Are there any cheap landscape lenses for a GH4?
Started Oct 1, 2018 | Questions
KaviDey New Member • Posts: 2
Hi all,
I just got a GH4 and I am looking to get my first lens for it. I want a lens that it's good for landscapes and video, but isn't too wide do I can also do done video. I am fine with used lenses, and my budget is MAX $140 US, but I would prefer cheaper.
If there aren't any lenses that fit that category and price, then I'd love a good starter lens recommendation.
Thank you!
Panasonic Lumix DMC-GH4
martok80 Junior Member • Posts: 31
Re: Are there any cheap landscape lenses for a GH4?
I'm not really an expert in landscape photography per-se, but you aren't going to find a whole lot besides kit lenses for under $140.
You can check some places like Keh, Adorama, B&H for used stuff.
For instance: https://www.keh.com/shop/lenses/micro-four-thirds.html
Looks like you could nab a Olympus 14-42 mk ii to get you started.  I absolute *hate* the 14-42 mk i and might suggest you try to nab that Panasonic 12-32 that is at $144.  The wider 12mm focal length and higher quality of that lens should serve you pretty well.
 martok80's gear list:martok80's gear list
Canon PowerShot S90 Olympus PEN E-P1 Olympus PEN E-PM2 Olympus E-M1 Olympus M.Zuiko Digital ED 14-42mm 1:3.5-5.6 +7 more
k3shooter Forum Member • Posts: 83
Look to mpb.com
They have the old 14-45 for $124 excellent, $134 like new. It is good optically but has Mega-OIS rather than Power-OIS.
14-45
The 12-32 is not that much more... and is wider and much more compact
12-32
Best Regards,
Steve
 k3shooter's gear list:k3shooter's gear list
Olympus PEN E-P5 Olympus E-M5 II Pentax K-70 Sigma 17-50mm F2.8 EX DC OS HSM Panasonic Lumix G X Vario 35-100mm F2.8 OIS +2 more
RickPick
RickPick Senior Member • Posts: 1,332
It all depends on what you mean by "not too wide". A "normal" lens (c.50mm) is reckoned to be one which gives a similar field of vision to the human eye, so I will go with that.
The Panasonic 25mm f1.7 lens fits that bill because with m4/3 you double the lens focal length to get the equivalent in 35mm ("full frame") terms. That's because the diagonal of the m4/3 sensor is 1/2 the diagonal of an FF sensor. You should be able to get that lens for the sort of amount you mentioned.
The older Panasonic 20mm f1.7 is also available now at a good price, especially used, and is an m4/3 classic due to its small size, sharpness and contrasty rendering. It can be good for landscapes. Its weakness is slightly slower autofocus compared to the more recent 25mm f1.7 - and complete lack of continuous AF capability. It is still usable for video if you don't mind using single AF or manual focusing.
Both of the above are prime lenses, meaning they have a fixed focal length. They will give you the best value in terms of light gathering ability - zoom lenses are nearly always more limited in that regard, with a typical kit zoom starting at f3.5 or f4 as its widest aperture at the minimum focal length. If you're willing to forgo that for their greater flexibility, there are several zooms you could acquire quite cheaply in the 14-45mm zoom range.  The Panasonic 14-45mm f3.5-f5.6. is one example that should be available used for the money.
Bear in mind to that the GH4 uses a considerable crop in 4K video, so you will need a wider lens in 4K to get the same field of view as a still photograph.
To sum up, one of the prime lenses will give you the best value in terms of image quality, particularly in low light. Against that, you will be restricted to a single focal length and will have to "zoom with your feet". A kit zoom will give you much more flexibility for framing and should give decent results in good light.
 RickPick's gear list:RickPick's gear list
Panasonic Lumix DMC-GH4 Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +4 more
Aaron801 Veteran Member • Posts: 7,900
The most consistently sharp lenses are going to be primes and pretty expensive at that. Still, it seems to me that if you stop down even a cheaper zoom you can get some really sharpness with it and shooting landscapes you're probably going for deep depth of field anyway.
I've shot a lot with a really cheap old 14-45mm Pansonic kit zoom and even landscapes with lots of detail seemed to work OK with it.
my flickr:
www.flickr.com/photos/128435329@N08/
 Aaron801's gear list:Aaron801's gear list
Olympus PEN-F Panasonic Leica Summilux DG 25mm F1.4 Olympus M.Zuiko Digital 45mm F1.8 Samyang 7.5mm F3.5 Fisheye Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS +1 more
hindesite Veteran Member • Posts: 4,893
KaviDey wrote:
Hi all,
Well, given that I use lenses from 8mm to 800mm for video, you might need to be a bit clearer about just what kind of video you have in mind.
Wildlife, vlogging, macro, product reviews, weddings...
I think the 12-32 is a poor recommendation for the GH4; even new it is very, very cheap, so appears to be a good deal, but with no focus ring is limited in application. Great compact travel lens though.
Paulmorgan Veteran Member • Posts: 9,499
KaviDey wrote:
Hi all,
Thank you!
For a budget of $140 I`d be looking at a kit lens 14-42, 12-50 etc.
JLWPhoto Regular Member • Posts: 470
KaviDey wrote:
Hi all,
Thank you!
If you can stretch the budget a little bit (or wait a little longer and save) you can find the Panasonic 12-60 kit lens for under $200. There is one on fredmiranda for $185 and on ~$200 on ebay.
As others have mentioned, the 12-32 is a great start lens and tiny!
 JLWPhoto's gear list:JLWPhoto's gear list
Canon EOS M Panasonic GX850 Panasonic Lumix DC-GX9 Nikon Z50 Sony a7C +28 more
JLWPhoto wrote:
KaviDey wrote:
Hi all,
Thank you!
Damn... I might go with that. I have one of those and felt like I was getting a good deal with the used one I got for $250, but they may have come down in price since I got mine.  It's not the fastest zoom, but is well built and seems to be optically better than the kit zoom that I had before. I like it because it foes down to 12mm (and the 60mm can be useful as well) and has a really close focusing distance.
my flickr:
Dutch Newchurch
Dutch Newchurch Veteran Member • Posts: 5,716
Paulmorgan wrote:
KaviDey wrote:
Hi all,
Thank you!
A second hand 12-50 might be the most versatile lens for the price.
Dutch
forestmoonstudio.co.uk
My DP Review gallery
Photography is about light, not light-proof boxes.
Dutch Newchurch wrote:
Paulmorgan wrote:
KaviDey wrote:
Hi all,
Thank you!
Its all I use, for scaping fast, lenses, IS etc is just not needed when using fairly long exposures and a tripod, most if not any lens will be up to the job.
OP KaviDey New Member • Posts: 2
I am planning to do some vlogging, and also shooting in mountains and near river just for fun.
JakeJY Veteran Member • Posts: 5,442
KaviDey wrote:
Hi all,
Thank you!
I presume you want a decent zoom range. If you can stretch your budget a bit, the Panasonic 12-60mm f/3.5-5.6 fits your bill (should be around $200 used) and is weather sealed also.
Or you can find a Panasonic 14-42 II. Make sure you get the newer II version, the original one is rated quite poorly. The old 14-45mm also gets good ratings although the OIS is older.
 JakeJY's gear list:JakeJY's gear list
Nikon Coolpix S9300 Nikon D5000 Panasonic Lumix DMC-GX85 Nikon AF-S DX Nikkor 55-200mm f/4-5.6G VR Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR +6 more
jwilliams Veteran Member • Posts: 6,400
try to find ...
the original Panny 14-45, 14-42 II (not V1) or the 12-32.  All pretty decent lenses and can be found used around your price.
Jonathan
