GRIII Poll
Started Oct 2, 2018 | Polls
MrHollywood
MrHollywood Senior Member • Posts: 3,170
GRIII Poll
Tell us how you feel!
 MrHollywood's gear list:MrHollywood's gear list
Nikon D850 Sigma 35mm F1.4 DG HSM Art Nikon AF-S Nikkor 70-200mm F4G ED VR Nikon 200-500mm F5.6E ED VR Nikon AF-S 70-200mm F2.8E FL ED VR +16 more
POLL
I'm very happy with the GRIII across the board!
39.7% 50  votes
It's not exactly what I wanted, but good enough!
32.5% 41  votes
I'm on the fence big time!
7.9% 10  votes
What was Ricoh thinking? Keeping my GRII!
16.7% 21  votes
I threw up in my mouth over the GRIII!
3.2% 4  votes
  Show results
Ricoh GR III
Tungsten Nordstein
Tungsten Nordstein Senior Member • Posts: 1,968
Re: GRIII Poll
Good idea for a poll. To my memory the first there's been in this forum.
'I don't take photographs, I delete them.'
Tungsten Nordstein, 1999
 Tungsten Nordstein's gear list:Tungsten Nordstein's gear list
Ricoh Caplio GX100 Ricoh GR Digital Ricoh GR Digital IV Sigma dp2 Quattro Ricoh GR II +6 more
MrHollywood
OP MrHollywood Senior Member • Posts: 3,170
Re: GRIII Poll
Probably won't tell us much, but interesting.
Rob
"We need a bigger boat."
Tungsten Nordstein
Re: GRIII Poll
Rob
Well, it does tell us that no one threw up. Or rather that no one admitted to it.
MrHollywood
Re: GRIII Poll
Rob
Yes, Ricoh shooters have strong stomachs!
Rob
Headforthehills Junior Member • Posts: 44
Re: GRIII Poll
I’m in two minds over the loss of the +/- control :
It is the one I use most often for exposure compensation, but it’s also the control that most often accidentally gets nudged.
In the months before the GR-III ships, I’m going to compare the GR-I with a Leica TL 18mm before deciding if the GR-III makes sense any more.
I’m frequently amazed by just how good even the jpegs from the GR-I are ; not sure the Leica  with 18mm is going to reach the same level, but it does win when looking for a 28mm(40) view.
The tipping point with the GR-III might be the VR.
Harold66
Harold66 Veteran Member • Posts: 8,813
Re: GRIII Poll
Rob
Or maybe , it is because that fifth option is a silly one which does not show the difference with the fourth one.
H
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR Ricoh GR II Olympus E-M5 II Panasonic Lumix DC-G9 +8 more
Tungsten Nordstein
Re: GRIII Poll
Rob
H
Throwing up in your mouth is not silly. It's pretty unpleasant. Especially for your dentist or significant other.
Is it possible that you are taking things a mite seriously these days, Harold?
preferredfault Regular Member • Posts: 273
Re: GRIII Poll
I'll tell you how I feel when I see the price.
"I can explain it for you, but I can't understand it for you."
MrHollywood
Re: GRIII Poll
Agreed. I usually don't care much about price, but Ricoh is on drugs if they think they can a lot of these with a high cost.
The sensor better be great and the lens better be sharp or it'll die fast.
Rob
TN Args
TN Args Veteran Member • Posts: 8,812
Re: GRIII Poll
Although I recently saw a mod comment that it is routine for people to run multiple accounts here so they can influence polls. Also that some of them open polls for same reason.
So, bearing that in mind, ..... it is interesting that with 54 votes counted, only 8 fell clearly on the No side. Come on No voters, put those multiple accounts to work!
 TN Args's gear list:TN Args's gear list
Sigma dp0 Quattro Panasonic Lumix DMC-GX7 Olympus E-M5 II Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G 14mm F2.5 ASPH +7 more
MrHollywood
Re: GRIII Poll
I doubt this is happening.
But 25% on the fence or not buying does not bode well for a camera that had universal acclaim via the GRII.
Final judgement has to be reserved until we see real tests and reviews.
Rob
TN Args
Re: GRIII Poll
Rob
I reckon it's unbelievably good. Remember how many GR and GR II users are happy with the camera they have. Not everyone is GAS-aholic.
thelps
thelps Contributing Member • Posts: 521
Re: GRIII Poll
Rob
finally, a good idea.
 thelps's gear list:thelps's gear list
Samaistuin
Samaistuin Senior Member • Posts: 1,062
Re: GRIII Poll
I never use the flash, so I don't care about its disappearance.
Wish they had put a 35mm lens though.
ANAYV Forum Pro • Posts: 17,709
Re: GRIII Poll
I liked it, but wondered why, when pressing the shutter button, it doesn't go away.
I'm forced always to press a button telling the GR ' I'm done adjusting the exposure compensation, where other cameras will revert back to shooting mode, once the shutter is half pressed. GXR also has this ' issue'
My thoughts when this happens:
I made my adjustment..pressed the shutter,now get off the screen!
They are. Removing the Anti Aliasing filter renders images sharp..and that sharp lens!
This was the first camera ever, for me, that I didn't have to add sharpening in post.
Afraid I would cut myself, the detail from this little gem. I miss it at times.
For now, enjoying going back in time...and like the output of my VR  enabled GX100.
Not the same I.Q.....but 24mm I like better than 28mm.
BTW, I'm not a street shooter..so I'm a rarity here, using these camera's for landscape and scenic photography.
Love the controls, layout and design of Ricoh camera's. Keeping my GXR , for sure.
ANAYV
Alex Sarbu Forum Pro • Posts: 10,536
Re: GRIII Poll
I reserve the final judgement for until after I see the camera and have it in my hands, but I'm quite tempted - so it's one of the first two answers for me
I'm a Pentaxian, and such a little gem would complement my DSLR kit nicely.
Alex
 Alex Sarbu's gear list:Alex Sarbu's gear list
Ricoh GR III Pentax K-5 IIs Pentax K-1 II Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 70mm F2.4 AL Limited +8 more
teemodk Senior Member • Posts: 1,277
Re: GRIII Poll
There is an update that fixes that.
ANAYV
 teemodk's gear list:teemodk's gear list
Oppo R7 Plus
Civic76 Regular Member • Posts: 209
Re: GRIII Poll
I think It Will be a great camera
Andrea
 Civic76's gear list:Civic76's gear list
Sony a7 III
ripleysbaby Senior Member • Posts: 1,094
Re: GRIII Poll
Hate to be the one to tell you but that was fixed using shutter button confirmation  in firmware update  v2.03. Over 5 years ago !!!
