OP
TN Args
An adapter should work well. Not perfectly, but well.
Tom Caldwell wrote:
Messerschmittbf109 wrote:
That is awesome, I wonder if Sigma is planning to release some of their zooms as well. I would love to switch to Lumix S1r, but I need my beloved 12-24 Art. Once they do that I am in!
I believe that there will be SA and EF adapters to L mount made by Sigma which will be the identical size, similar combined weight, and most likely identical functionality to remounted new lenses previously made for other mount systems.
The only practical difference would be that one might be a universal adapter for all lenses made for that particular lens mount and the other would be an “adapter” built into each remounted lens.
Think it out - it is not rocket science. If I was designing an electronic lens suitable for many different host mount systems I would make my interface to drive my own lenses to my own standards terminating in a known set of contacts. Then for each mount system I would assign their individually translated protocols (as known) to the common Sigma lens protocols.
The process must be almost identical whether it inside a purpose made and attached “new end” or inside a mountable adapter made for the same purpose.
Indeed it is not rocket science, yet your conclusion is not right. Sigma have clearly stated that an adapted lens will not perform as responsively as the same lens with an inbuilt native mount. The reason is protocol translations, as you have rightly mentioned.
So, an L-Mount Sigma 85 Art prime (for example) will out-perform an EF-Mount Sigma 85 Art prime plus an EF-to-L adapter. With any luck, this will only occasionally be noticeable.
Plus, the double flange tolerance on the adapted setup will slightly soften the edges. This would only occasionally be visible.
If Sigma would deliberately cripple their adapter then it must be entirely on their own head as third party adapters are bound to emerge soon enough.
The main difference would be that a Sigma lens made for (say) EF would have already translated the Sigma lens common driving protocols to EF mount protocols and the adapter would have to further translate these to the L-mount protocols. Whereas the new L-mount lens end would simply do one direct translation Sigma internal -> L-Mount. Unless they were “lazy” and simply took the internal EF translated connectors and re-translated them into L-Mount in the same way as the adapter might do.
Whatever method adopted the speed delay in the translation process who be hard to measure. Maybe some of the finesse might get “lost in the translation” but for all practical purposes I think that adapted Sigma EF to L mount could hardly seem different in any practical sense from the same Sigma lens remounted as L-Mount.
Yes, it will seem similar, but if you want the best the system has to offer, native L-Mount lenses are the only way to get it.
An Inconvenient Truth, perhaps.
