Sigma SDQH is changed to canon EF and can auto focus
Started Oct 8, 2018 | Discussions
mengaza Regular Member • Posts: 172
Finally, I get my SDQH after sending to modification.
 mengaza's gear list:mengaza's gear list
Sigma DP2s Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro +9 more
OP mengaza Regular Member • Posts: 172
Re: Sigma SDQH is changed to canon EF and can auto focus
Take with SDQH + tokina 11-16 f2.8
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
mengaza,
Why change to Canon mount ?
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
Ceistinne wrote:
mengaza,
S
I just want to try. I can have more choices of lens.
new sigma lens is heavy. and SA mount near the end.
EEvan
EEvan Regular Member • Posts: 343
How much was it. How long did it take?
goblin
goblin Veteran Member • Posts: 3,752
And who did it Conurus ?
 goblin's gear list:goblin's gear list
Ricoh GXR P10 28-300mm F3.5-5.6 VC Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp2 Quattro +73 more
MOD Kendall Helmstetter Gelner Forum Pro • Posts: 20,587
Nice results, are there any particular lenses that led you to switch mounts?
 Kendall Helmstetter Gelner's gear list:Kendall Helmstetter Gelner's gear list
Sigma 70-200mm F2.8 EX DG OS HSM Sigma 8-16mm F4.5-5.6 DC HSM Sigma 24-70mm F2.8 EX DG HSM Sigma 50-500mm F4.5-6.3 DG OS HSM Sigma 85mm F1.4 EX DG HSM +4 more
Scottelly
Scottelly Forum Pro • Posts: 18,026
Ugh. I thought that was supposed to be a good lens.
Scott Barton Kennelly
http://www.bigprintphotos.com
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
Scottelly
mengaza wrote:
Ceistinne wrote:
mengaza,
S
Canon EF is near the end too, but I like that you did it. I think it's a great idea, and I'm surprised you can get auto-focus. The 50mm f1.2 L on that camera would be cool, as would the TS 17mm f4 L and many other Canon lenses.
Scottelly
Very cool. Have you tried many Canon lenses yet? What lenses? How was the auto-focus? Did it work like a Sigma SA mount lens or more slowly? How is auto-focus accuracy?
Shawn67 Senior Member • Posts: 2,310
That is awesome. The SA mount was basically Pentax mechanical mount with Canon EF flange distance and electrical protocol but maybe on a different pin out.
Do you have any Canon lenses with OIS? Does that work too?
Shawn
The speed of AF is almost as of SDQH SA mount
Image stabilization is work
modification about 170 USD, it takes about 2 weeks for modification.
link of modifier:  https://item.taobao.com/item.htm?spm=a1z1r.7974869.0.0.269c3ad4eBwsIF&id=572097378847
There is green cast problem for some lens.
I tested several lenses
No green cast problem:
-tokina 11-16 f2.8 AT-X pro
-canon 16-35 f2.8II
-canon 135 f2 L
-canon 50 f1.8 stm
-canon 24 f1.4LII
-tamron 24-70 G2
Have green cast problem:
-canon 85 f1.2L II
-tamron 17-35mm F/2.8-4 Di OSD (Model A037)
-canon 50 f1.2L
-tamron 45 f1.8 VC
I post my shots a the comment of my post in this page https://www.facebook.com/groups/SigmaClubThailand/
Sigma SDQH with canon 35/2 IS:
https://www.flickr.com/gp/mengazaa/ZY3H2B
SDQH with tokina SD 11-16/2.8 DXII ATX PRO:
https://www.flickr.com/gp/mengazaa/8v5cy2
Scottelly
I love the look of the background in the images from that 35/2 IS lens. I bet you have been using that lens a lot, huh? I can imagine getting the mount changed, just to use that lens. Sigma doesn't offer any normal focal length prime lenses with IS, and 35mm on the H is just about perfect, if you ask me.
I'm not a fan of that 11-16, but I like how it covers the sensor. That's really interesting. I don't think Sigma makes a lens that wide which covers the whole sensor. Still, the 8-16 offers a wider view in crop mode.
Yes, I like canon 35/2 IS, it sharp, have IS and lightweight.
I dont't like sigma which not produce lightweight prime lens(f1.8 or f2 are ok for me) with IS.
As sigma user which usually use ISO100, IS is very important.
Tokina 11-16 is sharp lens but AF is very slow and sometimes can't AF (not sure, my lens have some quality issue?)
The 10-20 f3.5 covers the whole sensor by 11mm. The earlier 10-20 does not.
Shawn
docmaas
docmaas Veteran Member • Posts: 7,061
Are you sure IS is working?
I have both an SD1 and SDQ modified by Wei Duan and it was my understanding that is does not work on either sigma mount canon lenses or on canon lenses.  I'm pretty sure I read this in the xitec fora on users using his conversions in China.
I've never tried it though, partially because of this understanding/belief.  Maybe it is a new feature though as far as I knew Wei Duan's conversions do not involve chip mods which I believe are necessary to accomplish IS functionality.
If you really are seeing IS support I may have to get an IS lens to try it out?
Mike
"For me, photography is only an artistic language. The camera is my pencil. -- Charly Ho
"At every crossroads on the path that leads to the future, tradition has placed 10,000 men to guard the past."
Maurice Maeterlinck
Scottelly
Shawn
Thanks for the info Shawn. I think I'll stick with the 8-16 though.
Acutance newbie Junior Member • Posts: 40
Would you have access to Zeiss lens that has great micro-contrast? It would be interesting  to be able to compare that with a Sigma lens of the same focal length.
 Acutance newbie's gear list:Acutance newbie's gear list
Sigma DP1 Merrill Sony a7R Sony a7R III Canon EF 135mm F2L USM Sony 24mm F2 SSM Carl Zeiss Distagon T* +8 more
rf-design
rf-design Contributing Member • Posts: 619
-canon 16-35 f2.8II
-canon 135 f2 L
-canon 50 f1.8 stm
-canon 24 f1.4LII
-tamron 24-70 G2
-canon 85 f1.2L II
-canon 50 f1.2L
-tamron 45 f1.8 VC
Thanks for reporting,
1. Is there any EXIF info transfered to the X3F file?
2. Did you consider to edit the lens entry in the custom EXIF file to trigger the color cast correction in SPP for pictures taken with lens where you oberserve the cast?
3, Do have a comparison of resolution of the Tokina 2.8/11-16 in H-mode to the Sigma 4.5-5.6/8-16mm in APS-C mode or crop mode?
 rf-design's gear list:rf-design's gear list
Sigma DP1 Panasonic LX100 Sigma dp0 Quattro Sigma SD9 Sigma SD10 +68 more
