New Canon 85mm f/1.2 L Mk II Lens - some questions, please help
Started Oct 8, 2018 | Discussions
rowancastle New Member • Posts: 4
Hi All,
I just purchased this lens and it arrived today. As usual I'm just doing some very basic checks on it to make sure all is OK, as this is a big investment for me.
I would be grateful if anyone who owns this lens could reassure me on the following:
1. With the lens off the camera, the focus ring rotates extremely easily (really easily!). The index scale also doesn't move as you rotate the ring. I've done a bit of research and it seems this is normal because the lens is 'focus by wire'. Does your copy behave the same?
2. When I opened the box, the lens pouch was in the top cardboard compartment along with the instruction / guarantee leaflets but was not wrapped in plastic packaging. I'm pretty sure every other Canon L lens I've bought has had wrapping around the pouch but I can't remember. Do you think this is normal or might it suggest the lens is ex-display?
3. The lens code indicates it was manufactured in October 2017, a full year ago. I just bought it from one of the leading web retailers in the UK. Does that length of time between manufacture and sale seem a bit odd?
Many thanks for any help
Rowan
 rowancastle's gear list:rowancastle's gear list
Canon EOS 5D Canon EOS 5D Mark III Canon EF 16-35mm F2.8L II USM Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 100mm F2.8L Macro IS USM +2 more
Scott Larson Veteran Member • Posts: 7,505
Re: New Canon 85mm f/1.2 L Mk II Lens - some questions, please help
1. Yes.
2. Don't remember.
3. If the lens works, then why care how long it sat around?
 Scott Larson's gear list:Scott Larson's gear list
Sony RX10 IV Canon EOS 5D Canon EOS 5D Mark II Canon EOS-1D Mark IV Canon EOS-1D X +17 more
expro Senior Member • Posts: 2,274
Add: one year is not long at all in fact for this specialist lens could easily be longer.
you’ve just bought an amazing lens so go out and take some great shots!
 expro's gear list:expro's gear list
Canon EOS R3 Canon RF 24-70mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM Canon RF 14-35mm F4L IS USM
J A C S
J A C S Forum Pro • Posts: 20,544
This lens has focus by wire. This explains the focus ring. Put in on a charged camera to see something moving.
I believe that the pouch is never wrapped but I do not remember well.
BlueRay2 Forum Pro • Posts: 14,816
non of my "L" lenses i had purchased, had the pouch wrapped up in paper or anything else as far as i can remember. i have about 12 "L" lenses, i would have remembered at least one if the pouch was wrapped up in the box
Who are you gonna believe, me, or your lying eyes? Groucho Marx.
John_Hoffman
John_Hoffman Senior Member • Posts: 2,245
https://www.youtube.com/watch?v=NpPKoraQv9o
John Hoffman
Conway, NH
 John_Hoffman's gear list:John_Hoffman's gear list
Canon EOS-1D X Mark III Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 8-15mm f/4L Fisheye USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
J A C S
Now, I think that the pouches came wrapped all the time, contrary to what I wrote above,
OP rowancastle New Member • Posts: 4
Hi thanks for the replies,
I just checked the box from my other recently purchased lens - the TSE 24mm Mk II, and the lens pouch was still wrapped in its plastic packaging.
I'm rather suspicious now that this lens has been used and returned by someone else.
I guess I will check with the retailer and Canon tomorrow.
Thanks again.
Rowan
John Hoffman - thanks so much for the link to the unboxing video. This confirms that the pouch should have been wrapped and nested in a polystyrene tray - both of which are missing.
Definitely something fishy going on here. I'll be returning it tomorrow!
Thanks again.
Rowan
Arthur Stanley Jefferson Contributing Member • Posts: 809
Just curious...
What made you pick the 85 1.2 over the 85 1.4? Thanks
If it was  from a retail shop, they might have only got it out to show it to a customer, but sending it through the post without the internal polystyrene packing isn't a good idea. Was it well packed besides that?
Ps. There is currently £220 Canon cashback on the 85 F1.2 if bought from their listed dealers. Google Canon cashback 2018.
 Arthur Stanley Jefferson's gear list:Arthur Stanley Jefferson's gear list
Canon EOS 5D Mark III Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon EF 100mm f/2.8 Macro USM Canon EF 70-200mm F4L IS USM +4 more
hermit383
hermit383 Contributing Member • Posts: 728
Just to add to that:
Put the lens on the camera with the lens switched to MF for it to focus when turning the ring.
With the lens switched to AF, the ring will only focus the lens after the camera has been locked onto a subject in One-Shot AF.
 hermit383's gear list:hermit383's gear list
Canon EOS-1D X Mark II Canon EOS 5D Mark IV Canon EF 50mm f/1.2L USM Canon EF 85mm F1.2L II USM Canon EF 200mm f/2L IS USM +6 more
hermit383
Re: Just curious...
Not to hijack your question intended for someone else haha.
But I personally prefer the 1.2 for the overall image. Bokeh hands down is better with the 1.2. Also, to my personal rendering preferences, the 85 1.2 is sharper and has better image fidelity to me even wide open.
Thanks again for your help everyone - decided to keep the existing lens in the end because CPS assured me that this packaging arrangement is not uncommon. Nothing wrong with the lens itself so that's the main thing.
Rowan
apersson850 Senior Member • Posts: 2,078
Personal preferences is one thing, and they are, by definition, personal.
But if you just look at optical performance, then the EF 85 mm f/1.4L IS USM beats its brother, the EF 85 mm f/1.2L II USM, without a doubt. Add the stabilizer and the significantly faster focus operation to that, and the f/1.2 is trailing far behind. It's obviously better at one thing, though, and that's opening up to f/1.2.
Quantifying the bokeh is very difficult, so I'll refrain from that.
Anders
 apersson850's gear list:apersson850's gear list
Canon EOS 40D Canon EOS 400D Canon EOS 7D Canon EOS-1D X Canon EOS-1D X Mark II +26 more
grinbo New Member • Posts: 6
I have the same thing about lens pouch. But with EF 35mm F/1.4L II USM. I've asked Canon about it. Aswer was - it's ok.
nonproshooterdad Senior Member • Posts: 1,106
I like this lens too. I got my first copy several years ago. That one was marvelous on bokeh. I had a Sigma non art to compare with it. The Sigma at 1.4 can compete with it at 2.8. Its sharpness wide open was just enough, but the bokeh really shined. My second copy was not so impressive. And my current copy shines in another way, it's really sharp wide open. I also had a Sigma non art ( different copy than the one I used before) to compare with this copy, the bokeh was pretty similar. Canon maybe a bit better, I didn't really compare with different apertures.
So there are copy variances with the lenses, same to the Sigma.
