Pany 42.5mm f/1.2 vs Oly 25mm f/1.2
Started Sep 28, 2018 | Discussions
BeardedPixelPeeper New Member • Posts: 8
I was wondering if anybody has experience with both of these lenses. I know they're different focal lengths but I'm wondering which has the advantage, strictly judging on sharpness. Would be using either on my Lumix G7. Video and stills. I've seen great reviews on both, but neither seem to come out as a superior lens.
Thanks guys.
Panasonic Lumix DMC-G7 Panasonic Lumix G 42.5mm F1.7
MOD Tom Caldwell Forum Pro • Posts: 46,360
Re: Pany 42.5mm f/1.2 vs Oly 25mm f/1.2
Thanks guys.
You might find it hard to get the answer you want.  These are two lenses of quite different focal lengths.  I have the PL 42.5/1.2  and the PL 25/1.4.  Both are great lenses and I would not necessarily pick one over the other I tend to use them as needed and mainly the 42.5/1.2 as that is the length I prefer to use.
Tom Caldwell
pdelux Senior Member • Posts: 1,113
Thanks guys.
Theyre both great lenses optiically. (i only have the 25).
But I feel the 25 FL is more useful, but that depends on how you shoot and what other lenses you have.
Personally 25. 1.2 should be cheaper and I would use 1.2 on a 25 more often.
On the 42.5 I would be stopping down alot (depends on what you shoot) so perhaps you can get buy with a 1.7/1.8 portrait lense instead and have both it and the 25 1.2 for the same price as the Nocticron.
 pdelux's gear list:pdelux's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +6 more
Boss of Sony Senior Member • Posts: 2,425
I don't know why you would be tossing up between these two lenses. They're quite different. And both optically amazing. 25mm is a much more useful focal length for general photography. It's one of my favorite focal lengths. 42.5 is more a specialist lens for portraits, etc., and you will find less uses for it than 25mm.
 Boss of Sony's gear list:Boss of Sony's gear list
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GX85 Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 9mm F8 Fish-Eye Body Cap Lens
Adielle
Adielle Senior Member • Posts: 1,754
Consider your perspective
Just like what those before me have said.. I would not want to use 42.5mm for general photography. Only when you get really close to the subject, the perspective is such that it's not obviously "distorted" (compared to how we generally see things), and that's why it's used for portraits because it allows to fill the entire frame with the face without getting the same kind of perspective distortion you would get in real life or with the 25mm lens. Personally I don't like to fill an entire frame with a face.. so I get the right look with 25mm anyway, some torso included :).
rueil Junior Member • Posts: 43
I have both. The Panasonic 42.5 is a whole lot sharper than the Olympus 25 Pro.
The Olympus 25 has ok sharpness at f/1.2 but does not improve much by stopping down. It is not good at infinity focus either. I think the Olympus 25 is my worst landscape lens as all my other lenses (m43) seems sharper stopped down at infinity focus.
The 25 Pro is a disappointment. It has low contrast and is not particularly sharp.
It does have nice rendering and build quality, but you would expect so considering the price.
 rueil's gear list:rueil's gear list
Leica Q Panasonic Lumix DMC-GM5 Panasonic Lumix DC-G9 Nikon Z6 Olympus OM-D E-M1X +12 more
JeanPierre Martel Veteran Member • Posts: 3,304
Wide open, the M.Zuiko 25mm is very sharp in the center of the image but a little soft on the sides. From F/2,0 it’s sharp all over.
When the lens was new to me, I’ve tried it under many different situations but at the end, it became my favorite prime at museums: at F/2,0 for paintings and F/1,2 for close-ups of sculptures.
I also like it for nighttime photography, as a automatic-focusing substitute for the Voigtländer 25mm F/0,95.
Here are some shots published mostly with that lens (beware: in the lot, there might be some taken with different 25mm lenses):
https://jpmartel.quebec/?s=25mm (skip the French text)
The Lumix-Leica 42,5mm is a totally different beast. For close-up photography, it doesn’t have to be as close to the subject as the M.Zuiko 25mm F/1,2.
Moreover, it’s bokeh is unique. I just love it.
