative:
http://www.opticallimits.com/fuji_x/888-fuji18135f3556
https://www.imaging-resource.com/lenses/fujinon/xf-18-135mm-f3.5-5.6-r-lm-ois-wr/review/
 Geekapoo's gear list:Geekapoo's gear list
Sony RX10 IV Fujifilm X-E3 Sony a7R IV Sony a9 II Sony 35mm F1.4 G +15 more
VinceC Senior Member • Posts: 1,324
18-135
I've had all 3 lenses (now sold the 18-55).  For travel the 18-135 is a good size and weight, very flexible, water and dust resistant, has good stabilisation, and produces good images across both the focal length and aperture ranges.  Mine has been around Europe and to Alaska and Chile.
Airline restrictions on hand luggage encouraged my initial decision - and I've never regretted it.
Best regards
Vince C
 VinceC's gear list:VinceC's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Panasonic 100-300mm F4-5.6 II Panasonic 14-140mm F3.5-5.6 II +4 more
baobob
baobob Forum Pro • Posts: 18,248
I have bothh confuigurations
The choice between the two could be related to weight and size but also abilkty to safely change lens
The 18-135mm is a very good alrounder zoom, I have been using it now for years and even if it does not match other Fuji XF lenses it still delivers very goood to excellent results when  travelling
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
Doug MacMillan Veteran Member • Posts: 3,695
Never used the 18-135. My travel kit is the 18-55, 55-200 along with the 12mm Samyang.
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-E2S Fujifilm X-E3 Fujifilm X-H1 +10 more
Troubleshooter
This might answer your questions...
https://www.flickr.com/gp/chorge1972/m2A95h
All images shot with the XF18-135 (or some with the Samy 12/2). For my purposes when traveling more than enough IQ...
ninjagowoo
ninjagowoo Regular Member • Posts: 251
I ended up selling my 18-135 because the IQ just wasn't there. Nowadays I travel with the 16-55 and 50-140 (and maybe a prime for low light) since the weight doesn't really bother me. After a lot of lens juggling I arrived at the realization that if I'm going to bother lugging a 'serious' camera with me then I'm mostly doing it for the IQ (and maybe zoom reach). If photography were less important I would just use my phone or x70 and call it a day.
 ninjagowoo's gear list:ninjagowoo's gear list
Fujifilm X-H1 Fujifilm X-T5
jonikon Veteran Member • Posts: 7,433
sluggy_warrior wrote:
I always think of the 18-135 as 18-90mm. Beyond 90mm is still OK but too soft and inconsistent for me....
You appear to be a good candidate for the upcoming 16-80mm f4!
Jon
Jerry-astro
MOD Jerry-astro Forum Pro • Posts: 19,920
It’s interesting reading all the different answers so far in the thread with very different observations and opinions... some of which are diametrically opposite. My own experience with the 18-135 — which I rented for a period of time — was less than excellent. Long zooms like this are always a bit of a compromise, and as others have reported here, anything much above 90mm or so will suffer somewhat in terms of IQ. That said, the convenience might very much outweigh a small sacrifice in IQ depending on what you’re shooting, how much detail you’re dealing with in your images, and how picky you are about your final IQ.
I found the 18-55 to be an excellent lens with great IQ throughout its range. If most of your shooting is within that range, I might suggest that you might be better off going with that lens and then augmenting it with a tele, such as the XF 55-200 or XC 50-230, the latter being more of a consumer grade lens. There are plenty of choices and your decision will likely end up (as it always is with lenses) to be a tradeoff between IQ and budget.
BTW, the upcoming 16-80 f/4 might also be an excellent candidate if you can wait a bit.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
celestialemissary
celestialemissary Contributing Member • Posts: 795
18-135 is only lens from fuji that I did not like.
It's big and really not that sharp from 70mm+ corners are terrible
I hike with two lenses
16mm and 50mm f2
Sometimes only 23mm f2
So for me 18-55 would be the only lens I need.
You can keep 55-200 in the bag for those times you need a longer lens.
https://www.instagram.com/tst4nic/
 celestialemissary's gear list:celestialemissary's gear list
Ricoh GR Digital IV +1 more
If you can wait till next year then get the Fujinon 16-80mm f/4 which will be the ideal travel lens in the Fujinon lens line. Every single lens solution available right now is a compromise and changing lenses just to get beyond 55mm is a real PITA.
Jon
celestialemissary
Yeah I wait for that one but still changing lenses is not that big of a deal
and I only have prime lenses...
baobob
As you know I am a permanent defender of the 18-135mm Interestingly depending on reviews results are either average wit Photozone or on the contrary very good to excellent
https://www.ephotozine.com/article/fujifilm-xf-18-135mm-f-3-5-5-6-r-lm-ois-wr-lens-review--25914
So, as often, I think there are quite big sample variations. Obviously mine belongs to the top of the basket
This lens is well adapted for trekking light, fast AF 1:1 ratio reprod with a 150 Raynox Bonnette at 135mm with no vignetting and 5 stops OIS
Yes you cannot compare it to the Fuji primes but with a little of PP (clarity, sharpening)) you can easily lower the gap between very good and excellent
Last but not least highly recommended to spare your vertebras
Geekapoo
Jerry-Astro
May I suggest an alternative to the 18-135 (which is still quite limited for long reaches. Use the Fuji and also buy a bridge zoom. I have owned the Panasonic FZ1000 and now have a Sony RX10 IV. My X-T3 and the 10-24 and 18-55 give me good coverage from 15-80 and the Sony is spectacular wide open, even at 600mm. The Fuji, two lenses and the Sony RX10 IV are a relatively light travel kit. Oh and the AF for both cameras is great !
Jerry-astro
Geekapoo wrote:
Jerry-Astro
Certainly for some folks, that’s a very reasonable alternative.  I’m not personally a fan of hauling multiple kits around, even if one of them is fairly compact, and prefer to use a single body (for the most part... at least when traveling) and select lenses as needed.  But, that’s just my preference and I can see where folks who only need a longer zoom occasionally might prefer not investing in an expensive tele, but would would rather use a superzoom instead.
Jerry-Astro
Jerry-astro wrote:
Geekapoo wrote:
Jerry-Astro
Agreed. Although, I think if somebody is OK with the quality of the bridge camera, then s/he probably don't even need the bigger sensor/lens, and thus, would be OK with just the bridge camera alone which covers the whole big FL range.
