Minolta A1 - Firmware Update
Started Oct 9, 2018 | Questions
Carpn New Member • Posts: 2
Hi, can anyone help I'm bringing my old A1 back into use for some Astrophotography and would like to update the cameras firmware, currently it's version 1.02e. I know Minolta did some firmware updates beyond this and that Sony took over the support for a period of time.
any help was to where a can get the firmware from would be helpful, im running windows 7 if that's required.
Thanks in advance
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Minolta A1 - Firmware Update
Welcome to the forumĀ
The final version is 1.12e and is available here ; https://www.touslesdrivers.com/index.php?v_page=23&v_code=9120
When you click download a new window will open with three seperate links you can click , forget the Minolta server as they've dropped support , but the other two links are still valid .
Doesn't matter which windows version your running as you just un-zip the firmware to the desktop ( for e.g) , format the cameras CF card in the camera , put it in a card reader and and copy the firmware onto the card and insert it into the camera to update .
Make sure you have a good , fully charged up battery in the camera , or connected to the AC-DC adapter .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
OP Carpn New Member • Posts: 2
Thank you so much, very very helpful thanks again, I've downloaded it so now just need to update
(unknown member) Forum Pro • Posts: 15,443
I'm a bit late to the thread, but the final A1 firmware seems to be 1.13e (A1V113E.EXE) (or 1.13u (A1V113U.EXE), depending on region).
http://download2.konicaminoltaeurope.com/openmind/technic/kmphdwl.nsf/ftsearch?openagent&ch=CAM&dist=BEU&ui=EN&dg=fw&prod=DiMAGE%20A1&dsg=&os=&lang=English&ml=00&rid=&sub=&pcat=&pcc=0&fr=0&frs=
Patco
A photograph is more than a bunch of pixels.
neilt3
Indeed it seems to be .
When this thread started Minolta had pulled the plug on the downloads .
Must have been a glitch on the system for some reason , as at some point down the line all had reappeared .
Down load while you can .
