Z7 raw compression observations
Started Oct 6, 2018 | Discussions
Richard Costin
Richard Costin Regular Member • Posts: 173
5
I always check and compare the raw compression modes when I get a new camera to make sure my current thinking of shooting 12 bit compressed still holds.
Initial results hold true for the Z7 with an interesting caveat on the banding that’s appears when unrealistically pushing the black areas above any real world levels. 12 bit mode seems to all but remove it...
https://www.richardcostin.com/post/2018/10/nikon_z7_raw_tests_001/
Richard Costin
Wildlife Photographer
www.facebook.com/richardcwildlife
 Richard Costin's gear list:Richard Costin's gear list
Apple iPhone X
Nikon Z7
Bohemien
Bohemien Contributing Member • Posts: 737
Thanks!
Thanks for doing this test, very interesting!
 Bohemien's gear list:Bohemien's gear list
Nikon Coolpix A Nikon D600 Nikon Z6
rambalmur Forum Member • Posts: 50
Re: Z7 raw compression observations
I just tested this myself and yes, though the banding appears to be removed, there is a significant DR penalty for shooting in 12bit mode. There is a significant green shift when lifting shadows that does not appear in the 14 bit file. This is the same behaviour I noticed on my D850 which stopped me from using any of the reduced resolution modes (which also appear to default to 12 bit).
 rambalmur's gear list:rambalmur's gear list
Sony a7 III Sony a1 Nikon AF-S 105mm F1.4E ED Nikon AF-S Nikkor 58mm f/1.4G Nikon Z 35mm F1.8 +6 more
Jack Hogan Veteran Member • Posts: 7,991
If the shift is there in 12 bits and not 14 aotbe, I would guess it is probably due to an incorrect black level.
Richard Costin
OP Richard Costin Regular Member • Posts: 173
Interesting you are seeing a green shift, what were the conditions/settings you shot under?
As you can see on my example there was no shift.
Richard Costin
Apple iPhone X
Interesting Richard, I don't know why the banding would be gone at 12 bits.  It's also difficult to know what else LR is doing differently when pushing exposure with different capture setups.
Jack
Here you go.
Both images were made with identical exposures a few minutes apart - + 3.00 EV Push in exposure and +60 shadows using LR. No other changes.
I believe the banding may be being hidden by the excess noise that is introduced by shooting in 12 bit.
Richard Costin
Thanks for the example, I'll try and replicate here.
Seems to manifest in broad/large shadowed areas. Perhaps the compression algorithm treats these differently to shadow areas with lots of variation.
I'll flag this up with Adobe as well and see what they say.
Richard Costin
Apple iPhone X
Richard Costin
Interesting. If I shoot into a black closet I do indeed see some green appearing when pushed back up in post.
This looks absolutely to be related to 12 vs 14 bit (not quite sure why). Compression seems to make no difference in either mode. I usually hate to get to into this nitty gritty as often these things absolutely don't resolve into artefacts that impact my images but this one is worth looking in to.
I will report back once I have talked with Adobe & Nikon. The fact this issue was not visible on my initial test (with lots of details filling the frame) is odd and encouraging. I could understand this with the compression which would vary per image but simply dropping from 14 to 12 bit wouldn't (well shouldn't) introduces new colours so to speak.
Will set to 14bit compressed for the moment until I get some more info.
Thanks again rambalmur for flagging up your observations.
As well, if any of you full on technical chaps that run the in depth sensor tests have any thoughts I am sure we would all appreciate it. I'd love an informed explanation as to what is going on.
Rich.
Richard Costin
www.instagram.com/richard_costin
www.facebook.com/richardwildlife
Apple iPhone X
Rich.
I'm glad you were able to replicate my results. I noticed this issue first when I was shooting the D850. I made the mistake of assuming 12bit images would have the same shadow recovery potential as 14 and shot a couple of important portraits at a wedding working with that assumption. Let's just say they had more black and white images from that set than normal.
I've also run into a number of oddities with banding on the Z7 as well, where I don't see banding in situations I would expect to see it and conversely, see it pop up with a much more gentle push than expected.
Please keep us appraised about what Nikon/Adobe say about this issue and any information about mitigating banding if possible.
Thanks!
Richard Costin
Will do.
I have also observed the issue progressively reduces the higher you turn up the iso and seems gone by about 1000.
Absolutely was not seeing this on the D3, D800. D810 and D500. Less experience with the D850, if this sensor is of the same generation minus the phase sensors then it makes sense it would exhibit it too. This is why I retest with each new camera I use.
Cheers, speak soon hopefully.
Rich.
Richard Costin
Apple iPhone X
Richard Costin
This interesting set of data may be relevant...
https://blog.kasson.com/the-last-word/nikon-12-bit-raw-mode/
Richard Costin
Apple iPhone X
JimKasson
JimKasson Forum Pro • Posts: 38,217
Yes, like the infamous Leica M240 green shadows. Too high a black level results in a green shift near black, because of the relative sensitivities of the four planes in the Bayer matrix. Too low a black level gives a magenta shift.
Posted as a regular forum member.
 JimKasson's gear list:JimKasson's gear list
Leica Q2 Monochrom Nikon Z7 Fujifilm GFX 100 Nikon Z9 Fujifilm GFX 100S +1 more
JimKasson
Will do.
Same as with the M240.
Rich.
Iliah Borg Forum Pro • Posts: 28,883
lossy compression
14-bit lossy is internally coded as 12 bits;
12-bit lossy is internally coded as 10 bits
Is it noticeable on out-of-camera JPEGs?
MOD TOF guy Forum Pro • Posts: 16,805
Re: lossy compression
Is it just a conversion from 14 to 12 bits or does it use the same clever algorithm as before, starting rounding only somewhere in the mid tones and from there always keeping the rounding error lower that shot noise ?
Thierry - posted as regular forum member
 TOF guy's gear list:TOF guy's gear list
Nikon Z9 Nikon AF-S DX Nikkor 12-24mm f/4G ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Sigma 150mm F2.8 EX DG OS Macro HSM +8 more
Yes, I see the green shift in JPEG images, though interestingly there is "banding" as well. 12 Bit lossless compressed also shows the green shift but no banding.
Absolutic
Absolutic Veteran Member • Posts: 5,591
Will do.
Rich.
Hey Richard a little off top, but I have D500 and I see it is on your list.  Did you investigate D500, and are you telling me that I can safely shoot 12bit lossy on D500 and pretty much recover the same amount in Lightroom as I normally shoot with 14bit lossless?   I'd like to shoot smaller files if there is no penalty.
 Absolutic's gear list:Absolutic's gear list
Sony RX100 VI Canon EOS R5 Sony a7R III Panasonic Lumix DMC-GX7 Canon RF 85mm F1.2L USM +11 more
The raw data contained in the NEF file, obviously before linearization (application of NEFLinearizationTable, makernotes tag 0x0096) is 10- and 12-bit, respectively.