It’s my favourite lens for close-ups of relatively small flowers:
https://jpmartel.quebec/?s=42%2C5mm (skip the French text)
 JeanPierre Martel's gear list:JeanPierre Martel's gear list
Olympus E-M5 II Olympus M.Zuiko Digital ED 75mm F1.8 Leica Nocticron 42.5mm Olympus 40-150mm F2.8 Pro Olympus 8mm F1.8 Fisheye Pro +17 more
Adielle
Good to see that I'm not alone in thinking that. That's what I've seen, mostly not great contrast and pretty "flat"-looking images (probably related to the very high number of lens elements), and especially the center sharpness seemed usable but not nearly as good as that of the DG 25mm f1.4, despite reviews saying it's sharp. For such a large size, heavy weight and high price, I would have expected something much nicer. I think the Panasonic f1.4 25mm lens is a much, much better lens overall, despite the higher vignetting at highest apertures.
LongPVo Regular Member • Posts: 104
Thanks guys.
In terms of focal length, you'd go 25 when you don't have the luxury of changing lenses or carrying 2 bodies. Kinda like a zoom that doesn't zoom.
In terms of image quality, you'd go Noct if you want to capture a lot of details (tack sharp) , M.Zuiko if you take a lot of portraits (it's flatteringly sharp, sort of like softly sharp, it's still very sharp lens trust me). It's just you don't want to show too much natural imperfections in portraits IMO.
Check out Red35 Photography
 LongPVo's gear list:LongPVo's gear list
Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus 45mm F1.2 Pro Olympus 17mm F1.2 Pro
glassoholic
glassoholic Veteran Member • Posts: 7,641
Advice requested
Thanks guys.
Hopefully discussing just the Oly Pro is not seen as thread hijacking...
I have followed some of your and others experiences with the 25 Pro and have some questions...
I find the 25 Pro gorgeous at f1.2... super smooth rendering and clean colour rendition. It is not sharp in a clinical hard edged way but basically  sharp enough to render what is needed for closer focus subjects... and the slight softness seems to work together with the really smooth bokeh wide open... the shot looks lovely.
My Sigma 30mm f1.4 DC DN is sharper wide open overall but images look a bit "gritty" in comparison and bokeh is not as smooth and colour fringing both lateral fringing and longitudinal haze is unpleasant wide open... it can be cleaned up in processing but image gets even "coarser".
The problem is that by f1.8/f2.0 I can use the Sigma for when very detailed rendering is necessary and it's aberrations have cleaned up... like a group of ten people shot full length. I need faces crisp in a 16x20" enlargement. I have done this with the Sigma successfully but I have my doubts with the Oly Pro. It does not sharpen up until f3.5. I have done some testing and it seems it "should" be ok at around f2.0.
I still have some concern that when used for a job it might throw up a nasty surprise... prove to be a wide open one trick pony. Can you or others comment as experienced users.
M43 equivalence: "Twice the fun with half the weight"
"You are a long time dead" -
Credit to whoever said that first and my wife for saying it to me. Make the best you can of every day!
Velocity of Sound
Velocity of Sound Contributing Member • Posts: 964
If you go by numerical measurements...
If you go by those tests that measure sharpness, the Nocticron is sharper than the 25mm f/1.2.  However, it's worth mentioning that the Olympus 45mm f/1.2 out-resolves even the Nocticron, and currently has the distinction of being the sharpest lens on the system (with the second-sharpest being the Panasonic 200mm f/2.8).  Again, this is all based strictly on measurements.
I don't own the Nocticron on the 45mm f/1.2, but I do own the 25mm f/1.2  It's not critically sharp; I can usually tell it apart from my 12-100mm f/4 by sharpness, and indeed, lens testing shows that the 12-100mm has better resolving power, which is pretty surprising.  I also own the 17mm f/1.2 and I -think- it's sharper, but sometimes it's less clear to me.  I considered selling the 25mm f/1.2 after getting the 17mm f/1.2 but there's something special about the way images appear; I really like it, and some of my favorite family photos were taken with that lens.  As people often like to say, there's more to an image than how closely you can pixel-peep, and so I continue to keep and use my 25mm f/1.2.
But if Olympus ever remade it and gave it the sharpness boost people expect, I'd be very tempted to sell mine and purchase the new version.
 Velocity of Sound's gear list:Velocity of Sound's gear list
Olympus E-M1 II Fujifilm GFX 50S Fujifilm GFX 100S OM-1 Olympus Zuiko Digital ED 50mm 1:2.0 Macro +14 more
glassoholic
Re: If you go by numerical measurements...
Thanks... I wonder if the slight lack of sharpness was designed in? It does produce lovely files but I am still getting used to it and making a "sharper version" of it might ruin the "look" it gives?
Re: Advice requested
I use the 25 mostly between 1.2 and 2.8 I very rarely use it at F4 or higher, because I usually take portraits of people/kids in small groups 1-3.
