The Leica Q2 is a fixed-lens, full-frame camera sporting a new 47.3MP sensor and a sharp, stabilized 28mm F1.7 Summilux lens. It's styled like a traditional Leica M rangefinder and replaces the hugely popular original Leica Q (Typ 116), launched in 2015.
Z7 overheating with long video
I have been really enjoying getting to know my new Z7. Awesome camera.
One issue I am hitting is shutting down from over-heating during long video shoots. I use an Atomos Ninja Flame with 10-bit NLog HDMI output from the Z7. After 60-90 minutes, the Z7 shuts itself off from overheating. Ambient temp is reasonable (around 70-73 degrees) and the Z7 is open to air for ventilation.
Has anyone else experienced this? Any tips on how to handle?
Not stretched it that far at all but it may be an external or N log issue. As it seemed to be Ok internally from here ..
https://youtu.be/ekke2klnR9w?t=106
Instagram @vinnypimages
This is troubling since I'm getting the Z6.
I'm no video guy so take this with a grain of salt...
But it seems to me that the OP's use case is really pushing the camera to an extreme that most will never reach (and that's OK). We're talking about filming straight for 60-90 minutes at the highest resolution output. Again, to me that seems to be stretching it quite a bit. Most people I know who are into video film short segments at a time and then put it together in post.
Obviously the OP has his own use case and that is fine. I am not in any way trying to discredit the OP. And if the camera does overheat at such an extreme, that may be a problem for some.
But I would caution anyone jumping to conclusions, because it is just a sample of one and again it may be an operating condition that most will never get to.
Was that HD or 4K output?
But the ambient temperature is a very temperate 73F. One wonders how it will handle 90 and 100F, which are routine in the NE and SW U.S. and many other parts of the world.
I have heard of overheating. And the link to the video above showed consecutive videos with no overheating. Perhaps this an issue with this camera only. At any rate, this post will undoubtedly spur more user tests.
Are you sure it's not the 30 min max limit set in the firmware so the camera will not be classified as a video camera avoiding additional import duty imposed on video cameras?
There is no limit when using an external recorder.
i shoot the D5300 as a vid cam with the atomos ninja 2.
Not if it’s your wide b cam shooting a long event. And he doesn’t say if it’s continuous or after 60-90 mins of shooting segments. I got that from shooting a lot of segments with the V2.
Wedding and event video shooters will care.
Sorry - you are making a significant usage error, though what you report can be correct after several successive video sessions.
I presume you are making successive videos as the maximum recording length is usually 30 minutes.
Memory cards and batteries heat up with continuous prolonged use.
There are warnings about this on pages 35 and 197 of the En version of the camera manual.
Electronic VR and movie log output consume extra power.
Using either the viewfinder or rear monitor a fresh battery is likely to run out before 90 minutes is reached - En User Manual page 230
Sorry - to the best of my knowledge any DSLR from any manufacturer is at risk of switching off due to overheating if used continuously for video for an hour or more.
Leonard Shepherd
In lots of ways good photography is much more about how equipment is used rather than the equipment being used.
Why?
So far there is nothing to suggest the Z7 gets hot enough to switch off taking video than other Nikon or other brand DSLR bodies.
If using a DSLR for an hour or more recording, ideally 2 bodies are already needed as recording usually stops after 30 minutes.
Leonard Shepherd
so I take it that shooting stills for 13 hours no break streaming live to a uhd monitor as well as using the evf at the same time in 36deg c is out of the question ? shooting raw and h jpeg
Don
Olympus EM5, EM5mk2 my toys.
http://www.dpreview.com/galleries/9412035244
past toys. k100d, k10d,k7,fz5,fz150,500uz,canon G9, Olympus xz1
I have been using 4k @ 30fps 10-bit N-Log--so yes, pushing the camera hard. I have not tried other video settings, but perhaps at lower resolution the Z7 won't overheat.
A battery grip will defiantly help. and only use the grip battery.
Don
https://kolarivision.com/nikon-z7-dissasembly-teardown/
no heatsink/cooling mechanics whatsoever inside Z7.. so no surprise it will will overheat.
Why?
I regularly take 60+ min videos using the D5300. The Z6 will replace this set up.
The thing suggesting the Z7 overheats is this user report from one of the few folks shooting log. That’s not nothing.
Why would wedding videographers care? I was at an hours long Indian ceremony that didnt have many breaks. Having your camera overheat and be dead for 15+ mins as it cools off is really bad even if you are shooting multiple cameras because often you’re shooting multiple angles.
why are you repeating the same incorrect statements about a topic you don’t know anything about?
Unless shooting both internal and external the camera isn’t writing to the card.
If shooting from a tripod you can/should turn off IBIS/VR.
You don’t need to use either VF or rear monitor when using an external recorder because it has a larger screen.
My D5300 shooting to an external recorder lasts 120 min+. Is it at risk of overheat at 60 mins in 73 degrees F?
Nope.
Have you thought of ventilating the back of the camera with some USB-powered fans? Deploy the screen first...
Just an idea...
If you haven’t already I’d turn off EVF and LCD as well as IBIS.
After that there’s not much else you can do beyond using flat rather than log and presumably drop to 8 bit.
Which would be disappointing.
Latest sample galleries
Latest in-depth reviews
Fujifilm's GFX 50R takes the image quality from the existing 50S model and wraps it in a new body with new controls and a lower price of entry. Is that enough to tempt you to pick one up for yourself? Find out how the GFX 50R performs in our full review.
The Mavic Air hits the sweet spot for many drone users, combining compact size with high performance and good image quality. Find out what makes it so useful, and why it might just be the best travel-friendly drone on the market today.
The Fujifilm XF10 is a stylish, compact, well-priced pocket camera that will take great photographs. Unfortunately, the XF10's overall performance may be a let-down, including for those users coming from smartphone cameras.
The EF-M 32mm F1.4 is a welcome addition to Canon's APS-C mirrorless lens lineup. It's a good performer all-around and enjoyable to use on the EOS M50, and we hope to see more like it introduced to the EF-M range.
Latest buying guides
If you're looking for a high-quality camera, you don't need to spend a ton of cash, nor do you need to buy the latest and greatest new product on the market. In our latest buying guide we've selected some cameras that while they're a bit older, still offer a lot of bang for the buck.
A question frequently asked on the Internet is 'what's the best DSLR?' In this buying guide we've answered that question – but also whether it's the right question to be asking in the first place.
What's the best camera for under $500? These entry level cameras should be easy to use, offer good image quality and easily connect with a smartphone for sharing. In this buying guide we've rounded up all the current interchangeable lens cameras costing less than $500 and recommended the best.
Whether you've grown tired of what came with your DSLR, or want to start photographing different subjects, a new lens is probably in order. We've selected our favorite lenses for Sony mirrorlses cameras in several categories to make your decisions easier.
Whether you've grown tired of what came with your DSLR, or want to start photographing different subjects, a new lens is probably in order. We've selected our favorite lenses for Canon DSLRs in several categories to make your decisions easier.
