Choice between X-T and X-H series, all things being equal
Started Oct 8, 2018 | Polls
Peetz Forum Member • Posts: 70
If the X-T3 had IBIS, and the forthcoming X-H2 received all the X-T3 improvements, which would choose?
I started this poll because of Kai Wong's review where he said that, if the X-T3 had IBIS, there'd be no need for the X-H series.
POLL
X-T3 with IBIS
72.1% 49  votes
X-H2 upgraded with all the X-T3 goodies
27.9% 19  votes
  Show results
Fujifilm X-T3
dual12 Senior Member • Posts: 1,276
Re: Choice between X-T and X-H series, all things being equal
Kai is wrong. Some people prefer the larger body, shutter release, sturdier construction, and top LCD of the X-H1.
 dual12's gear list:dual12's gear list
Fujifilm X-E1 Fujifilm X-E3 Fujifilm X-H1 Fujifilm X-T3 Fujifilm GFX 50R +10 more
OP Peetz Forum Member • Posts: 70
I'm curious. If you prefer larger bodies, why stay with APS-C? Why not go to Full Frame?
Sal Baker Forum Pro • Posts: 11,560
Fuji doesn't make one.
Sal
 Sal Baker's gear list:Sal Baker's gear list
Ricoh GR Fujifilm X-E2 Fujifilm X-T100 Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +3 more
I didn't state that I preferred a larger body. But don't discount that most FF lenses are much larger, and there's little difference in image quality between FF and Fuji APS-C. If I need better image quality, I'll use medium format, which is a more obvious difference.
Phil1 Senior Member • Posts: 2,398
Coming from a T2 I chose the H1 over the T3 because for me, for the sort of things I shoot, the H1 has a better balance of features (these differences are well documented elsewhere). In adition it feels very solidly built.
Between a T3 with IBIS (if that were posible) and an H1 I'd still go for the H1.
Phil
tmorterlaing Junior Member • Posts: 47
Some serendipitous timing with my post perhaps: https://www.dpreview.com/forums/post/61764690
TLDR is Im staying with the H1 even though I have both in my hands right now.
Based on the poll results, it seems Fujifilm should work to miniaturize IBIS for the X-T4, by learning some tips from Sony's A6500. And then dump the X-H series.
I hear the people's reasons for liking the X-H, but as the mirrorless wars heat up, I think people who like heavy cameras may not be as loyal to Fujifilm as those users who like compact, smaller cameras.
People who like whopping big cameras have the option of going to Nikon, Canon, Sony, Pentax and Lumix - whereas people that choose Fuji for light weight are less likely to jump ship to the heavier brands.
7
Kind of frustrating the amount of people who compare the H1 to the T3 in a way that makes the H1 out to be just a thicker T2 with IBIS. .
Everyone seems to forget the other myriad of advantages the H1 has which for some are a really big deal. The H1 has the same EVF as the T3  (upgraded from the T2). Compared to the T3, the H1 is better built, it will take more of a beating and can deal with heavier lenses. It has better (subjective) ergonomics. It also has a leaf spring shutter which is far superior to that of the T3. (It also comes with a nicer eyecup, which is a non-issue, but still a point).
If they made an X-H2 it would *not* just be an X-T3 with IBIS and a slightly thicker body. It would be better than the T3. So, ditching the H series doesn't seem likely, as the H series is their flagship range, not the T series.
The main question is, why didn't the H1 have the T3 processor? Some odd timing there...
Everaert Regular Member • Posts: 132
Why does it have to be an OR choice between T and H?  I have both and use them for different purposes.  And no I will not simply go FF or DSLR as the current FUJI offering allows me to use the same lenses on both bodies.  Nor does adding IBIS to the T series obviate the need for the H imo.
 Everaert's gear list:Everaert's gear list
Fujifilm X-T4
dv312
dv312 Veteran Member • Posts: 9,262
Not sure if IBIS would sway me over to the XH2
I'm perfectly OK with OIS lenses
I still prefer the smaller body + optional Arca grip which is more useful to me than just a huge grip without Arca
The top LCD is a welcome feature but not a deal killer
The smooth shutter is nice to have but XT3 ain't bad to start with
The XH build is better but the difference is like a Panzer vs a Tiger, both can withstand abuse for many moons
Now what I 'd like to see in both is a new battery capable of at least 900 shots (read Sony A9) and maybe a better LCD a la Nikon Z
And last but not least a way to add custom settings to a function button or my Menu (been waiting for firmware release on this for many moons)
 dv312's gear list:dv312's gear list
Fujifilm X100F Sony a1 Sony 2.0x Teleconverter Sony 1.4x Teleconverter Sony FE 100-400mm F4.5-5.6 +1 more
Jerry-astro
Jerry-astro Forum Pro • Posts: 20,535
Puh-leeeeze!
