Sony A7ii (A7rII) Meikon underwater housing + Rokinon (Samyang) 14mm f2.8 AF
Started Oct 1, 2018 | Discussions
plasticsdoc New Member • Posts: 7
Despite what was written in other threads the Meikon housing for the A7 mark 2 series will fit a Rokinon/Samyang 14mm AF lens!
Need to mount the camera first
The barrel needs to be mounted first, then the lens should be mounted.
Finally, the dome can be placed.
Taking the lens out is the process in reverse, however, it requires releasing the lens from inside the casing after the dome is taken off. Small fingers are a must!
Haven't tested this underwater, still trying to modify the casing to accept a vacuum valve.
Sony a7
Barmaglot_07 Contributing Member • Posts: 633
Re: Sony A7ii (A7rII) Meikon underwater housing + Rokinon (Samyang) 14mm f2.8 AF
Whoa, that's... involved. How does the 14mm lens line up with the dome's nodal point in this setup? Also, can you change the camera battery without taking the whole thing apart, or do you recharge via USB between dives?
 Barmaglot_07's gear list:Barmaglot_07's gear list
Sony a6300 Canon EF-S 60mm f/2.8 Macro USM Sony E 30mm F3.5 Macro Sony E 18-200mm F3.5-6.3 OSS LE Sony E 10-18mm F4 OSS +5 more
OP plasticsdoc New Member • Posts: 7
Yes, quite a tedious process. It would be best to do USB charging since the camera needs to be taken out to change the battery.
Need to see is IQ is worth the hassle, but this is the lens I am using for astrophotography. I wanted to see if I could get away without buying a new WA lens.
daveco2
daveco2 Contributing Member • Posts: 953
Very interesting. I tried it with my Batis 18 mm, but of course it wouldn't even fit into the dome, which I should have tried first. Getting the lens off was tricky, but got it done reaching in to depress the lens release with a thin screwdriver.
Yes, battery life for scuba can be a problem. I'm hoping the solution is the external box with 7x capacity battery that I built a couple of weeks ago.
I also made a box that fits under the camera and connects via a Case Relay battery adaptor for astrophotography on a scope or on a tripod for timelapse.  Box plus battery weighs 1 lb.
Tripod attaches at same X-Y position as camera.
 daveco2's gear list:daveco2's gear list
Sony RX100 Sony a7R II Sony a7R III
Mark K
Mark K Veteran Member • Posts: 6,797
Those are very thoughtful considerations. Please feed us with some underwater images
Mark K
 Mark K's gear list:Mark K's gear list
Sony a6400 Sony a1 Sony a7 IV Sony FE 100-400mm F4.5-5.6 Sony RX100 III +76 more
guzy New Member • Posts: 22
Hi Plasticdoc, have you tried it underwater? How's the 14mm AF speed & performance?
 guzy's gear list:guzy's gear list
Sony a7 II Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Sony FE 90mm F2.8 macro +2 more
@Mark K and @guzy. My apologies for an incomplete review, which I'm sure leaves a lot to be desired. Unfortunately, I have not been able to test it out due to work obligations. Additionally, my next diving trip is not scheduled till the end of this year.
Check out Meikon's Instagram page for measly 1 example with this set-up, when I inquired further they did not respond. The picture though wasn't half bad.
I will try to get to the pool to test it out this weekend.
Mark K
Last Christmas on a diving equipment show, I have asked Meikon's boss trying to put my 16-34/4 and A7rII combo into this housing and it took him over an hour to do so. The "engineer“  and the promoters were standing by the side helplessly.
I hope I can see better products and more ports.
Mark K
NedStudio
NedStudio Forum Member • Posts: 82
Great thread, thank you for sharing. Question: do you really need extra batteries for underwater ? How long do you stay underwater and how many shots do you take?
Here is why I am asking: i do most of my  Underwater photo shoots in shallow waters. I used external strobes (Sea and Sea), and I shoot only stills. I average about 600-700 shots per photo shoot, 2.5 hours in average, one battery.
I try using fresh genuine Sony batteries for my A7rII. After 20-30 uses, i usually relegate the battery to over water use, and start a new one.
Thanks,
Ned
 NedStudio's gear list:NedStudio's gear list
Canon PowerShot S110 Canon EOS D60 Canon EOS 550D Sony Alpha NEX-7 Sony a7R II +7 more
miniadv New Member • Posts: 4
Have you got some shot? Another question, I have the same configuration, I would like to buy this housing, but every meikon dome port has the barrel unscrewable from the dome? I thought it was all fixed. Thanks
daveco2
Here's the Seafrogs 2nd Gen housing for the a7RII with the dome detached from its extension. The small retainer is shown at the rear of the dome. The extension ID near the dome is 3.9" and near the housing it necks down to 3.6". This 2nd housing has the port for vacuum checker and the zoom knob. I've used it on about 15 dives with no problems.
The two fiberoptic ports shown at the front of the housing, above the extension, are my addition and are not supplied with the stock housing.
Thank you, this model is good, there is the O-ring in both extension and dome, this one I have read that support also the sony 12-24 so it is good for the samyang too, same diameter, while in the housing of the first post, cheaper, I can't see if it has the o-ring in the tube and dome, but i hope so.
