32mm f/1.4 --- Blue Mountains - (PICS)
Oct 3, 2018
23
Canon EOS M6 + Canon EF-M 32mm f/1.4 STM lens
- with optional EW-60F lens hood + 43mm Hoya 'FUSION' Circular Polarizer.
6 locations with the EOS M6 + EF-M 32mm f/1.4 STM lens...
Yesterday I visited 5 rather distant locations in the Blue Mountains National Park with the new 32mm f/1.4 lens- This National Park is located in the mountains just West of the city of Sydney in NSW Australia. I wanted to try the lens out with something more challenging that city architecture and daisies growing along the road. Virtually every shot turned out as expected with just two shots that were out of focus without reason.... I later discovered that one or two of my images were ever so slightly blurred but there was a reason for this...
Problem #1 - WB
A problem I encountered was that there had been a fire-reduction-hazard (burnoff) recently and the plants themselves were showing a lot of magenta hues in the leaves... which produced issues with the camera's White Balance. I experienced something like this quite a few years ago with the Canon G1X and the Pro1 so this isn't a lens related problem. It's related to how Auto WB can shift slightly based on the colors in a scene. If you put the AF reticule onto the blue sky the results were slightly different to when the AF reticule was on the green foliage. Some shots had either too much cyan or too much magenta (in my opinion) so I altered them in Photoshop. I regret leaving the camera set with "Auto" WB instead of selecting (or at least testing) the "Daylight" WB - which is designed for clear sky sunlit scenes like I was shooting in. The colors in the mountains were troublesome for me because of the odd tint in the leaves (see example below). When I was in the city last weekend, I had a lot of white shirts and white ships and white boats in my shots for the camera to more accurately guage it's WB from... but not in the Australian bush.
32mm f/1.4 - The trees and leaves were an off-green with a lot of green mixed with magenta tones. This was taken under the bright sun just before midday.
Problem #2 - ISO button bumped somehow.
Partway through my day I seem to have hit the ISO button and cranked the ISO up to 25000... which was destructive to the images I took in daylight (not shown here). Fortunately I was watching the WB and spotted it before I took more than 8 shots with that ISO setting. This has happened once before when I held the M6 camera via the back end instead of with my hands on the grip. I have a feeling that there's a special "combo" button setting that triggers this since there's no chance I'd ever choose this ISO level.
Problem #3 - ISO issue No.2 - Blurred images (just a couple)
It turns out that my ISO reset itself again from "Auto" to "ISO 100" sometime at around 2pm. I didn't do this intentionally. With the CPL filter on the lens, the camera automatically dropped the shutter speed down to 1/60. Normally this is a safe shutter speed although I prefer 1/100+ where possible if the focal length is longer than 24mm. I was presumably moving slightly when I took several of the shots that were at 1/60 ...and this resulted in two of three images that were slightly (very slightly) blurred. I couldn't tell until I got home. One of the shots that was "soft" from the movement is below (red car on a bush track). You probably won't notice it but it's not ideal. I can happily shoot with this lens much slower (eg 1/40 to 1/50sec) but I'm usually aware of this at the time and brace myself differently. If you're quite still, you can hold it at 1/30sec or even slower... but using a CPL filter with a camera that changed its own ISO for some reason is what complicated things for me. This is why I would have appreciated Canon using an Image Stabilizer on this lens although realistically, I'm sure they didn't expect me to be shooting at ISO 100 with a CPL filter on the lens.
I found myself using the Control Dial far more often with this lens than with any other. I'd scroll to Av to crank the aperture wide for a more shallow DOF or I'd crank it up up to a narrow aperture to increase the clarity of a shot, depending on the subject. Otherwise I'd shoot in P-Mode although the camera seemed to like to hover between f/5.6 - f3.5 for a lot of shots. I picked up quite a bit of dust on the camera's LCD screen and was glad that the Hoya FUSION CPL filter I was using was anti-static and dust repelling.
The six locations I visited yesterday in the Blue Mountains National Park:
* Three Sisters rock formation (at Katoomba)
* Hydro Majestic Hotel (at Leura)
* Govett's Leap Lookout (at Blackheath)
* Mount Wilson (at Mount Tomah)
* Mount Tomah Botanical Gardens (at Mount Tomah)
* District of Bilpin (tractor and vehicle shots)
I expected to see more snakes and birds but apparently Springtime has only just kicked-in here and most of the snakes were waiting for it to get warmer. I looked under a few boulders and rocks for reptiles and insects but found nothing. A 'large' Water Skink (about as thick as your finger) was poking its head out of the top of a stone wall and I caught it by slowly approaching to minimum focus distance (MFD). The shallow DOF was beneficial for separating people and plants from complex backgrounds. With this excursion to the mountains, I was no longer testing for sharpness (which was more effectively established in the city shots I took over the weekend) but for simple versatility.
NOTES:
* Images taken in JPEG
* No crops.
* No additional sharpening was applied during PP
* 43mm Hoya FUSION Circular Polarizer was used on all shots.
* 1400+ images were taken on one battery.
* All shots were handheld.
* EW-60F lens hood was on the camera for protection.
* Shots of bees were taken using Servo AF
* CPL filters can warm up and otherwise enhance colors.
I decided to desaturate the vintage tractor and old Dodge vehicle shots (last images at the end) but retained the shallow DOF from the lens in the Dodge shot. The original unedited images seemed too brightly colored and almost unnatural to look at as Golden Hour began to approach and the sun dropped low. Hope they're of use to those of you contemplating this lens.
My favorite shots below are denoted with an Asterisk "[*]"
A life-sized lizard sculpture on a walking track.
The visitor's viewing deck platforms at Katoomba
[*] Tourist snapping a selfie
[*] "The Three Sisters" at Katoomba - note the burned areas to the right
Large blossoms over my car at the visitor's carpark
Testing DOF with a shrub that was out of reach.
Springtime
Tourists taking selfies.
Viewing platform - from below.
More tourists taking selfies.
The Megalong Valley. There's a drought here at the moment.
Tourists taking in the view from Spooner's lookout.
DOF test
Those selfie-sticks
Springtime flowers - a lovely violent hue.
The logo of the Hydro Majestic Hotel
No hands but they almost ran be down here. It was moving as I took this shot.
View from behind a window at the bar in the Hydro Majestic Hotel
One of the many vintage buildings on the complex.
DOF test.
Daffodil ... I just liked it for the tiny fly (top right).
Arriving at Govett's Leap Lookout at Blackheath.
[*] The View from Govett's Leap Lookout.
Two shot panorama
Vertical shot
Honey Bee
In the middle of nowhere without a snakebite kit or a PLB - (one of the soft images)
Taken while reaching out of my car door window. - note the bokeh swirl
A more intact section of road. - The car is a metallic red that refracts sunlight.
DOF study
The view from the Mount Tomah Botanical Gardens
Another Honey Bee
[*] Small Water Skink checking me out from the top of a stone wall
Yet another Honey Bee
I should have used a smaller aperture (taken in P-Mode)
VERY tiny flowers. Each one was just a little thicker than two grains of rice.
This was for sale
Rust - DOF study
[*] This old Dodge hasn't been enhanced. Nice detail and color from this lens.
[*] Dodge - at f/1.4 - colors were intentionally desaturated. (filled with poisonous spiders.)
I'm sorry to say that the Sydney weather prediction is "rain" for the rest of the week... this will impact my trip to the beach and to the goldfields - which I was planning to test this lens further. I still need to conduct a couple more lowlight tests although I'm better able to grasp now what the lens can and can't do. I think this would make for a great travel lens.
