Depth-of-Field Preview - EOS R
Started Oct 10, 2018 | Questions
Phil-LA New Member • Posts: 11
Hello,
I just received my Canon EOS R. I shoot mainly with the compact camera Canon G1X Mark III and this is my first mirrorless camera.
No need to say that I am a beginner and would need some help about the Depth of Field Preview please.
- With the G1X Mark III: When I half press the shutter button, I see a preview of the exposure as well as the actual depth of field, which is very convenient.
- With the Canon EOS R: When I half press the shutter button, I get to see a preview of the exposure but not the actual depth of field. The depth of field display is always for the maximum aperture of the lens and I have already enabled the Exposure Simulation.
My knowledge is quite limited and I don't understand.
- Why is that different from the G1X Mark III? Why can't the EOS R close the aperture when half pressing the shutter button?
- Is it possible on the Canon EOS R to get a preview of the actual depth of field when I half press the shutter button ?
Thanks for your help 😁
kevinertia
kevinertia Junior Member • Posts: 28
Re: Depth-of-Field Preview - EOS R
You have to assign DOF preview to a custom button. The shutter button is not an option for this, so you will not be able to replicate the behavior that you're accustomed to as far as I know. See pages 137 and 555 of the manual for more information.
 kevinertia's gear list:kevinertia's gear list
Canon EOS 5D Mark IV Sony a7R III Canon EF 135mm F2L USM Canon EF 35mm F1.4L II USM Sigma 85mm F1.4 Art +6 more
OP Phil-LA New Member • Posts: 11
Thank you for your reply Kevin! Yes, I already read the manual.
- Am I expecting too much from a mirrorless camera or is it Canon intentionally limiting its functionalities? 😅
- Do you have the same behavior with your Sony mirrorless for example?
I also find the exposure to be somewhat inconsistant vs my G1X Mark III. Auto WB is better thought.
gakhar New Member • Posts: 13
7
Is this how all mirrorless cameras work? I was under the impression that the other brands showed DOF preview as part of the EVF? Thanks in advance!
ThePointblank Regular Member • Posts: 119
The Canon EOS R focuses with the aperture wide open; this is partially the reason why the EOS R does so well focusing in low light.
Most other mirrorless systems operate fully stopped down when focusing.
 ThePointblank's gear list:ThePointblank's gear list
Canon EOS R Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 100-400mm F4.5-5.6L IS II Canon EF 50mm F1.8 STM +1 more
am2am Junior Member • Posts: 37
well - in low light every mirrorless camera will focus with aperture wide open - unless you force different aperture manually
Personally I found it strange choice but maybe its just me. I prefer sony's DOF preview implementation
KrisAK Contributing Member • Posts: 845
No. I've seen handled differently in different cameras, even within the same brand.
zonoskar Contributing Member • Posts: 550
There is a very big upside to the way Canon is doing this. The maximum amount of light is available for the AF system, so it also works in almost complete darkness. Not so with the other brands. Besides, why would you want DoF preview? I have never used (well, actually once to check if the button works) this function on my 5D.
 zonoskar's gear list:zonoskar's gear list
Canon EOS 5D Canon EOS M Canon EF 17-40mm f/4.0L USM Canon EF 100mm f/2.8 Macro USM Canon EF-M 22mm f/2 STM
pauljames34 Regular Member • Posts: 407
I'd find that really annoying getting a dim DOF preview with a half press of the shutter button!
 pauljames34's gear list:pauljames34's gear list
Canon EOS 5D Mark III Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM +5 more
lawny13 Veteran Member • Posts: 3,132
What you said there is wrong. The sonys at least focus stopped down no matter what amount of like there is. You can only shoot wide open to get wide open focus..,
What they will do is focus initially wide open and immediately stop down with live view preview off. So in AF-C it will try to do continuous focus stopped down which will end up resulting in CDAF hunting if the light is low enough. Sony doesn’t allow you to turn this behavior off.
I was not precise enough so to clarify my previous statement.
I know sony will focus stopped down if aperture is set-up this way. I understand  the difference in canon's implementation. And I agree this is superior AF solution (have both sony mirrorless and canon DSLR at home and did compare AF in low light) but there is trade off in live view DOF.
My message is the following: in most low-light cases it doesn't matter.
Any camera will try to maximize amount of light captured in low light situation. With auto-iso engaged and shutter speed defined you'll end up with fully opened aperture anyhow.
With aperture priority photographer makes a decision - in my case I always go wide open low light unless I have to achieve particular affect (very rare scenario).
Re DOF preview implementation - it's probably individual taste and preference - I found it really useful to see constantly how my final picture will look like in sony EVF. My photo's taking technique evolved partially thanks to this - I've realized I spend less time on AF and  focus more  on the composition and the final picture effect.
I do not despute the pros of having stopped down focus. I just loath the fact that on Sony systems you can not turn it off.
In low light or for macro photography having the system focus wide open and only stop down when fully depressing the shutter is ideal, while in good light or when you don’t need to work fast one can take advantage of stopped down focus. I will give you 3 scenarios.
1. If you have a scene that demands you stop down to f11 and beyond, the sensor is deprived from too much light and you immediately have CDAF over PDAF. Let’s day you want a slow enough shutter sleep to have some motion in there. Or you are shooting video and you don’t have an ND filter and you are shooting at 1/25.
2. You are at a party or dinner and you want to shoot at f3.5 up to f6.3 to catch enough people in focus. Ideally you want as fast as possible AF to catch those candidate fleeting moments but the DOF you want.
