Lumix G7 shutter time
Started Oct 7, 2018 | Discussions
judyb Regular Member • Posts: 149
When I press the shutter button, there is about a 3 second period before I can take the next photo.
I've got camera set on regular jpeg, use UHS1 card. When I tried V60 didn't make any difference. Have image settings on 7meg.pixles.
Camera is new to me so I'm looking at different menu settings to see what I can change.
Also have GX85 & when I use 14-140 lens with it, there is no delay, press the button, photo taken immediately.
Same lens on the G7 & there is the approx 3 second delay.
Have I missed something in settings?
Thoughts?
Thank you
Panasonic Lumix DMC-G7 Panasonic Lumix DMC-GX85
Mark9473 Veteran Member • Posts: 6,428
Re: Lumix G7 shutter time
Is the shutter delay function activated in the menu? Or the self-timer?
Mark
 Mark9473's gear list:Mark9473's gear list
Canon G1 X II Panasonic Lumix DMC-G6 Panasonic Lumix DMC-GX85 Panasonic G85 Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +21 more
OP judyb Regular Member • Posts: 149
will check
thank you
stateit
stateit Senior Member • Posts: 1,741
I turn the 'review image' off.
I bet you've got it set to 3 seconds, or thereabouts.
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
I don't think that one matters.  Shutter overrides review.
Recent and not so recent pictures here https://trevorc28a.wixsite.com/trevspics
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
Think I found something with my g7
The self timer can be set to 10 or 2 seconds before taking photo
I've looked at submenus & can't find way to turn off self timer
Yes on top left side I have button on single photo notnntimer option
2 seconds is about time from pressing shutter to when photo taken
So next step seems to be how to get timer to shut off option
Just posted what I found there is no menu option to turn off self timer
Lowest setting about 2 seconds which is what the delay is
Thoughts?
Trevor Carpenter
Thoughts?
The mode dial top left is switched to self timer.  You want it at the other end of the dial for single shot.
it is set on single shot, after setting it I turned camera off, pulled out battery, put battery back in & turned camera on.
Still is in 2 second self timer mode.
In Menu settings shows 2 or 10 seconds, no "off"
Nothing in info site on Panasonic support that remotely covers this.
Head scratcher
There's no "off" setting in the menu; only the dial does that.
Mark
Mark
Nothing changed when I turned dial from timer to single photo
That's what is curious
Nothing on Panasonic site about this
Thanx for reply
alcelc
alcelc Forum Pro • Posts: 19,006
Sure to have the right "mode dial" setting?
P.181 of G7 pdf user manual
You select the "Single" instead of "Self Timer" ? For Panasonic cameras, Single shot and Self Timer can not co-existed.
G7 use a different way to control the Drive Mode than GX85.
GX85 use the Down of 4-ways control to set Drive mode. P.134 of GX85 pdf manual.
Albert
Do any other positions from the drive mode dial not work either? It's starting to look like you've got a defective dial.
Mark
yay I found solution.
in a menu, there's button for Auto Review, set it to off & wonder of wonder
now photos taken instantly
when I did message chat with Panasonic, tech said he was escalating to next tier.
fun troubleshooting
alcelc
fun troubleshooting
If auto review be the cause, I suppose it might worth to know that no matter under what situation, after a shot, when we half hit the shutter again auto review will be cancelled and returns to standby shooting mode.
I have my auto review switched off. Before that, I also had auto review on but set it to hold. I used to touch the shutter after a shot if I have no interest to review that shot...No delay for my next shot.
Albert
Trevor Carpenter
fun troubleshooting
crazy, my auto review has been permanently on  on every Panny I have owned and it never stops the use of the shutter nor should it.