The lens is very sharp @ 1.2 - (not record breaking) but only a fool could fault its sharpness. Its not the clinical type of sharpness you find on the other Olympus lenses - there is a different somewhat very natural looking sharpness, zoomed in 100% you can really see its very sharp. It does improve slightly up to 1.8/ F2 but I think from F2 onwards sharpness improvement is probably negligible, perhaps only in the corners.
But thats just my version and how I perceive it - there are obviously websites which test this sort of thing. The Imaging resource review mirrors my experience with it:
"Sharpness
The lens does not disappoint: it is very sharp right out of the gate at ƒ/1.2 and offers tack-sharp edge-to-edge sharpness by ƒ/2. You can stop down further if you want, but it doesn't garner substantially more image sharpness."
Sigma is known for excellent sharpness, but sharpness sometimes comes at a cost of "character" i.e. very clinical. I feel sometimes that my Olympus 45 1.8 is sometimes like this, and other olympus lenses are known for this.
In my opinion the idea of sharpness can be overrated. Call me crazy - but sometimes I prefer a softer overall image to a very sharp one. Some of my fav images are from my voigt 17 @ F0.95 -- and no the image background is not a blurry mess, infact very recognisable - but the overall softness of the image including the subject adds a very dramatic, cinematic quality.
Of course it depends on the images you make - there are times where absolute sharpness is critical, like a large group photo with lots of small faces. But for my type of shooting it i will consider the overall "look" and quality the lens produces, sharpness I think once it reaches an acceptable level loses its importance.
P.S. a 25 is not the most ideal FL for large group photos you have to backup quite a bit...
Andersonm Contributing Member • Posts: 954
some basic experience re group photos
My rule of thumb for ordinary social settings, where you are taking photos of people facing you at a "normal" distance:
45mm will do 1 person well
25mm will do 2-3 people well
20mm will do 4-8 well  - my favorite
12mm will do 20 well
 Andersonm's gear list:Andersonm's gear list
Olympus OM-D E-M5 Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 20mm F1.7 II Panasonic Leica DG Summilux 15mm F1.7 ASPH
glassoholic
"Sharpness
A very good assessment IMO. I am still "reprogramming" my mind for the 25 Pro to appreciate the smooth-sharp low contrast vs the coarse-sharp high contrast of the Sigma 30 1.4 DC DN. A perfect lens would have the characteristic of the Pro between 1.2 and 1.8 and the characteristic of the Sigma between 2.0 and 5.6 lol...
glassoholic
Re: some basic experience re group photos
Spot on... I have to swop your 20 for a 17 though! But I get it done.
I think the lack of sharpness in the smaller apertures is a compromise to achieve the beautiful back ground blur and wide open performance. We know Olympus can make super sharp lenses, this lens uses a different philosophy. That being said it's still a very sharp lens at all FL but I guess doesn't improve exponentially as other lenses do when stopped down. Also I think the lower contrast adds to the the illusion it may be less sharp than it is. But I like the less contrasty images, if you post process many prefer a flatter image to work with, and contrast is easily fixed post or even in camera while shooting. I find my self reducing contrast in alot of images after applying the Olympus profiles in Lightroom.
Okay. My error. I’ve since used the Olympus 25 Pro more and started to love it. In fact, is my most used lens this year. My mistake was comparing it in sharpness to the likes of other 50mm primes I’ve had experience with. My point about sharpness at infinity (landscapes) and poor contrast in back lit situations still stands as it can not compare to the likes of other brands top 50mm and even other lenses within the MFT system.
But the rendering and close up sharpness for environmental portraits is very good. The out of focus transitions with smooth bokeh gives to very pleasing images. It really is a beauty within the MFT system.
bofo777 Senior Member • Posts: 2,267
Thanks guys
I have both of these lenses use them for portraits and events and weddings..Both are especially great for producing smooth bokeh esp in HSS photos....You really Know how a lens performs when photographing weddings when you are continually switching from one camera to the other with these two lenses on them... Both lenses are equally exceptional in sharpness, responsiveness with beautiful bokeh...I don't really shot much video but for photography if you can add both to your collection..DO IT
 bofo777's gear list:bofo777's gear list
Olympus E-1 Olympus E-M1 Olympus E-M1 II Olympus E-M1 III Fujifilm GFX 100S +17 more
Bassam Guy Veteran Member • Posts: 4,890
Thanks guys.
Both of them are so damn sharp that sharpness is a complete non-factor. The large FL difference is a huge factor. Are you shopping for a lens to use for photography?
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