3. Last but not least. MILC is at a major disadvantage to DSLRs when you consider flash photography. You can be in a room without light and still get perfect and instant focus with IR assist. You set your aperture based on what your photo to look like since you have the flash to provide the amount of light you need to keep ISO low. Though the EOS R doesn’t have the IR AF option either the fact is that with wide open focusing and that -6EV rating it will be far superior than to any other MILC system out there in low light situations with a flash on board. Heck I would say that for AF-C it even beats DSLRs since IR AF is a AF-S kind of thing.
If you don’t see any value in any of the above then ignore me. But the fact is that I have been saying for years that Sony can solve this easy but putting look up tables in their lenses to fix their focus shift issue and they still haven’t done it. Canon comes out and does this on the getgo because they get exactly what I have been saying. Once you get enough experience I can ball part my f-setting for the DOF I want. I rather not cripple my AF for 30% of my shooting situations.
YMMV
willcasp New Member • Posts: 1
Allowing the user to program the half press of the shutter button as Depth of Field Preview would be super handy. For some reason, this option is not allowed!
I am using the AE lock button for now,
 willcasp's gear list:willcasp's gear list
Canon EOS-1D X Mark II Canon EOS R
On a Canon DSLR, the DoF preview is a separate button near the lens.
You could set the multi-function touch bar as DoF preview... that's a good option, as it is right by your thumb when shooting.
Ciriaco Garcia Regular Member • Posts: 353
That is not always true. The Sony cameras may also focus wide open, but this is a relatively complex subject:
https://www.fredmiranda.com/forum/topic/1554180/
 Ciriaco Garcia's gear list:Ciriaco Garcia's gear list
Sony a7R III Canon TS-E 17mm f/4L Sigma 35mm F1.4 DG HSM Art Canon EF 24-70mm F4L IS USM +1 more
I have tested this with the 4 lenses I had (including the kit), and to me there is just two tests that really really matters.
1. Set live view update off. Set camera to AF-C, Press the AF-On button.
Behaviour: initial focus is done wide open (or at least partially so), and the lens immediately stops down and tries to do the rest of the focusing stopped down. If the light and f# setting means CDAF... well too bad for you.
2. The same is done with AF-S, but it stopped AF once obtained.
Extra behavior to note. With AF decoupled from the shutter button (for back button focusing) press the shutter half way and the camera will stop down for AE anyway. So rather than be able to just calculate and simulate the exposure it also stops down.
So... no matter what you do you will starve the sensor of light, and you have no option to turn this off. So, dinner parties and nigh events, kids parties, or any less than ideal amount of light and you have to shoot wide open to maximize AF performance. It is a shame you can’t have the best AF performance while stopped down. After all a scene were you want f4 for example doesn’t necessarily mean you can’t benefit for f1.8 aperture for focusing. Every experience photographer doesn’t need DOF all the time since they can estimate pretty well what will come out, or assess this at first. And you definitely don’t need DOF preview when shooting at 10 FPS and tracking since you won’t be paying attention to this.
al404
al404 Contributing Member • Posts: 827
No way to have DOF live preview without pressing an assigned button on RP?
I think this is one of the huge advances of mirrorless...
 al404's gear list:al404's gear list
Fujifilm X-T3 Fujifilm X-T5
Huge advantage is relative.
Currently you have to different camps.
1. stopped down focusing from sony (but this is forced, as in you can't have it any other way).
2. Wide open focusing which is what canon does.
Pros for the Sony side, is what you see is what you get. Obvious advantages there.
Pros for canon is that you never compromise the AF system when shooting as you always get maximum light.
I have shot both systems. And if I had to pick I would go with the canon approach. Come dim light situations and the AF system suffers needlessly. I care less for DOF than getting in focus images at the setting I want rather than the convenient setting for the system's AF but not the settings I want.
Some I can easily have a situation where I want an image at f5.6 shutter speed 1/30 with a 50mm lens, and ISO 1600 because I want more DOF. And for a candid moment I want the AF to focus quick wide open @f1.8.
HOWEVER, I wish canon would give us the option for both. In good light the AF system shouldn't have a problem. And if it can AF in video with @f11, I don't see why it can't do it in stills. They just need to give us that option. Sony on the other hand has the issue that it incorporated forced stopped down focusing because when they introduced their GM lenses they had significant focus shift, so it was their "fix" for that. Before that FW update you could turn it on and off.
JustUs7 Senior Member • Posts: 4,327
On the RP, I programmed the movie record button next to the shutter for DOF preview. I’m not using it when shooting stills otherwise.  I’m also using AF-On for focus.
Thumb on focus. Quick peak at DOF if I need it. Then half press for meter and shoot.  Works for me. I can find movie record without looking now, so it’s muscle memory.
 JustUs7's gear list:JustUs7's gear list
Canon EOS 1000D Canon EOS Rebel SL1 Canon EOS RP Canon EOS M6 II Canon EF 75-300mm f/4.0-5.6 III +10 more
al404
I also did the same thing, reaped video recording button to DOF preview but is really annoying.
Not sure I did understand:
1) rec for DOF
2) AF lock for back button focusing
3) half press shutter for metering
is correct? I did try before the AF desynchronized from shutter button but did not really work for I may give it a try again
I think Sony approach is way better, or at list you should have an option to chose from
I also had Fuji I don't exactly remember how did it work but I guess with half press it update the DOF and keep it or maybe it was always live... not sure
I think Canon approach is kind of outdated, what you see is what you get I think is a much modern one ( at least for me )
since I really like to play with DOF in my photos is a really important aspect on how camera it works
