Panasonic 3D1-Katydid Close up
Started Oct 9, 2018 | Discussions
threed123
threed123 Senior Member • Posts: 1,490
I took this MPO pic about 1 foot away. The pocket-sized 3D1 does a great job as a macro 3D camera if you are willing to work with it. I'm posting a universal view with alignment straight out of the camera. You can freeview the left two and crosseye the right two. Also am including an anaglyph. Since there is mostly green in the image, anaglyph does quite well. I am also including an adjusted anaglyph crop. Look at these on a big monitor for a "wow" experience. They really hold up well. I did some sharpening, not much, though. To give you a reference, the Katydid was about 1.5" long.
3D1 - Katydid. Freeview the left two images, and crosseye the right two images.
3D1 - Katydid. Anaglyph using the alignment straight out of the camera.
3D1 - Katydid Anaglyph cropped and adjusted to push back into the 3D window. Reduced ghosting.
Panasonic Lumix DMC-3D1
