Help! Nikon D90 Mirror stuck
Started Sep 29, 2018 | Discussions
Mika85 New Member • Posts: 6
Hi, I have this D90 wich is too old and cheap to be sent to any kind of service. I was wondering if someones been fixing cameras and knows how to solve this problem.
When lens not attached, camera seems to be working fine. You press button and it takes a photo. Everything works. When I take lens, any lens, and put it on, all still seems to be ok. I can AF, all automatics work fine, untill I take a picture.
It takes one picture. Only thin line is visible as normal, everything else is black. I remove the lens, an see that the mirror is stuck in middle. I press shutter few times and mirros step by step goes up with every press, and releases. Then it works again with no lens. If I put lens on, same problem again.
Any good Ideas how to fix this myself?  I have fixed lot of lenses and changed shutterunits to cameras so I do have equipment to dissassemble the camera.
Thanks and sorry for my english.
 Mika85's gear list:Mika85's gear list
Nikon D600 Nikon AF-S Nikkor 70-200mm f/2.8G ED VR Nikon AF-S Nikkor 300mm f/4D ED-IF Nikon AF-S Nikkor 24-70mm f/2.8G ED
Nikon D90
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Re: Help! Nikon D90 Mirror stuck
A wild guess: the only thing I can think of that's different with a lens attached is that it has to wack the aperture to the set value when a lens is attached. Perhaps there just isn't enough power to hoist the mirror and wack the aperture? Either that or maybe there's some sort of mechanical coupling that ensures timing of the two motions and it is worn and sticks in its travels when there is force on the aperture?
Can you see if the lens does stop down (and reopen after) when the shutter is fired?
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
OP Mika85 New Member • Posts: 6
Hi, and thanks for your reply.
I can not see lenses apertureblades moving when I fire the camera, they seem to stay open. They cant be that quick that I miss that movement?
There is that aperture lever inside of cameras mount wich has two parts. When I remove the lens as the error is on, upper lever part is up and one is stuck at downpostion. Mirror is halfway going up.
Now when I try to release the mirror after I take the lens off, it still jams a few times going up. I have to fire the camera maybe five times and with every press, mirror goes little bit more up. When it gets up, it releases and everything works normal after that until I put the lens on again.
KenCK41 Regular Member • Posts: 221
The problem is in the mechanism on the side of the mirror box. Possibly the lever that connects to the lens aperture setting is slightly bent or twisted. The aperture control mechanism is quite complex and parts do wear out.
It would require pulling the mirror box,   Figuring out the operation, and then access if it’s a bend restricting the aperture control lever or some deeper issue requiring parts replacement
rghermi New Member • Posts: 1
Hi, I have the exact same issue with my D90. I was wondering if you could fix your camera and what the issue was. Thanks.
Al Young New Member • Posts: 2
Hi guys, I recently acquired a used D90. When I attached an old Nikkor manual lens, prime and zoom, everything works normal (of course in manual mode). But when I attached an AF-S DX NIKKOR 18-105mm f/3.5-5.6G ED VR, the shutter blade also stuck in the middle and not coming down.
I already renew to the latest firmware for both camera and lens (as at September 2020)
This makes it very interesting.  D90 works for the manual lens but not newer AF-S.
Anyone can give me some hints?
Cheers
Hi guys, I have the same problem with my D90. Works ok with manual lens but not digital ones.
Any one out there knows a DIY solution?
Thanks a lot.