Exaggerate much? “Whopping big?” There’s about a 40% difference in weight between a similarly outfitted X-T3 and a 7DMkII (1665g for 7DMkII plus 17-55 f/2.8 vs. 1194g for X-T3 plus 16-55). Add about 130g to the equation if you want to compare the X-H1, and the difference still remains huge. So, join the group of people here who like to exaggerate and overposition the size issue here.
I totally get the fact that some folks prefer more compact cameras and might find the X-H1 to be less comfortable to hold and carry than an X-T3, for example. I have no issue with that. I do have an issue with trying to compare the size increase of the X-Hn series as putting it in the same class as a DSLR and using terms like “whopping big” to describe it. Thanks just plain bunk, IMHO.
Jerry-Astro
Fujifilm X Forum Co-Mod
 Jerry-astro's gear list:Jerry-astro's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H2S Fujifilm XF 8-16mm F2.8 XF 150-600mm Canon Pixma Pro-100 +1 more
Joachim Gerstl
Joachim Gerstl Veteran Member • Posts: 9,198
True, but what have the romans ever done for us?
 Joachim Gerstl's gear list:Joachim Gerstl's gear list
Sony RX100 IV Fujifilm X-Pro2 Fujifilm X-Pro3 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +6 more
40daystogo Regular Member • Posts: 377
Re: Puh-leeeeze!
It depends what is your reference point. I like small cameras. I came from the Sony A6000, and initially found the X-T2 to be on the largish side. That's compared to the Sony A6300 and A6500 which are all under 500 grams even with IBIS.
I liked the Fuji X-T20 size and weight, but chose the X-T2 because of the larger EVF.
torppapa Contributing Member • Posts: 747
Because of lens size maybe?
 torppapa's gear list:torppapa's gear list
Canon PowerShot A700 Canon PowerShot G10 Canon PowerShot G9 Canon PowerShot G15 Fujifilm X20 +111 more
Re: The H1 is not 'whopping'!
When I unpacked my H1 I was expecting quite a large camera, but sitting it alongside my T2 with the (non-battery) grip it didn’t seem any different in size and the weight was about the same too (just a minuscule 62g heavier).
So let’s not get carried away – the H1 is not ‘whopping! In fact it is about half the weight of the pro Canon & Nikon cameras!
For some, but not all, purposes the H1 is superior to the T3. It all depends on what you need. Just because you like what the T3 offers (and it is very considerable) please don’t think that everyone else has the same photographic needs as you!
Phil
Canadianguy Senior Member • Posts: 2,951
Re: All things being equal?
All things being equal - I would much prefer the X-H# over the X-T# body. Fits better in my hand, shutter is much dampened, stronger lens mount, stronger body, top display screen, IBIS.
But things are not equal - the X-H# has a $300-400 USD premium on it. Although the things mentioned above are nice to me - I just don't thinks its worth the price premium to me.
Jerry-astro
Well, now that’s a very different kettle of fish.  Most of the arguments here have been around the X-H1’s “huge” size and additional weight, which as I said previously, comes across to me as just bunk and overpositioning, IMHO.  However, the price difference is indisputable and then it simply comes down to value and your own needs.  I personally really like the handling and feel of the camera, particularly with larger lenses, and IBIS is highly beneficial for much of the photography I do when traveling — often in low light situations.  Thus, the $300-400 USD premium is absolutely worth it... to me.  Whether that applies to you or others is a very individual thing and all the arguments in the world won’t convince someone who can’t see the benefit as justifying the additional cost.  So, arguing the point, as many seem to want to do here, makes little sense, since the notion of value is really very much an individual thing.  That’s why it’s great to have choices.
Jerry-Astro
VariableScope
VariableScope Contributing Member • Posts: 564
I disagree. The H series is interesting BUT I agree that Fuji needs to differentiate it more.
Whether they add IBIS to the T4 or not, there's other things to add to the H2
- BIGGER BATTERY. Make it a proper pro level camera
- Flip out screen. This is gonna be the top end video camera correct? This is IMO a must have feature for this. Also of course, add the headphone jack on body like the T3.
- Additional video/audio interfaces on accessories: Remember the GH4 had a YAGH video interface attachment. Add this as a bottom grip style accessory that will add SDI and XLR input/output for more options for video creators
- Additional flash controls to match high end Nikon and Canon offerings
- Eff it. Built-in GPS/GLONASS for geotagging.
 VariableScope's gear list:VariableScope's gear list
Fujifilm X-H1 Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Fujifilm XF 16mm F2.8 +3 more
